DOE "Free" Charging Station - Use Own Electrician for Installaton?
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
Thread: DOE "Free" Charging Station - Use Own Electrician for Installaton?
  1. #1
    Join Date
    Jun 2012
    Location
    Boston, MA/San Francisco, CA
    Posts
    17
    Default DOE "Free" Charging Station - Use Own Electrician for Installaton?
    Just managed to sneak under the deadline for the ChargePoint America program and qualified for a "free" Coulomb CT500 charging station. Local incentives will provide $1,200 toward installation. Based on what I have read, SPX will contact me and give an insanely overpriced quote well beyond what a reasonable electrician would charge. Can I use my own licensed electrician and have him paid through the program? This person currently does all electrical work for the property I would rather go with someone that knows the building inside out.
    EDIT 8/27/2012: Update in post #14. Short version, it wasn't worth it.
  2. #2
    Join Date
    Nov 2010
    Location
    Norwood, MA
    Posts
    155
    Default
    There are many other paper-pushing and device configuration options required for the SPX program other than connecting the electrical supply (its a government program - you can imagine the forms). The best way to reduce SPX cost is to have a sub-panel in the garage that will support a 40A breaker. I had a subpanel installed separately so the SPX portion of my install was "only" about $650.
    Why 40A when the volt only draws 12A you may be wondering???? The CT500 is capable of delivering the full amount of power supported by the J1772 spec (7.2kw or 30A) and there is supposedly an update that will allow it to provide 9.6kw) later...
    2012 Volt owner on 2/28/12
    as of 1/28/13: 8,158 EV miles - 11,090 total miles
  3. #3
    Join Date
    Dec 2011
    Location
    New York
    Posts
    365
    Default
    I qualified for the free EVSE but not the $1200 installation. After SPX's authorized electrician quoted $2800 for the installation, I paid a separate electrician $1500 to do the heavy work of installing a sub-panel in the garage next to where I would hang the EVSE. SPX still charged $500.
  4.
    Advertisement
  5. #4
    Join Date
    Mar 2012
    Location
    Arlington, VA
    Posts
    978
    Default
    You would probably have been better off having your first electrician to the whole job. Did you have to pay for a separate permit or was it included in either the $1500 from the first guy or the $500 from SPX?
    edit: I forgot that you get the extra warranty if SPX installs.
    Dennis
    7.1kW grid tied solar/solar hot water
    2012 Volt- Diamond White, C22542 (fully loaded- MyLink-No Nav)
    2008 Prius
    Blink Level 2 EVSE
    VoltStats-Rocky Volt
    First year stats-- 13,100 miles, 100% EV, 22,500 mpg, 92.63 mpge
  6. #5
    Join Date
    Dec 2011
    Location
    New York
    Posts
    365
    Default
    Quote Originally Posted by drbruns View Post
    Exactly. SPX needs to "hang" the unit for the final step to get it treated like an SPX install. While I obviously didn't like spending the extra money, I consider it ok because it's a higher capacity EVSE that I can most likely use for future EVs ... which I definitely will have.
  7. #6
    Join Date
    May 2012
    Location
    Houston, TX
    Posts
    8
    Default
    I had several estimates from SPX contracted electricans AND non-SPX licensed electricians. The stipulation to get the 'free' charging station was the need for proof any existing 240V outlet or sub-panel had the proper permits when installed. In the end, SPX returned with a $471 installation cost above the $1,200 DOE allowance -- just under what it would cost for the lowest priced 240V charging station I could buy independently. I had what SPX considered a 'special' installation that involved me providing a 35-foot trench for the conduit to run from the main panel to a detached garage...so if your install is less complicated there's a higher likelihood you may have smaller or even no out-of-pocket expenses.
  8. #7
    Join Date
    Jun 2012
    Location
    Posts
    17
    Default
    Thanks for all the replies. Sounds like SPX will be involved in one way or another.
    Here is a more in depth explanation. My significant other has been given an apartment as part of her employment contract. The facilities person has always gone with a local licensed electrician for all the work on the property. He comes with great references and has done some pretty big projects. He knows the building well and I would rather have him do the work. PG&E is coming out for a site survey and their part of the work looks straight forward. The pole carrying electricity to the property is right my parking space in the carport. The electrical meters and power panel are 15 feet in front of where the Volt will be parked. The facilities person, electrician and I have already identified a perfect location for the charging station.
    I would like to find a way for the charging station sent to the electrician and he be paid to install the charging station.
  9. #8
    Join Date
    Sep 2008
    Location
    SF Bay Area, CA
    Posts
    101
    Default
    Please continue to keep us posted on your progress. I think there have been very few installations in common type parking areas.
    That is the situation I am in but I have not purchased my Volt yet. I hope by next year - we will see how things go. Good luck with your efforts.
    Thanks for the information.
    Dave.
    No Volt yet!
    - Derailed on disability and going broke with FOR PROFIT health care costs in the USA! Every other industrialized country in the world has non-profit health care or Universal Health care that works contrary to what one might hear on some main stream news.
    Real Healthcare Reform Needed--> http://www.pnhp.org/ Watch the movie SICKO if you can stand the truth.
  10. #9
    Join Date
    Mar 2012
    Location
    Arlington, VA
    Posts
    978
    Default
    Quote Originally Posted by John_Hatchett View Post
    I would just go buy the $490 Voltec station, pay the local electrician the $300 to install it, claim the 30% federal tax credit, and sell the finished installed equipment to the apartment owner for $553.
    What 30% tax credit are you referring to?
    Dennis
    2008 Prius
    Blink Level 2 EVSE
  11.
    Advertisement
  12. #10
    Join Date
    Mar 2012
    Location
    Arlington, VA
    Posts
    978
    Default
    If I'm not mistaken, this credit expired Dec 31, 2011.
    Dennis
    2008 Prius
    Blink Level 2 EVSE
Similar Threads
  1. Detroit Free Press "outs" the Cadillac ELR
    By Codyozz in forum Chevy Volt News and Events
    Last Post: 04-25-2012, 02:36 PM
  2. California "Free" Coulomb EVSEs..What happens on Dec 31, 2013?
    By Voltmeister in forum Volt Ownership Forum
    Last Post: 04-04-2012, 04:47 PM
  3. See "Revenge of the Electric Car" for free at Hulu!
    By Raymondjram in forum Chevy Volt News and Events
    Last Post: 02-02-2012, 09:10 PM
  4. "Li-Ion Battery Fault, service within one day" and "Voltec propulsion system error"
    By Bert in forum Error messages/ health monitoring/ DTC's
    Last Post: 10-03-2011, 12:33 AM
  5. New Volt TV Ad: "See You Later, Gas Station"
    By honoreitiscom in forum Chevy Volt News and Events
    Last Post: 12-13-2010, 11:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
