B-2689
Personal Best Charge: 57.2 miles
Best Day: 71.3 miles, no gas (49.9 on full charge, 21.4 on ~4 hours @120V)
Over 4 billion pieces of data collected on the Volt OBD2 port
Speaking of cooling, you can use the 240v charge station to precondition the Volt in the winter with heat, and in the summer with cool without drawing from the battery. That's the main reason I got the 240v Voltec. The faster charging is nice, but not a huge factor for me as the car charges while I sleep either way.
B3320
Best All Electric Miles: 54.2
Lifetime: 30,821 miles, 140 MPG, Remaining Oil Life 100%
Typical Commute: 57-67 miles
30 day Stats: 1100 miles, 201 MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
VOLT TIPS & SECRETS
I only used 10kwh for a couple of months, then it dropped to 9.7 or so where it has stayed, temperature be derned...
Volt #3967, Golden, Co.
My battery range is still 45-48 mi/ full charge
I am having the same problem. Volt ad-vizors are idiots.
I am down to 9.6 from 10.1.... I am guessing its the temperature in the dfw area. range seams unchanged and is still about 44-48 miles per charge. 5300 total miles.
