Which 2012 would you buy and why? Last 5 vin #'s 21204 vs 26129?
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 28
Thread: Which 2012 would you buy and why? Last 5 vin #'s 21204 vs 26129?
  1. #1
    Join Date
    Feb 2012
    Location
    Niagara
    Posts
    57
    Default Which 2012 would you buy and why? Last 5 vin #'s 21204 vs 26129?
    I am assuming higher Vin made later then earlier, negotiated similar deals on both cars, same colors, both base cars with little options. Question is for a couple hundred bucks more is higher Vin worth it? I have heard that recently built cars may have 2013 cars battery chemistry and therefore increased ev range? Any other advantages ? Thoughts? Thanks
  2. #2
    Join Date
    Jun 2011
    Location
    Westborough, MA B-2689
    Posts
    773
    Default
    Quote Originally Posted by Deep River View Post
    I would seriously doubt that the 2012s would get the 2013 batteries (for example, the software would likely have to be different as well, and the 2012 service manual would need to be updated). Even if it might, is it worth a gamble of a couple hundred bucks to maybe get something and maybe not (and would you even know)?
    From a resale perspective, it's unlikely that anyone buying the car used in the future would pay more based on the VIN. But for a new car, knowing that it had likely spent less time sitting outside on a dealer's lot (or on a train or whatever), it might be worthwhile. I'm guessing perhaps 2-3 months time difference between the two cars, as far as when they were built.
    B-2689
    Personal Best Charge: 57.2 miles
    Best Day: 71.3 miles, no gas (49.9 on full charge, 21.4 on ~4 hours @120V)
    Over 4 billion pieces of data collected on the Volt OBD2 port
  3. #3
    Join Date
    Jul 2009
    Location
    rive-nord de Montréal, Québec
    Posts
    196
    Default
    If that matter to you, you can check if these ones are late MY2012 care with or without, the ''Engine Assisted Heating / Plugged-in" parameters as seen here.
    About the increased EV range (and Hold mode), you'll have to wait for the MY2013
    Late 2012 Volt built in may, White Diamond, light neutral leather, polished wheels, rear camera, Bose & MyLink
  4.
    Advertisement
  5. #4
    Join Date
    Oct 2011
    Location
    Spokane, WA
    Posts
    73
    Default
    You could go test drive the newer one and deplete the battery. Check the power meter to see if you get 10.5 kWh or not. If you hot rod it with the HVAC full on maybe you can get it done in 30 minutes! I plan to pick up my 2012 Thursday and will get to check this on the 55 mile ride home.
  6. #5
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,291
    Default
    I believe someone reported their 2012 MY car didn't kill the center console when the radio was turned off. I'd look at this. That would be worth a couple of hundred bucks.
  7. #6
    Join Date
    Apr 2011
    Location
    Livonia MI
    Posts
    771
    Default
    Quote Originally Posted by DonC View Post
    The difference between the 2 cars would be worth $0 for me. Cars aren't like milk or bread (unless the car has been sitting on the dealer's lot for many, many months). Personally, I can't understand the fixation about turning the radio off (although I mute mine as occasionally necessary).
  8. #7
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,664
    Default
    IF there isn't a difference in options or deal that you prefer, I'd take the later one. There are a couple changes that GM rolled in incrementally which the newer car is more likely to have. If there's a difference in price, or if the earlier car has an option you like better, I'd take that. Either way, it's an awesome car, and getting around to buying one is more important than debating over which one, IMO...
    Walter
    Volt FAQ
  9. #8
    Join Date
    Feb 2012
    Location
    Guelph, Ontario
    Posts
    40
    Default
    Whats this 10.5kw number all about...my 2012 got 10.6 the other day when we ran it right out of juice.
    Luckily it switched over about 200m from my front door so no big deal.
    Volt# C20417 Silver
  10. #9
    Join Date
    Jun 2011
    Location
    Posts
    773
    Default
    Quote Originally Posted by CMMPro View Post
    The 2012's (and beyond) show you the amount of electricity the car used. In your case, you used 10.6kWh. The number can fluctuate slightly, as the initial charge and the charge at which it turns on the gas engine vary a bit.
    B-2689
  11.
    Advertisement
  12. #10
    Join Date
    Jun 2012
    Location
    Seattle, WA
    Posts
    57
    Default
    I believe that the newer MY2012 Volts likely do have the new battery chemistry. I just depleted my battery for the first time and reached 10.9kWh Used. From what I have seen posted from others, this is a bit more usable charge than on the MY2011 or earlier MY2012 Volts. Also, the newer VIN will likely have newer software installed. For example, on recent Volts, it is now possible to turn off the radio and still display the Home Screen, Energy and Climate controls. My VIN is #C-27825. I'd go with VIN #C-26129 if both Volts are otherwise identical.
    Fedway
    Seattle, WA
    2012 Cyber Gray Volt #C-27825
    Voltstats: High Voltage 2012-27825
    Manufactured: 6/5/12
    Delivered: 6/29/12
Similar Threads
  1. Replies: 4
    Last Post: 07-03-2012, 11:06 AM
  2. 2012 Volt Service Manual Not Available Until 7/1/2012 :(
    By BlackVolt in forum Engineering and Design
    Last Post: 03-25-2012, 09:10 AM
  3. 2012 1/2 Model - any differences vs. inital 2012 model
    By tommytuna in forum Volt Ownership Forum
    Last Post: 11-26-2011, 10:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
