Yet another problem with charging
Grab our Forum Feed
+ Reply to Thread
Page 3 of 4 FirstFirst 1 3 4 LastLast
Results 21 to 30 of 34
Thread: Yet another problem with charging
  1. #21
    Join Date
    May 2012
    Location
    Québec
    Posts
    15
    Default
    The store i went to said you cant have 10 gauge extension as it wont fit in regular 120 volt domestic outlet?
  2. #22
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,398
    Default
    Quote Originally Posted by Patrick View Post
    Wrong. Perhaps they are thing of some special purpose cord for power generators, etc.
    I have several 10 gauge extension cords, all have a standard 3 prong male/female ends and plug into standard wall outlets. Let me guess: the store doesn't carry any 10 gauge extension cords?
    Amazon
    http://www.amazon.com/Coleman-Cable-...extension+cord
    Home Depot
    http://www.homedepot.com/h_d1/N-5yc1...kuId=202891137
    Sears
    http://www.sears.com/shc/s/t_10153_1...sion-cord.html
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 139 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  3. #23
    Join Date
    May 2012
    Location
    Québec
    Posts
    15
    Default
    Actually they do. That is confusing!
    I went to a Rona which is quite popular here in quebec
  4.
    Advertisement
  5. #24
    Join Date
    Jul 2012
    Location
    Monroe, Ohio
    Posts
    21
    Default
    Quote Originally Posted by mmcc View Post
    And (correct me if I'm wrong) any drop in line voltage while charging will increase the amperage draw which will compound any circuit problems like loose connections, worn receptacles stabs, etc and increase heating at points where resistance is present.
    You are correct
  6. #25
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,974
    Default
    Quote Originally Posted by DonC View Post
    I agree with what you're saying but that's not what he asked. He asked whether he had fried the outlet. If that had happened then the outlet wouldn't be working at all. Since he's been charging without a problem, before looking at the outlet I think he should eliminate the possibility that this is a one time event caused by dropping line voltage.
    Still not fully true... You can damage an outlet and it will appear to work under a light load. With a heavier load it can fail completely. Depends on how much resistance the contacts have. If the contacts have been severely overheated and the contacts have high resistance die to weak springs and tarnished surfaces they might still run a light load. (Like 8 amps.) As you increase to load to 15 amps the resistance in the contacts will cause added Voltage drop and the charger will not have enough voltage to function. (Which is exactly what he described.)
  7. #26
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,974
    Default
    Absolutely true.
  8. #27
    Join Date
    May 2012
    Location
    Québec
    Posts
    15
    Default
    If i did damagethe outlet how expensive is the repair?
  9. #28
    Join Date
    Jul 2012
    Location
    Monroe, Ohio
    Posts
    21
    Default
    Quote Originally Posted by ddeen View Post
    My 120 charger does almost exactly the same thing except I don't use an extension cord, mine is plugged directly into a 120VAC wall outlet. Mine won't charge at all at 12A, resets about 3 times and then goes to 2 red lights after about 5 minutes, charges at 8A for a few hours and then I get the 2 red lights. I replaced the wall outlet with a heavy duty one and the outlet is only about 10ft from the breaker box. The voltage drops from 119VAC to 109VAC when the car is charging at 12A, 119VAC to 113.5VAC at 8A. I've now been 24 hours trying to charge it and it is only 83% charged. I'll be visiting the dealer soon.
    ddeen ,
    the problem you have may be related to a loose neutral connection . If the neutral is loose in the box or in the meterbase or at the connections at the weather head or even on the pole or pad mount transformer that feeds your house . You can have a shift in voltage. The neutral is a balance point for both hot legs. If it is not connected or loose ,the voltage can shift from high too low on one of the 120 volt hotlegs . Especially under a heavy load or motor or heating element,or in this case maybe your charger.
    I used to find this on poles or underground service burnouts by pulling the meter and jumpering both load side hot legs to 1 line side hot leg of 120v. I would ask the customer to turn on a hair dryer or the dryer and if the neutral was loose , the voltage would fluctuate high on one leg and low on the other or just bounce all over.
    If you can ,plug in your charger and test the voltage at the main breaker on both legs and see if you are at 109 in the panel or if it is unstable.
  10. #29
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,974
    Default
    Changing an outlet is about $3 for the part and 10 minutes of labor for a qualified electrician to replace it. How much does your qualified electrician charge to make a minimum house call?
  11.
    Advertisement
  12. #30
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,974
    Default
    Quote Originally Posted by Hi-Voltage View Post
    ddeen ,
    Possible. Could be a faulty neutral. Could be a faulty hot. Could be a faulty breaker. Could be a lot of things. Probably the best thing to do at this point is call a qualified electrician to come look at it with the car plugged in. Any decent electrician will have the proper tools and equipment to diagnose and solve it easily. This kind of repair should be a minimal charge.
Similar Threads
  1. Charging problem with 110 charging unit
    By ghostgs1 in forum Battery issues/TMS
    Last Post: 06-25-2012, 12:32 PM
  2. problem with charger
    By tedbe in forum Volt Ownership Forum
    Last Post: 06-23-2012, 02:28 AM
  3. CEL After Problem at Public Charging Station
    By magnushawk in forum Error messages/ health monitoring/ DTC's
    Last Post: 02-19-2012, 05:42 PM
  4. A second and more serious problem with my Volt
    By faz in forum Volt Ownership Forum
    Last Post: 11-02-2011, 08:24 AM
  5. Problem Charging at Work...
    By JorgeM77 in forum Volt Ownership Forum
    Last Post: 11-01-2011, 10:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
