Whats going on here?
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Whats going on here?
  1. #1
    Join Date
    Jun 2012
    Location
    San Jose CA
    Posts
    27
    Default Whats going on here?
    Can someone explain how much kWh capacity I should have remaining? I am guessing 3.3 because I assume that the 16 kWh battery only charges 80% to 12.8. Am I understanding this correctly?
    --Patrick
  2. #2
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    2,691
    Default
    Generally you get about 10-10.4 kWh out of the battery. It charges to 80% and stops at about 20% discharged. Look like a nice trip for 9.5kWh and 45 miles.
    Diamond White #B2140 ecosister plate=SLRRYDER
    Crystal Red #C8885, Red-Rider plate=NO2OPEC
    No gas purchased, fully charged off Solar, OK so I bought some gas to go to Vegas!
    DRIVING for FREE! NO OPEC FEE!
    My TED 5000 power monitoring
  3. #3
    Join Date
    Nov 2010
    Location
    Norwood, MA
    Posts
    155
    Default
    you will enter charge sustaining mode when the KWh used gets around 10.0 KWh. There are some variations (9.8 to 10.2) that I've never seen fully explained. Some think it has to do with batter management use other say its how much regen you get and others say its the temperature
    Also - I *think* that if you engage mountain mode the extra KWh will be added to the total - once you hit 0 EV miles left the EV total seems to stop...
    2012 Volt owner on 2/28/12
    as of 1/28/13: 8,158 EV miles - 11,090 total miles
  4.
    Advertisement
  5. #4
    Join Date
    Jun 2012
    Location
    San Jose CA
    Posts
    27
    Default
    So from a pure electric standpoint, I can use 60% of my total capacity without the engine coming on (roughly what I used - 9.5). 20% buffer off the top and 20% cushion on the bottom end. Am I understanding that correctly?
    @ahaer
    I am not sure I understand what you are saying about mountain mode. Can you explain further?
    --Patrick
  6. #5
    Join Date
    Jul 2009
    Location
    Kitchener, Ontario, Canada
    Posts
    846
    Default
    Quote Originally Posted by pchapman View Post
    @ahaer
    Yup that is for the most part correct. The Volt uses between 60 to 65% of the battery capacity.
    7 August 2012 - 2013 Volt - D3079 - Blue Topaz Metallic - Pebble Beige Cloth - Comfort Package and Safety Package 1 came home.
    https://www.voltstats.net/Stats/Details/1667
  7. #6
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    2,691
    Default
    @ahaer
    I think he is saying that if engaged before you hit 4 remaining bars you in effect get a HOLD mode, leaving the last bars for when you are nearing your destination, above 4 bars it is pretty much running in CS mode.
  8. #7
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,653
    Default
    @ahaer
    Near enough. The battery actually stops charging at ~86% of theoretical maximum, and aside from mountain or hold mode, the engine comes on at ~22%, with the car using the ~1kWh below that to the 15% hard lower limit as a buffer for strong acceleration and mountain climbing.
    (Mountain mode works just like normal mode except it keeps another 3-3.5 kWh in the buffer. If you turn it on above that SoC, that's the only thing different about it. Turned on when the battery is almost dead, it causes the engine turn run when it would normally be shut off (deceleration/regen, low speeds and stopped,) and causes the far to run the engine harder to rebuild the battery buffer. Some people think (I originally thought) they can manipulate this to make the car run the engine more efficiently than it otherwise would. Hold mode sets the target SoC to whatever the current charge is, turning the engine on immediately and keeping the rest of the battery charge for later use. It's particularly helpful in European cities that don't allow ICE cars into the city center Or charge fees for them to enter, but it can be useful in other ways too.)
    Walter
    Volt FAQ
  9. #8
    Join Date
    Jun 2012
    Location
    San Jose CA
    Posts
    27
    Default
    Quote Originally Posted by saghost View Post
    Ok, so if I engage Mountain Mode with approximately 25% (or less) capacity, the engine will turn on immediately. If turn on Mountain mode at 50%, then the engine will turn on at about 25%. The 3-3.5 raises the engine the low point at which the engine will turn on, saving an extra bit of battery for predicted heavy use (i.e., climbing a mountain). Ok, I think I got it! I think I got a grip on hold mode. Thanks saghost!
    --Patrick
  10. #9
    Join Date
    Dec 2010
    Location
    Nashville, TN
    Posts
    279
    Default
    Careful, Hold mode is different in that it simply maintains the current state of charge, whatever level it happens to be.
    It's only available on European Volts and Amperas and new to the US 2013 MY
    Black Volt C-4730
  11.
    Advertisement
  12. #10
    Join Date
    Jun 2012
    Location
    San Jose CA
    Posts
    27
    Default
    Quote Originally Posted by yoyodyn View Post
    Hold sounds pretty self explanatory. The fact its only on 2013s in the US explains why I don't see it in my available modes. Just got my 2012 Volt couple days ago. Thought it might be some buried menu option. I wont spend any time looking for it now! Thanks!
    --Patrick
Similar Threads
  1. Whats the best state to register your car (volt) in?
    By davedave2008 in forum Buying/Leasing
    Last Post: 07-01-2012, 07:42 AM
  2. charging stations, whats not to get here?
    By Brittt1 in forum Volt Ownership Forum
    Last Post: 03-06-2012, 11:00 AM
  3. Whats it like owning a Volt in a red state?
    By pauldon in forum Politics, Finance, and Environment
    Last Post: 12-27-2011, 10:28 PM
  4. whats my chance
    By keegs54 in forum Volt Ownership Forum
    Last Post: 09-20-2010, 01:25 PM
  5. Whats up in Bakersfield?
    By Khadgars in forum Politics, Finance, and Environment
    Last Post: 09-03-2009, 10:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
