Choice between level 1 and level 2 chargers at purchase
Grab our Forum Feed
+ Reply to Thread
Results 1 to 10 of 10
Thread: Choice between level 1 and level 2 chargers at purchase
  1. #1
    Join Date
    Jul 2012
    Location
    Monroe, Ohio
    Posts
    21
    Thumbs up Choice between level 1 and level 2 chargers at purchase
    I would have loved to have had the choice between level 1 and level 2 chargers at purchase . I have done electrical work all of my life and it would have not been an issue to wire it up in the garage. And I'm sure others wouldn't mind paying an electrician to do it. I can understand an upgrade in price and I would have payed it, but I could have applied the savings from level 1 charger towards it.
  2. #2
    Join Date
    Jan 2012
    Location
    Lakeland Florida
    Posts
    1,279
    Default
    Ebay the L1 charger, take the proceeds and apply to the L2 unit
    2012 Crystal Red Volt #10921 - Plug Powered #76
  3. #3
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,664
    Default
    Quote Originally Posted by Hi-Voltage View Post
    If we're in the realm of "I wish," what I'd rather have is something like the Model S ships with - a compact portable charger that comes with both normal 110V and 14-50 (trailer park 50 amp 220V) plugs, with options for almost anything else common (including the 14-30 dryer plug in my garage,) and able to support 10kW if the plug can take it (autoswitching I believe based on the plug you connect it to.)
    There's no real need for anything else to charge the car, unless you need 62 miles per charging hour (special high power system.)
    Walter
    Volt FAQ
  4.
    Advertisement
  5. #4
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,458
    Default
    Quote Originally Posted by saghost View Post
    That does sound nice.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 140 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  6. #5
    Join Date
    Apr 2012
    Location
    Durango, CO
    Posts
    211
    Default
    I think the 110 that comes with the car is intended to be a portable unit that you keep in the car so that you will always have with you the ability to recharge. Generally when you visit relatives or stop at a motel 110 will be all that might be available. What you do at home where you park your car is up to you.
    My only quibble is that it should be an option you can buy and roll into the price at the time of purchase in those areas where there are no special deals. I did it by talking the dealer into selling me the SPX Xpress that was plugged into an outlet at the dealership. It was rolled into the purchase and I just paid an electrician $125 to install a plug in my garage.
  7. #6
    Join Date
    Mar 2012
    Location
    Arlington, VA
    Posts
    984
    Default
    Quote Originally Posted by John_Hatchett View Post
    If I had to pick between a L2 EVSE or a 7kw onboard charger, I think I would probably opt for the 7kw charger so that I could get 2 hour full recharges at any of the 150+ L2 charging stations in my town.
    I agree 100% John.
    Dennis
    7.1kW grid tied solar/solar hot water
    2012 Volt- Diamond White, C22542 (fully loaded- MyLink-No Nav)
    2008 Prius
    Blink Level 2 EVSE
    VoltStats-Rocky Volt
    First year stats-- 13,100 miles, 100% EV, 22,500 mpg, 92.63 mpge
  8. #7
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,983
    Default
    Having a 7kw onboard charger would make paying for an L2 station at home worthwhile. Paying for an L2 station installed at home to only get 3.3kw is marginal.
    The difference between L1 and L2 on the Volt is 8-12 hours vs 3-4 hours. I would hardly call a 100% increase in charge speed "marginal".
  9. #8
    Join Date
    Dec 2011
    Location
    Los Angeles
    Posts
    254
    Default
    A full L2 on-board charger in the Volt would make Walgreens' asinine charger pricing competitive with gasoline. Fingers crossed for 2015 when my lease is up!
    -Drew
  10. #9
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,983
    Default
    I just wish GM would educate dealers about charging options and SPX. I asked my dealer if they knew where I could get a charger installed and they just gave me a blank stare. My dealer did not even know an L2 charger was available for the Volt. I don't think a dealer should be allowed to sell a Volt without some basic understanding of where to direct a customer to order a charger and have it installed.
  11.
    Advertisement
  12. #10
    Join Date
    Mar 2008
    Location
    Fort Worth, TX
    Posts
    694
    Default
    We've had similar discussions over on the Leaf forums. If GM and Nissan would include an auto-sensing 120V / 240V EVSE that would really help a lot. Many people would not need to spend the money for a second EVSE. At least with the Volt I consider 240V charging to be a luxury, due to the nature of the vehicle being range-extended. However, with a Leaf it is a necessity for most people.
    Ironically, since my wife bought the Volt 2 months ago, I've been downgraded to charging my Leaf on 120V so she can have the 240V charger. This is primarily because I drive 10 miles per day and she drives 40. And I'm using the Volt's L1 unit to charge my Leaf since it mounts nicely on the wall compared to the Panasonic unit provided by Nissan.
    2011 Blue Nissan Leaf SL (No QC Port)
    2012 White Chevy Volt
Similar Threads
  1. Battery Life Related to Level 1 vs. Level 2 Charging?
    By BILL GERTH in forum Engineering and Design
    Last Post: 01-04-2012, 12:03 AM
  2. Michigan Consumers Energy-Free Level 2 Chargers!
    By Selling Volts At Sundance in forum Volt Ownership Forum
    Last Post: 11-17-2011, 11:14 AM
  3. Explain why Level 2 chargers are so expensive
    By MIN FUEL in forum Chevy Volt News and Events
    Last Post: 10-31-2011, 01:47 PM
  4. Any Level 2 Chargers Cheaper than the Voltec?
    By Marc Lee in forum Volt Ownership Forum
    Last Post: 01-30-2011, 09:28 PM
  5. Rant: FUD campaign re level 2 chargers
    By Marty in forum Engineering and Design
    Last Post: 10-14-2010, 06:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
