3-Speed Transmission Gives a 15% EV Range Improvement
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: 3-Speed Transmission Gives a 15% EV Range Improvement
  1. #1
    Join Date
    Nov 2011
    Location
    Deerfield Beach, Florida
    Posts
    94
    Default 3-Speed Transmission Gives a 15% EV Range Improvement
    Doesn't the Volt have a single-speed transmission? Switching to a three-speed transmission could add 5 miles of electric range, and allow for weight reduction thus potentially adding EV miles!
    More here: http://www.gizmag.com/antonov-3-spee...sion-ev/19088/
  2. #2
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,983
    Default
    Quote Originally Posted by Powered7 View Post
    The Volt has a continuously variable transmission. CVT. This article does not apply to a Volt.
  3. #3
    Join Date
    Jul 2009
    Location
    Colorado Springs, Colorado
    Posts
    2,861
    Default
    Volt has continuously variable transmission using a epicyclic gearing setup and two electric motors.
    The article is more about direct-drive EV's like the leaf. The tradeoff there is complexity/reliability vs range.
  4.
    Advertisement
  5. #4
    Join Date
    Mar 2012
    Location
    Kansas City
    Posts
    256
    Default
    I could still see a multi-gear transmission improving efficiency and performance slightly, but I don't think it would be worth the added complexity on the Volt.
  6. #5
    Join Date
    Dec 2010
    Location
    Atlanta,GA
    Posts
    219
    Default
    Quote Originally Posted by Skotty View Post
    The Volt's continuously variable transmission has an infinite number of gears. Is that enough for you?
  7. #6
    Join Date
    Nov 2011
    Location
    Posts
    94
    Default
    That makes sense to me, thanks!
  8. #7
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,662
    Default
    Tesla tried to make a two gear solution work on the roadster - tried hard for a few years. They couldn't find one that could handle the torque, shift smoothly and reliably, and not add a bunch of weight. They eventually came up with a strategy to boost the current through the motor to buy back their low speed performance and went with a single speed transmission instead.
    The linked article has a 2.2:1 gear spread from highest to lowest - from which they are claiming a 15% improvement in performance. GM says they get "1-2 miles of electric range" or "2-4%" depending on the source from allowing the CVT to drop motor RPMs by a similar amounts by using the second motor. You will note that the Volt has a noticeably better highway MPGe compared to other EVs with similar city MPGe.
    So I'm somewhat skeptical of both the promised savings and the practicality of making such a trasmission without large weight/reliability impacts.
    Walter
    Volt FAQ
  9. #8
    Join Date
    Jul 2012
    Location
    Indore M.P.
    Posts
    2
    Default
    3-Speed Transmission Gives a 15% EV Range Improvement it is correct but for some specific condition only while in rest all conditions it is not so because switching transistors is cause of low range and short circuit.
  10. #9
    Join Date
    Jul 2009
    Location
    Posts
    2,861
    Default
    Quote Originally Posted by virkambhatt View Post
    Hmm three strange post by this new member.. guess they want the link to their site/sales not really a volt person.
  11.
    Advertisement
  12. #10
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,662
    Default
    Quote Originally Posted by tboult View Post
    We've got another one who always posts something tangentially related to the topic lately - makes me think it's a smart spambot, but I'm not 100% certain:
    http://gm-volt.com/forum/search.php?searchid=1374253
    Walter
    Volt FAQ
Similar Threads
  1. GM should investigate a 5-speed transmission ...
    By Jason M. Hendler in forum Suggestions for GM
    Last Post: 01-19-2013, 10:21 PM
  2. Replies: 15
    Last Post: 06-12-2012, 12:27 PM
  3. Best highway EV range doing the speed limit
    By RoRo in forum Volt Ownership Forum
    Last Post: 05-17-2012, 10:43 AM
  4. Optimium speed for range (The Goldilocks Zone)
    By pdt in forum Engineering and Design
    Last Post: 01-15-2012, 12:03 AM
  5. Pininfarina B0 Electric Car: 153 Mile Range, 80 MPH Top Speed.
    By JoeReal in forum Electric Car Competitors
    Last Post: 10-13-2008, 04:14 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
