An $80 lesson for free: fix-a-flat and TPMS sensors don't mix
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: An $80 lesson for free: fix-a-flat and TPMS sensors don't mix
  1. #1
    Default An $80 lesson for free: fix-a-flat and TPMS sensors don't mix
    One of my tires ate a large sharp piece of steel and promptly deflated. I was in a parking garage at the time and the flatbed couldn't get in to get me, so I tried using the fix-a-flat inflator to get it pumped up enough to drive out, to no avail. I ended up slowly crawling out on the deflated tire, about 60 yards.
    Given that you only get fix-a-flat for a 'spare tire', a warning that actually using it would damage or destroy that wheel's TPMS sensor would be nice.
  2. #2
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,451
    Default
    Sorry to hear that. You may also need a new tire. "Driving on a flat tire will cause permanent damage to the tire. Re-inflating a tire after it has been driven on while severely underinflated or flat may cause a blowout and a serious crash."
    I think avoiding the goo if at all possible is the best choice. If the hole is small enough to be fixed by the goo, it's likely small enough to be fixed by a tire plug kit you can get at Walmart for $5. If it's larger, then neither will work and the spare in my garage would be my next choice. If I'm out of town, I'd use the OnStar roadside assistance.
    I keep a $10 junkyard donut spare in my garage just in case we get a flat locally one of us can drive it out to the other, together with the $10 scissors jack also from the junk yard.
    How large was your large sharp piece of metal? The owners manual says, "The tire sealant and compressor can be used to temporarily seal punctures up to 6 mm (1⁄4 in) in the tread area of the tire." Larger than that and the goo is useless.
    Why do you say the fix a flat goo and TPMS don't mix? It seems from what I can find that tire shops hate cleaning it up, but the TPMS is a sealed unit and unaffected.
    "In the demo the contents of the aerosol can turns into foam and then, after about two hours, returns to a liquid. They state that in either condition it cannot hurt the tire or the TPMS sensor and does not create false readings. They do admit that there will be some liquid remaining in the tire which will have to be cleaned out.
    Chat traffic about fix-a-flat’s compatibility with TPMS systems is a mixed bag. Some entries indicate that it is not a problem if the sensor is cleaned properly, while others cite owner’s manuals that specifically recommend against using “tire sealant products”. Some of the problem may be aggressive sales tactics by service facilities, which are using evidence of fix-a-flat as an excuse to sell a sensor, but the owners’ manual may be a good place to start before you buy that can for use in an emergency.
    The SOPUS product (Fix-A-Flat) does prominently display in all of its advertising and on the can itself “Tire Sensor Safe”.
    http://www.thecarconnection.com/news...e-over-its-use
    http://forums.corvetteforum.com/c5-t...ix-a-flat.html
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 140 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  3. #3
    Default
    Mine was much bigger than that, I was just hoping that it would inflate the tire enough to avoid running on the rim, but luckily the bead held long enough to get out of the parking garage.
    Still, at least the trailering was covered, and it didn't happen at high speed or out in the middle of nowhere, so there's that.
  4.
    Advertisement
  5. #4
    Join Date
    Feb 2012
    Location
    Wesley Chapel FL
    Posts
    247
    Default
    I'm sorry to hear the flatbed could not get to you, luckily you did not have to drive too far.
    Mike McGinnis
    Best single charge range: 64 miles
  6. #5
    Join Date
    Apr 2011
    Location
    Livonia MI
    Posts
    771
    Default
    Quote Originally Posted by Mathew Hennessy View Post
    To clarify, did you use the sealer integral with the inflater, or did you use an aftermarket product called "Fix-a-Flat"?
  7. #6
    Join Date
    Mar 2012
    Location
    Illinois
    Posts
    1,657
    Default
    I hope by the time I need new tires there are some run-flat options for Volt owners. At our age my wife and I really don't want to have to deal with attempting to fix a flat on the side of the road.
    I'll gladly take a mile or two hit on my all electric range for the safety/security of run-flats.
    Tom
    USAF Retired
    2012 Volt
    Best EV Range 50.x miles (more than once)
  8. #7
    Join Date
    May 2011
    Location
    Louisville, CO
    Posts
    89
    Default
    I'm still in the "research stage", but hope to be ordering a 2013 soon. I'm surprised to hear that it doesn't come with a "donut spare"; does anyone know if there's any reason that would not work with a Volt (other than taking up space and adding a bit of weight)? Does the Volt include a jack, so changing out a tire is even an option (assuming you actually have access to a spare)? I guess I'm having a hard time shaking the old school feeling that every car should carry a spare tire!
  9. #8
    Join Date
    May 2012
    Location
    Tennessee
    Posts
    44
    Default
    I understand the unusual circumstances of being in a garage where a flatbed can't get to you, but I have no intentions of fixing a flat on the side of the road. Having never had OnStar before, have other owners had bad experiences when calling them for flats?
    Slickbrave
    Lebanon, TN
    2012 White Volt/ Black Leather, Nav, Bose
    C3624
  10. #9
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,451
    Default
    Quote Originally Posted by swlee View Post
    Many new cars do not have spares (or jacks). Volt is one of them. But it does come with three years free roadside assistance via OnStar. So if you need, they will have a flatbed come and the car will be taken to the nearest dealer for repair (the repair is not free). I'd rather just put on a spare and ride on that while the tire is repaired (anywhere), or if the tire's shot, order a new tire from TireRack and have it installed. Meanwhile, I can keep driving the Volt. That's why I spent $20 on a spare and jack. But I don't keep them in the car.
    B3320
    VOLT TIPS & SECRETS
  11.
    Advertisement
  12. #10
    Join Date
    Jun 2011
    Location
    Westborough, MA B-2689
    Posts
    773
    Default
    That should be covered under warranty. I cannot imagine that if you use the car properly and it becomes damaged, that the warranty would not cover it.
    If, say, it got bent when you drove when it was flat, they could try to attribute that to you. But if simply using the "goo" as directed damages/destroys part of the car, that should be covered by the warranty.
    B-2689
    Personal Best Charge: 57.2 miles
    Best Day: 71.3 miles, no gas (49.9 on full charge, 21.4 on ~4 hours @120V)
    Over 4 billion pieces of data collected on the Volt OBD2 port
Similar Threads
  1. Resetting the TPMS after tire rotation
    By Marc Lee in forum Volt Ownership Forum
    Last Post: 03-02-2013, 10:43 PM
  2. TPMS Sensor Installation Instructions Needed
    By FrankIII in forum Volt Ownership Forum
    Last Post: 06-23-2012, 10:45 PM
  3. TPMS Pairing Tools
    Last Post: 06-16-2012, 03:15 PM
  4. Here's the lesson Mr. Romney: Don't bet against America
    By mustardman in forum Politics, Finance, and Environment
    Last Post: 02-17-2012, 02:28 PM
  5. Any implications using rims/tires not equipped with TPMS sensors?
    By maestro77 in forum Chevy Volt News and Events
    Last Post: 10-04-2011, 10:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
