iPod not recognized
Grab our Forum Feed
+ Reply to Thread
Results 1 to 10 of 10
Thread: iPod not recognized
  1. #1
    Join Date
    Jul 2012
    Location
    Little Rock, Arkansas
    Posts
    45
    Default iPod not recognized
    I have a 2 gig 2nd gen iPod Nano (MA477LL) version 1.1.3 that is not recognized by the sound system. The iPod source u=is greyed out. My iPhone 4S is recognized and works fine. Anyone else have this problem. The manual for the Volt says it should work. Thanks for any insight.
    Clay
  2. #2
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    2,069
    Default
    I can suggest a few things to try.
    1. Try a different USB cable. You may have a faulty USB cable.
    2. Back up your iPod in iTunes. Then perform a "restore". This will re-format the iPod and reset the software load.
    3. Run any software upgrades on the iPod. Then re-synch your iPod and load all your favorite tunes back on the iPod.
    You might also want to check the compatibility information with your Volt advisor. Some older model iPods may not support the USB streaming capabilities.
    You can also load MP3's onto a USB thumb drive and try playing that instead. (The Volt will not directly play AAC files from a thumb drive.)
  3. #3
    Join Date
    Mar 2012
    Location
    Arlington, VA
    Posts
    1,012
    Default
    I have an old iPod Classic 120gb that would work, but took forever to index the library. I went to a newer iPod Touch that indexes quickly and generally works fine. The had an issue with audio popping that was resolved by setting the volume on the iPod to maximum and then rebooting it.
    The only other issue I have is when I make a quick stop and then restart the Volt. Sometimes the iPod app on the Volt is stuck in Pause mode and other times the volume won't come out of the Volt's audio but out of the iPod itself inside the center console.
    After the Volt has been off for a while, the iPod then works normally.
    Dennis
    7.1kW grid tied solar/solar hot water
    2012 Volt- Diamond White, C22542 (fully loaded- MyLink-No Nav)
    2008 Prius
    Blink Level 2 EVSE
    VoltStats-Rocky Volt
    First year stats-- 13,100 miles, 100% EV, 22,500 mpg, .03 gallons burned, 92.63 mpge
  4.
    Advertisement
  5. #4
    Join Date
    Mar 2012
    Location
    Oxford, UK
    Posts
    64
    Default
    Quote Originally Posted by clayk59 View Post
    Clay
    Yes, exactly the same here. When I plug in my 2GB 2nd generation iPod Nano the car simply doesn't recognise that there's anything on the USB port. With the same cable my wife's 5th generation iPod Nano works fine. USB sticks also work fine. This is in a brand new (as in collected from the dealer yesterday) UK Chevrolet Volt (no sat nav).
    I can't verify that my manual says it should work as they didn't give me a manual for the infotainment system (and the other manuals were electronic only!), but the UK Ampera manual definitely includes 2nd generation iPod Nano as compatible.
    UK Volt, Viridian Joule.
    Google+ Electric Car UK Community
  6. #5
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    2,069
    Default
    Sounds like it's time to buy a more modern iPod. Or use a USB stick. It may well be an issue that the 2nd generation iPod simply can't stream audio over the USB port. It may not be the Volt's fault. It may be the fact that that model of iPod simply can't support the digital interface feature required to integrate with a modern system.
  7. #6
    Join Date
    Mar 2012
    Location
    Madison, WI
    Posts
    134
    Default
    My iPod nano 3rd gen would constantly lose contact with the car. I finally gave up and bought a 16GB USB drive, and it's worked perfectly ever since.
  8. #7
    Join Date
    Jul 2012
    Location
    Posts
    45
    Default
    Just upgraded to a new nano and it works great. My son got the old one. Everyone wins
    Clay
  9. #8
    Join Date
    May 2009
    Location
    Wake Forest, NC VIN:#C-8909
    Posts
    2,066
    Default
    I also gave up and sold my iPod Classic 128GB due to problems. I bought two 64GB SD cards for $38 each and split my collection on both. It now indexes quickly and doesn't have the song count limitation and song duplication that the iPod had.
    2012 Blue Topaz Volt - VIN:#C-8909 - Leather Seats Black with Dark Trim, Rear Camera
    9/15/11 Ordered, 11/18/11 Arrived (highly efficient signature zone) Volt Stats
  10. #9
    Join Date
    Apr 2012
    Location
    St louis,MO
    Posts
    24
    Default
    does 64 gb flash drive work, I had freezing problems with ipod 160 gb classic, I just gave up and switched to aux input and has been working fine, but miss the song ID which comes with USB. I am planning to switch to 64 gb flash drive, anyone here in the forum using 64 gb?
  11.
    Advertisement
  12. #10
    Join Date
    May 2009
    Location
    Posts
    2,066
    Default
    Quote Originally Posted by raj7 View Post
    Essentially 64GB SD-XC cards with a USB adapter is the same as a 64GB flash drive. They work great for me. Just make sure you reformat to FAT32 to be properly recognized.
+ Reply to Thread
Similar Threads
  1. iPod gripes
    By davemac616 in forum Chevy Volt Owners Forum
    Last Post: 05-29-2012, 12:07 AM
  2. iPod Integration
    By JHermon in forum Suggestions for GM - Chevy Volt
    Last Post: 04-26-2012, 08:29 AM
  3. iPod lockup
    By Marty in forum Chevy Volt Owners Forum
    Last Post: 01-24-2011, 12:02 PM
  4. Another Huge Advantage of Volt Recognized!
    By JoeReal in forum Hybrid and Electric Vehicle Competitors
    Last Post: 09-21-2008, 03:52 PM
  5. 4-seater iPod
    By GearheadGeek in forum Chevy Volt Engineering and Design
    Last Post: 09-16-2008, 03:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
