Screen Failure?
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Screen Failure?
  1. #1
    Join Date
    Dec 2011
    Location
    North Carolina
    Posts
    11
    Default Screen Failure?
    When I got in my car this afternoon in EXTREME heat, 104 degrees, this is what my screen looked like....any suggestions? It did reset after sitting for a while.
  2. #2
    Join Date
    Jan 2012
    Location
    Lakeland Florida
    Posts
    1,271
    Default
    LCD's don't do well in extreme heat. While I have no doubts you could have the panel replaced, its really a technology issue. If your not using a windshield sun screen, I would recommend you do as it could easily get into the 160+ range with mid-day sun beating on the dash. LCD's are spec'ed to 60C for most LCD's 70C maximum for the rugged ones for operating temperature
    2012 Crystal Red Volt #10921 - Plug Powered #76
  3. #3
    Join Date
    Jun 2012
    Location
    Illinois
    Posts
    194
    Default
    "Kinda looks neat....after baking in the heat"..........okay all cheesy rhymes aside....I agree with Henry.....might be good to get a windshield screen...especially if sitting out in the hot summer days will be a recurrent theme........
    Proud owner of Voltimus Prime and his alter ego....1.21 Jigawattz.....
  4.
    Advertisement
  5. #4
    Join Date
    Feb 2012
    Location
    Boulder, CO
    Posts
    10
    Default
    It happened to me 2/8/12, 9 days after getting my Volt. It was probably about 40 degrees, went away after a while and never occurred again.
    EE, Ecar, why not?
    Diamond white 2012
  6. #5
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,139
    Default
    Interesting. Almost identical screen shots.
    It sounds like an extremely rare race condition (a devilish software demon) during boot-up. It's probably impossible to reproduce intentionally, and therefore essentially impossible to debug/fix.
    If GM software engineers are reading this thread, the screenshots may help; however, I doubt that the probelm is in their code. More likely it's buried deep in the LCD firmware.
  7. #6
    Join Date
    May 2008
    Location
    Denver CO
    Posts
    888
    Default Definitely the Volt is a high tech car. A few cooling tips given to me by forum
    Choose the nano-ceramic or nano-carbon window tint. New, very modern window tinting. Cuts heat way down, now including the IR cut back with these amazing applications. The other is the roof. The other memberes recommended painting the roof white to go with my white car. The black is intense at pumping heat into the cabin. Note, nowadays, you can also tint the windshield with clear. Basically, cut out all the IR, UVA, and other heat conentrating rays down to a very decent level. Still, there's no guarantee that was heat. These screens can be sensitive for other reasons too. That could've been a bump during prep work. No way to know, but definitely get it replaced as soon as possible. I've gone through so many LCD screens it isn't funny. Only TVs seem to hold up because they never get moved about in my house. All my laptops, phones, gear, that's my weak link.
  8. #7
    Join Date
    May 2008
    Location
    Denver CO
    Posts
    888
    Default
    Another change for me, I picked up an extended warranty. New technology piece of mind is all. Hope I never need it frankly.
  9. #8
    Join Date
    Mar 2012
    Location
    Illinois
    Posts
    1,629
    Default
    Something similar happened to my daughters Cruze LTZ last month while she was visiting Texas in temps over 108 degrees after the car had been sitting in the sun for hours. Dealer couldn't find any faults and it hasn't happened since. I've had no issues with my 2012 Volt even in triple digit temp's here in St Louis but I did tint my windows with ceramic tint, so I wonder if that has any impact?
    So I wonder if this is heat related?
    Tom
    USAF Retired
    2012 Volt
    Best EV Range 50.x miles (more than once)
  10. #9
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,139
    Default
    Quote Originally Posted by BAZINGA View Post
    Maybe, but we do have at least one exception: Just Joe reported above that his event occurred on a mild February day in Colorado, when it was 40 degrees outside. No doubt, this seems like the kind of rare firmware defect that excessive heat could promote.
  11.
    Advertisement
  12. #10
    Join Date
    Mar 2010
    Location
    Hampton, VA
    Posts
    167
    Default
    It definitely looks like a software issue, not an issue with the screen itself. My guess is that there was a glitch as the system was loading and displaying the background image, hence why the foreground display elements (battery gauge, green ball, etc.) look fine.
    Volt C-6178
    2012 Silver Ice Metallic, Camera, Nav/Bose system, cloth seats
    9 Jul - Order placed (1100) / 6 Oct - Produced (3800) / 27 Oct 2011 - Picked up! (6000)
    Last fill-up: 20 Feb 2013 / Last gas used: 21 Apr 2013
Similar Threads
  1. Power Steering failure
    By White Diamond in forum Volt Ownership Forum
    Last Post: 06-16-2012, 12:34 AM
  2. Volt Failure - need advice
    By guyflyguy in forum Volt Ownership Forum
    Last Post: 02-29-2012, 01:12 PM
  3. Charge Cord Failure
    By Bill R. in forum Volt Ownership Forum
    Last Post: 08-30-2011, 04:16 PM
  4. Help: Volt Charger Failure
    By tangentlin in forum Volt Ownership Forum
    Last Post: 08-16-2011, 07:12 AM
  5. Fukushima Failure Analysis
    By George S. Bower in forum Politics, Finance, and Environment
    Last Post: 03-28-2011, 07:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
