Charge Port Door Opened During Car Wash
Grab our Forum Feed
+ Reply to Thread
Results 1 to 5 of 5
Thread: Charge Port Door Opened During Car Wash
  1. #1
    Join Date
    Apr 2012
    Location
    Fort Myers, FL
    Posts
    26
    Default Charge Port Door Opened During Car Wash
    Hi Folks. Quick question. My Volt was going through a Car Wash today when either (1) the guy inside cleaning the dash pressed the button and opened the charge port door OR (2) the door popped open on its own. I was blaming the guy but I've done a cursory search here and it looks like there have been a few instances where the door pops open on its own during a car wash.
    Fortunately, my door stayed on and seems to be in good shape. I would never have noticed anything was wrong had I not seen the door pop open through the glass with my own eyes.
    My question is this: the door was open for half the wash (maybe 1-2 minutes of water/soap before it hit the dryers). Should I be concerned about potential water damage in the port? Should I dry it out in some way? I just got home and popped the charge port door and wiped out excess water. I realize a lot of you charge outside overnight even in rainstorms etc. but my Volt lives in a garage so this is the closest water has ever come to the charge port (and with no charge cord inserted into the port at the time).
    Suggestions? Should I wait awhile before plugging the volt back in to make sure the port dries out?
  2. #2
    Join Date
    Mar 2010
    Location
    Hampton, VA
    Posts
    168
    Default
    The port should be pretty well weather/water proof.
    I guess you could always stuff it with rice.
    Volt C-6178
    2012 Silver Ice Metallic, Camera, Nav/Bose system, cloth seats
    9 Jul - Order placed (1100) / 6 Oct - Produced (3800) / 27 Oct 2011 - Picked up! (6000)
    Last fill-up: 20 Feb 2013 / Last gas used: 21 Apr 2013
  3. #3
    Join Date
    Apr 2012
    Location
    Fort Myers, FL
    Posts
    26
    Default
    As hot as it's been in FL the last few days I'd have lunch within 15 minutes if I did!
  4.
    Advertisement
  5. #4
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,983
    Default
    You can leave the charge port open & let it dry out for a few hours if you want. It's designed to work in the rain... So I don't think a soak at the car wash should hurt anything.
  6. #5
    Join Date
    Oct 2010
    Location
    Vicksburg Michigan
    Posts
    116
    Default
    I can not wrap my mind around letting some car wash guys into or around my Volt. Running, softened, hot and cold water, a bucket and a soft sponge works for me.
Similar Threads
  1. Problem with Charge port door
    By gwmort in forum Suggestions for GM
    Last Post: 08-04-2012, 12:17 PM
  2. Automatic opening and/or closing of charge port door
    By mbartosik in forum Suggestions for GM
    Last Post: 12-25-2011, 02:47 PM
  3. Charge Port Door FROZEN SHUT!!
    By bronco7TX in forum Battery issues/TMS
    Last Post: 10-28-2011, 12:09 PM
  4. Make the charge port door manual
    By voltage692 in forum Suggestions for GM
    Last Post: 03-09-2011, 08:30 AM
  5. Charge Port Complaint
    By barry252 in forum Volt Ownership Forum
    Last Post: 02-01-2011, 12:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
