The Heat Sure Cut My Range...
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 23
Thread: The Heat Sure Cut My Range...
  1. #1
    Join Date
    May 2012
    Location
    Ol' Virginy
    Posts
    43
    Default The Heat Sure Cut My Range...
    I'd been getting 43+ miles on battery since I got my Volt.
    It's been in the high 90's, and I'm using air-conditioning and still driving the same speed...and my mileage has dropped to 32-33! I didn't realize the air-conditioning sucks up that much power.
  2. #2
    Join Date
    Mar 2012
    Location
    Sunny Florida
    Posts
    538
    Default
    That's quite a hit. On hotter days we usually spend about 3-5 miles on AC. I say spend because it's so worth it When only one person is in the car we'll only spend a minute or two on Comfort before switching to Eco. With a fully loaded car we usually spend the first 5 minutes on Comfort, switch to Eco and occasionally switch back to Comfort for a few minutes.
    Ford Fusion Energi
    Cyber Gray Metallic VOLT
    Gasoline is for suckers Hidden Content
    Dan & Nan - Lowering gas prices since March of 2012
  3. #3
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    4,095
    Default
    Been over 100 here and I only use ECO and AUTO fan. I've only noticed 3ish miles extra being used. I used the blue/red arrows to adjust the temp. 73-75 will essentially adjust the fan speed. I point 3 vents toward myself and close the forth. I have a post/thread with pictures of this but simple to understand and *very* effective.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Mar 2009
    Location
    Phoenix, AZ
    Posts
    1,206
    Default
    Me too.
    It's been in the 110's here in Phoenix, and I'm down to about 35 miles range.
    This is not bad though. My AC and TMS are running all the time in this weather....
  7. #5
    Join Date
    Dec 2010
    Location
    West Virginia
    Posts
    804
    Default
    Losing power for a week cut into my EV mileage a bit..... Good thing I had the ICE to fall back on, although waiting in line to buy gas is something I hadn't done for more than 40 years.
    I'm very grateful to all the power company linemen from as far away as North Dakota who have come to help restore our electric network. Yesterday I passed a long convoy of bucket trucks with "Kansas City Power and Light" logos on the side. At one time, over 350,000 addresses were without power here in the Mountain State. As of 8 PM tonight there are still over 100,000 without power.
  8. #6
    Default
    Also see a big reduction in miles. At night when the temperature drops the milage goes back to normal (45 miles per charge) but during the day if its 100 degrees, I run the fan on HI in comfort mode, and get about 30.
    Volt # 2262, picked up on Earth Day 2011. GO VOLT! LOVE THIS CAR!
  9. #7
    Join Date
    Jul 2012
    Location
    Monroe, Ohio
    Posts
    21
    Default
    WVhybrid- we finished up our storm repairs last Monday (Duke Energy), we had crews from all over helping us. KCPand L was one of them in my staging area . So those boys have been away from home repairing storms since last Friday the 29th. My personal best was 18 days in Louisiana when I was still working as a lineman, many contract companies may work 6 months at a time out of town. They should be able to put a hefty down payment on a new Volt when they get home.
    Quote Originally Posted by WVhybrid View Post
  10. #8
    Join Date
    Sep 2009
    Location
    Oswego, IL
    Posts
    126
    Default
    Yesterday with the temps above 100, I dropped down to about 38 miles. I really impressed how effortlessly the Volt takes the high temps and a/c. My last car, you could feel it stress the engine.
    MY2012 VIN #C-3879 - Hidden Content
  11. #9
    Join Date
    Mar 2012
    Location
    Virginia
    Posts
    2
    Default
    I get far better mileage than I have seen reported. On Ev mode, I can get 57 miles, and in gasoline mode 49 mpg at 65 mph on the (rather hilly) Interstate. I am a smooth driver, and the 57 miles in EV mode was at speeds less than 60 mph.
  12. Advertisement
  13. #10
    Join Date
    Mar 2012
    Location
    Southern Illinois
    Posts
    5,592
    Default
    I've needed to run errands over the long holiday in triple digit temps and yes my battery mileage has dropped from a daily average of 43 miles to 35. Granted when I say triple digit temp's I'm talking about temps in the 105 to 110 and having to park the Volt outside in the sun vs garaged between errands as is usually the case with my life style, has taken a big chuck out of my all electric range.
    Understand our average temps this time of year in St Louis is about 94 degrees and we've just had 8 straight days of TRIPLE DIGIT temps so this is most likely worst case for many folks.
    Last evenin I went out to the garage to check the garage doors and the Volts TMS was running. The temp inside my garage was 98 degrees. That's how far the heat has permeated into our house and tha was after sunset last night.
    Tom aka Accidental Electronaut
    USAF Retired
    My garage
    2017 GMC Acadia Denali
    2017 Volt Premier
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. A/C system heat pump option? with element as back heat?
    By Moreboost in forum Suggestions for GM - Chevy Volt
    Last Post: 04-12-2014, 04:50 PM
  2. Volt on racetrack? Minimum range? Heat problems?
    By cnicholson in forum Generation 1 Volt (2011-2015)
    Last Post: 06-25-2012, 11:07 PM
  3. ??? Heat adding HEAT while the AC is on
    By BAZINGA in forum Mechanical Systems - Chevy Volt
    Last Post: 05-07-2012, 12:07 PM
  4. Departed with 42km EV range, drove 25km, arrived with 38km EV range. Great....not!
    By maestro77 in forum Chevy Volt Engineering and Design
    Last Post: 01-18-2012, 05:07 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
