Parking sensor wouldn't stop
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Parking sensor wouldn't stop
  1. #1
    Join Date
    Mar 2012
    Location
    Boston
    Posts
    61
    Default Parking sensor wouldn't stop
    This afternoon I backed out of my garage. The front parking sensor was on solid when I started, which is not unusual, but it never stopped. Even when I was out of the garage it was still solid. I thought maybe I'd dragged out a cardboard box or something so I got out to look, but there was nothing. I turned off the parking sensors but the solid beep persisted. I turned off the car and the solid beep kept going!
    I'm not sure how I got it to stop. I restarted the car once or twice, got out, and eventually the beeping stopped as I closed the driver door.
    When I returned, I turned on the sensor in the garage. It seemed to be working ok, perhaps a bit premature about turning from beep-beep to solid beep, but it responded when I turned it off.
    Anyone else have this experience or an explanation?
  2. #2
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,650
    Default
    This happened to me exactly once, a few days ago. I still don't understand it, but I went through most of the same things (was really surprised when turning off the car didn't help!) It shut off after about a minute? Disturbing, for sure. :-/
    It was the same sort of thing - a legitimate solid tone at the front that I backed away from but the sound didn't stop.
    Walter
    Volt FAQ
  3. #3
    Join Date
    Jan 2012
    Location
    Los Gatos, CA
    Posts
    176
    Default
    I've had this happen once, too. I think I powered down the car and opened the driver's door to get it to stop.
    - Mark
  4.
    Advertisement
  5. #4
    Join Date
    Nov 2011
    Location
    Newport Beach, CA
    Posts
    16
    Default
    I've had that happen twice. But both times it went off after about a minute. Very annoying.
  6. #5
    Join Date
    Nov 2011
    Location
    Sylmar, Ca
    Posts
    122
    Default
    Wow. Funny the same thing happened to me for the first time today. Backed out and it just kept going. I put it in drive and then hit the button to turn off the sensors and it went on for a few seconds then finally turned off. Very odd.
    Alex
    2012 Crystal Red Volt, All options except Navi.
    VIN#C-3498 Born 09/11= RIP 11/28/11 with 1600 miles.
    GM Buyback
    Me
    2012 Blue Topaz Volt/ Loaded with every option adopted 1/12/12 with 9 miles
    VIN#C-7622 "AC2DC" EV Personal best= 58.1
    Current lifetime MPG=103
    Wife
    2012 Toyota Prius Plug-In
    Adopted 11/5/12 with 3 miles
    Current MPG=105
    "American by birth, Teamster by the grace of God"
    Local 399
  7. #6
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,269
    Default
    I think it happened to me once a few months ago. Not exactly sure but I think I cleared it by powering the car off and then on again. It might have been a couple of times. I don't have a great idea because the noise so threw me off and I couldn't figure out what the issue was.
  8. #7
    Join Date
    Oct 2010
    Location
    San Jose
    Posts
    222
    Default
    Happened to me just once, and nearly a year ago:
    http://gm-volt.com/forum/showthread....1054#post81054
    Volt #3002
  9. #8
    Join Date
    Mar 2012
    Location
    Boston
    Posts
    61
    Default
    Quote Originally Posted by dtaubert View Post
    Your thread indicates that it was your rear sensor. Mine was the front, and sometimes I'm parked close enough to trigger the solid tone, so that's why I didn't think it was unusual. Were you parked close enough to legitimately trigger a rear warning tone?
    Also, this morning mine definitely didn't go from solid tone to beeping until I was eight or ten feet back from the wall, so I suspect it's gone out of calibration or something.
  10. #9
    Join Date
    Mar 2012
    Location
    United States
    Posts
    87
    Default
    This happened to me w/ my rear sensors last week. They started correctly but didn't stop once the obstacle was gone. Pulled over, shut off car, cleaned off sensors, started back up and no noise.
  11.
    Advertisement
  12. #10
    Join Date
    Mar 2012
    Location
    Boston
    Posts
    61
    Default
    I wondered if maybe some insect remains have clogged one of the front sensors, and that would also explain why mine now seems to be miscalibrated and why the rear sensors have been less troublesome for others.
    But why would that cause the tone to persist after the warning system and even the whole car has been turned off?
Similar Threads
  1. Tire preasure sensor not working?
    By Volt2012 in forum Volt Ownership Forum
    Last Post: 04-11-2012, 12:32 AM
  2. Battery fix/sensor
    By c6vette in forum Volt Ownership Forum
    Last Post: 02-24-2012, 02:26 PM
  3. Oil Sensor question
    By ddobrzenski in forum Chevy Volt Accessories, Modifications, and Hacks
    Last Post: 02-17-2012, 11:54 AM
  4. Is Coolant Level Sensor Necessary?
    By Marc Lee in forum Battery issues/TMS
    Last Post: 01-31-2012, 06:55 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
