Volt back at the dealer again
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Volt back at the dealer again
  1. #1
    Join Date
    Jun 2012
    Location
    Royal Oak, MI
    Posts
    36
    Default Volt back at the dealer again
    Well only had the car two weeks now and it's been in the service department each Friday since. Keep getting a CEL that points to low pressure in the AC system. They can't seem to trace down where it's leaking even after using dye in the refrigerant. Starting to get a little bit frustrated I can't enjoy my car right now.
    Off to pickup a loaner for the weekend...
  2. #2
    Join Date
    Mar 2008
    Posts
    1,170
    Default
    Wow. I didnt know they monitored the AC pressure. I guess we'll all know when the AC is going out. This thing has a ridiculous amounts of sensors (to go bad and need replacing)
    2012 Chevy Volt
    Please visit my blog at voltowner.blogspot.com
    Twitter: @voltdriver
  3. #3
    Join Date
    Dec 2011
    Location
    Los Angeles
    Posts
    254
    Default
    If the Volt's A/C system wasn't working properly then the battery's TMS would also be down, leading to potentially devastating consequences. No surprise that this defect popped the CEL.
    -Drew
  4.
    Advertisement
  5. #4
    Join Date
    Jan 2011
    Location
    SE PA
    Posts
    3,500
    Default
    How does that AC influence and/or work with the battery TMS? TMS uses coolant that heats up and goes through its own radiator.
  6. #5
    Join Date
    Dec 2011
    Location
    Los Angeles
    Posts
    254
    Default
    If I'm not mistaken there's a chiller powered by the a/c that cools the pack. It's integrated in such a manner that sometimes the car sends chilled air to the cabin when the TMS is active even if the driver hasn't selected a/c for the cabin climate control.
    -Drew
  7. #6
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,292
    Default
    The good thing about the sensors is that usually they fail immediately or they don't fail for a long time. But I agree with CarZin that the car seems to have more than the average number of sensors.
    Quote Originally Posted by mtndrew1 View Post
    Drew, I think you're right that there is some connection between the cabin evaporator and the battery chiller. The AC condensor is routed through both the battery chiller and the cabin evaporator. If the Condensor it turned on for the battery chiller the cabin evaporator will take advantage of that. http://gm-volt.com/2010/12/09/the-ch...ems-explained/ But the evaporator is not directly connected to the chiller.
    I'd agree with bonaire that if the cabin evaporator went down it shouldn't effect the battery chiller and the TMS. On the other hand if the AC condensor was on the fritz then this would effect the TMS.
  8. #7
    Join Date
    Jan 2011
    Location
    SE PA
    Posts
    3,500
    Default
    A123 EXT please (ie. cells which apparently won't need TMS and would make the pack cooling a lot easier and fewer sensors, etc.) Currently, if it is 90*F ambient outside, the Volt TMS still wants to get the pack down to 70 or so *F. This is the good thing about the TMS - it keeps the LG Chem cells (which need a TMS for longevity) in the right temperature range in the hotter weather.
    Did you guys see the specs on the Honda Fit EV? Those are entirely different Lithium cells (2.4V and 10C charging - and air-cooling). Batteries are going to go through a lot of changes and I think one of the major goals is to get EVs out there without TMS. Those with leases may be in a good position to get into them in 2015+ when the next gen Volts (and others) start to come online.
  9. #8
    Join Date
    Dec 2011
    Location
    NW Ohio
    Posts
    347
    Default
    Quote Originally Posted by DonC View Post
    The condenser is in front of the radiator, its where the freon is cooled after its compressed. Heat is radiated from the condenser to the outside air.
    The evaporators are fed compressed freon thru the expansion valve, and is where the freon evaporates, resulting in cooling.
    There are two evaporators, one for the cabin air, one for the battery coolant loop. The chiller is an evaporator.
    Loss of freon pressure would cause a lack of cooling in both the cabin and the battery system.
  10. #9
    Join Date
    Jun 2012
    Location
    Royal Oak, MI
    Posts
    36
    Default
    From what I could gather it sounds like this system is separate from the Battery TMS. I went to pickup my car today and they said after using the dye in the refrigerant they found a light leak on one of the seals near the AC compressor, this was after the called the Volt Technical Team. Unfortunately the service manager really didn't know for sure if this would solve the problem, gave it a 50/50 chance with his confidence level.
    Now the kicker, as I get in to my Volt and power it on I notice the red battery light on. I called over the service adviser right away and turned it off and back on and bam comes up the service charging system notice. My Volt now gets a longer stay at the dealership. I'm really trying to be understanding with the newness of the car and its technology but after only having my car in my possession thirteen days out of the nineteen I've owned it I'm fast getting frustrated.
    So wait and see at this point, I won't get it back till next Wednesday since I'll be out of town at this point.
  11.
    Advertisement
  12. #10
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,669
    Default
    Quote Originally Posted by mikeyd810 View Post
    It is, and it isn't. The battery TMS is a dexcool coolant loop, with it's own radiator and pump. At the front of the battery enclosure it has a 1.8kW electric heater for when ambient temperatures are to low - and there's also a chiller (an evaporator that transfers to water instead of air) that's hooked into the same A/C loop as cabin cooling, which is what the car uses to hold the battery below ambient when ambient temperatures are too hot.
    Loss of refrigerant or a compressor failure of the A/C system would prevent the TMS from keeping the battery lower than ambient temperatures in hot weather - and thus compromise the battery management strategy and potentially lead to accelerated degradation similar to what Leafs are experiencing in PHX and Texas. So it's related and I'm not at all surprised that GM put sensors in to monitor it.
    Walter
    Volt FAQ
Similar Threads
  1. I just got back from the dealer with a loner car due to window problems
    By silvercorvette in forum Volt Ownership Forum
    Last Post: 04-08-2012, 09:50 PM
  2. Our Volt is back
    By bobhodgen in forum Volt Ownership Forum
    Last Post: 03-28-2012, 11:39 PM
  3. Distance between the front seat back and the rest seat back?
    By jomo25 in forum Volt Ownership Forum
    Last Post: 07-29-2011, 07:47 PM
  4. How far from a Volt dealer can you be?
    By rphooper in forum General Motors and General Automotive Topics
    Last Post: 03-30-2010, 10:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
