High Voltage Battery measurements: VICM vs HCP
Grab our Forum Feed
+ Reply to Thread
Results 1 to 6 of 6
Thread: High Voltage Battery measurements: VICM vs HCP
  1. #1
    Join Date
    Apr 2012
    Location
    Birmingham, Alabama
    Posts
    6
    Default High Voltage Battery measurements: VICM vs HCP
    Using the DashDAQ, there are two high voltage battery current and voltage measurements. One is VICM, which I believe is the vehicle integration or interface control module, and one is the HCP. Can anyone tell me what each of these is and the difference between them?
    And while I'm on the topic, I'll also throw in ECM. Can anyone explain this to me?
    Thanks!
  2. #2
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,547
    Default
    Quote Originally Posted by agirlinalabama View Post
    And while I'm on the topic, I'll also throw in ECM. Can anyone explain this to me? Thanks!
    I don't know the answer to your question exactly but wanted to make you aware that you can use google site keyword to do searches (does not work at all sites but this one it works well). You may have done that already because one hit shows: VICM (vehicle integration or interface control module)
    ie. use this as a google search -- site:gm-volt.com VICM
    I see it is mentioned in a post at chevroletvoltage.com
    http://www.chevroletvoltage.com/inde...1&id=6613#6619
  3. #3
    Join Date
    Apr 2012
    Location
    Birmingham, Alabama
    Posts
    6
    Default
    I have checked (I was pretty determined to find this answer on my own) and have only seen the acronyms mentioned in posts, no explanations. And yes, I did find the "VICM (vehicle integration or interface control module)" that way.
    I actually just used the forum search tool, so it's nice to know that the google site search works so well. That's much more efficient!
  4.
    Advertisement
  5. #4
    Join Date
    Dec 2010
    Location
    NW suburban Chicago
    Posts
    255
    Default
    a hybrid control processor (HCP)
    VIN # B2365 Chicago suburbs (purchased 4/15/2011 in Austin, Texas)
    240V Leviton Evr-Green 160 Home Charging Station installed 11/4/2011
    DASHDAQ
  6. #5
    Join Date
    Sep 2008
    Posts
    2,582
    Default
    There difference is basically where the high voltage measurement is being measured.
    The HCP (Hybrid Control Processor) is also known as the Hybrid Powertrain Control Module 1 (HPCM1) and is located internal to the Power Inverter Module under the hood. Voltage measurements here would represent the "end of the line" so to speak. (only present when certain contactors are closed, subject to precharge resistances, etc etc)
    The VICM (Vehicle Integration Control Module) is also known as the Hybrid Powertrain Control Module 2 and is located under the front passenger seat. It actually receives its high voltage information from the Battery Energy Control Module (BECM) which is located inside the battery box. This voltage measurement represents the "source" of all high voltage power.
    I have been planning to write up a front page techncial article on the Volt's extensive network topology interlinking some ~35 control modules for some time now. I finally will take some vacation time at the end of the month and perhaps I will get to it then.
    There seems to be a fair amount of interest.
    WOT
    Follow the Chevy Volt on Twitter! @WopOnTour
  7. #6
    Join Date
    Apr 2012
    Location
    Birmingham, Alabama
    Posts
    6
    Default
    Thanks, WOT!
    An article on the network topology would be great!
+ Reply to Thread
Similar Threads
  1. service high voltage charge system
    By rupert in forum Chevy Volt Owners Forum
    Last Post: 10-01-2012, 08:04 PM
  2. High Voltage
    By strangeengine in forum Chevy Volt Owners Forum
    Last Post: 03-30-2012, 12:52 AM
  3. Has anyone tried to purchase high voltage battery yet?
    By Eric99 in forum Chevy Volt Owners Forum
    Last Post: 12-27-2011, 04:32 PM
  4. 'High voltage battery' and the 'power electronics' coolant levels not user service?
    By maestro77 in forum Chevy Volt Engineering and Design
    Last Post: 10-30-2011, 01:23 PM
  5. High voltage battery manual service disconnect (MSD)
    By Alex92 in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 07-06-2011, 09:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
