My #1 suggestion: instantaneous and/or averaged kW usage
Grab our Forum Feed
+ Reply to Thread
Results 1 to 8 of 8
Thread: My #1 suggestion: instantaneous and/or averaged kW usage
  1. #1
    Join Date
    Jun 2012
    Location
    Miramar, Florida USA
    Posts
    7
    Default My #1 suggestion: instantaneous and/or averaged kW usage
    By now I'm used to having an "avg mpg / current mpg" display in some of the cars I've driven.
    I'd really like the same for the Volt (and as this is a software change, I'd like it for my 2012 Volt, thank you!).
    As it stands, the fuzzy green and blue ball and other such displays are all frustratingly vague. I'd like something more instantaneous and more specific (just tell me the watts being used for gosh sake!)
    To be specific, one one of the displays I'd like to see the current power consumption (averaged over no more than a few seconds) and an averaged power consumption (from a time a user resets the counter or from the last charge, or trip, but more like hours and days than seconds).
    I like the idea of tying in the consumption to two trip counters.
    What should the unit be? watts / mile? miles per kilowatt? That's not so important to me as long as one of the two numbers updates frequently enough to help me tweak my driving for the maximum range.
  2. #2
    Join Date
    Jun 2012
    Location
    Florida
    Posts
    109
    Default
    Agreed. I'd like to see a real efficiency displayed somewhere. The Volt displays "mpg" 4 different places: Trip A, trip B, and two in the energy efficiency display. But none tell me how efficiently I am driving because all 4 combine gas and electric miles and thus only represent the % of time I spend using electric vs gas. Why not display mpg in CS mode and mpkwh in CD mode? The information is right there in the energy efficiency display, why do I have to mentally divide miles traveled by kwh used all the time while a useless "250+ MPG" is blaring at me in giant font?
  3. #3
    Join Date
    Jun 2012
    Location
    Plano, TX
    Posts
    222
    Default
    The Leaf shows Miles/kWh instantaneously and along with the trip computer resets. There is even a separate reset on the center console you can do to track history at whatever intervals you choose.
    Very useful and a glaring oversight to me who is used to monitoring that as my primary "mileage" indicator while driving the Leaf.
    I hardly plan to use gas on the Volt so putting everything in terms of MPG is nonsense.
    Steve Martin
    2012 Blue Topaz Metallic Volt delivered 7/31/12 charged with Ecotality Project Blink EVSE
    2012 White Diamond Tricoat Volt delivered 6/29/12 charge with Ecotality Project Blink EVSE
    2012 Cayenne Red Leaf delivered 3/29/12 charge with eVgo/Aerovironment EVSE
    6kW Solar array
  4.
    Advertisement
  5. #4
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,509
    Default
    Well the masses who are the genuine target for this car do not know/care about those. I think GM was genius in making this car so "normal". That is the way to get the transition to work IMHO. This is not a car just for the "early adopters" tech geeks.
    Still it would be novel to have that information in some lower level areas that could be accessed. They have the kWh used on 2012+ so that is pretty decent even tho you have to do a little math to get per mile numbers. MyVolt.com has the rough kWh for us 2011 drivers.
  6. #5
    Join Date
    Jul 2012
    Location
    California
    Posts
    4
    Default
    For sure, marketing Miles/kWh is not a great idea but once you DRIVE one and "get it" - it's one of the first things I wanted to start tracking - but other than for "This Drive" - you don't see it anyway. I also drive mostly on Electric so while it's cool to impress my friends with the 250+ MPG - I really want to know how much kWh I'm using. Should be an easy add to the current Energy screen.
  7. #6
    Join Date
    Mar 2012
    Location
    Arlington, VA
    Posts
    978
    Default
    The monthly OnStar diagnostic report contains the kWh/100 (at least the only one I have received so far). I don't understand why MyVolt.com doesn't show this instead of the "--". The charging history contains the kWh used for each charging session and the system knows the total miles driven.
    Seems like a simple coding exercise to me.
    Dennis
    7.1kW grid tied solar/solar hot water
    2012 Volt- Diamond White, C22542 (fully loaded- MyLink-No Nav)
    2008 Prius
    Blink Level 2 EVSE
    VoltStats-Rocky Volt
    First year stats-- 13,100 miles, 100% EV, 22,500 mpg, 92.63 mpge
  8. #7
    Join Date
    Jun 2012
    Location
    Plano, TX
    Posts
    222
    Default
    How brain dead is it to report kWh/100 miles anyway. You pay for gallons of gas, you like to see how many miles per gallon you get. You pay for kWh of energy, it would be nice to see how many miles you get per kWh.
    You don't pay for 100 miles of driving and then try to see how few kWh you can use for it. Backward thinking, that I can't comprehend.
    I still have -- for every single statistic after one week of ownership (other than tire pressures from the first day and current battery charge). Still no idea if that is normal, everyone on the forum just says the data sucks anyway, and OnStar people seem to have no clue that they even have a web site. Very frustrating.
    Steve Martin
    6kW Solar array
  9. #8
    Join Date
    May 2012
    Location
    Minnesota
    Posts
    188
    Default
    Just received my first MyVolt stats email. Elect miles and kWh are way off from my figures and I keep a daily log of miles and kWh. Called onstar and got NO good answers. My records for month of June 857 miles elect and theirs 549. kWh mine 187 theirs 154. The guy I talked to said their figures would never match mine. I told him don't send out reports with bad info. He said thats the way it is and I should not pay any attention to the miles or energy items on the report. Thats bullsh t. My Volt adivsor promised to get back to me this week and see what is going on.
Similar Threads
  1. Battery Usage
    By Dekka37 in forum Battery issues/TMS
    Last Post: 06-28-2012, 03:16 PM
  2. Air Conditioning and battery usage
    By agggilli in forum Newcomers
    Last Post: 01-24-2012, 12:58 AM
  3. Pre-conditioning Energy Usage
    By ClarksonCote in forum Volt Ownership Forum
    Last Post: 11-24-2011, 03:21 PM
  4. Tracking of KWh usage
    By evportlandme in forum Volt Ownership Forum
    Last Post: 08-31-2011, 09:55 PM
  5. Odomter vs. Energy Usage
    By ammPilot in forum Volt Ownership Forum
    Last Post: 03-16-2011, 04:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
