Decrease in total energy available for use
Results 1 to 10 of 15
Thread: Decrease in total energy available for use
    colorado
    3
    Default Decrease in total energy available for use
    For the first 4000 mi on my Volt the Energy Info screen would show 10.1 kwh used when the ICE came on. For the last 2 weeks it shows only 9.8 kwh when the ICE comes on. Any ideas on why this has changed?
    Colorado Springs, Colorado
    2,861
    I'd guess its the recent heat wave in CO. The car estimates many things and that depends on Temp. So it may be recognizing it needs to use some of the battery to cool the battery, so it not available to use. And when you are charging, the TMS is running to cool it so depending on when you planned for it to finish charging it may also still be cooling some of the power.
    ________________________________
    BoultVolt Red 2011 #3745. More freedom than electric.
    Personal best, 82.1 miles on one charge.
    While I'm moderator my job there is to delete spam. To be clear, in my posts I'm speaking as myself. These views are my own and don't represent this board, my university, employer,etc.
    May 2009
    Wake Forest, NC VIN:#C-8909
    2,030
    Coincidentally, today I only got 9.7 kWh before switching over. I almost always get 10 or 10.1. I did have the battery modification last week, so who knows?
    2012 Blue Topaz Volt - VIN:#C-8909 - Leather Seats Black with Dark Trim, Rear Camera
    9/15/11 Ordered, 11/18/11 Arrived (highly efficient signature zone) Volt Stats
    Mar 2010
    Central NY
    1,440
    Does that screen report power used by the TMS also? If not, you may be seeing some variation due to the summer heat and the TMS running?
    Volt Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Leaf Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Commercial Level 1 Charging Station - Low cost solution suitable for Hotels, Employers, Airports, etc.
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic - Love the blue!
    [SIZE="2"]Driving for FREE with Solar PV!
    Norwood, MA
    155
    Way to many unknowns in the dumbed down power displays on the volt. I wish they had a mode were you could some of the detailed data the car collects without spending $600 on a DashDAQ...
    2012 Volt owner on 2/28/12
    as of 1/28/13: 8,158 EV miles - 11,090 total miles
    Jan 2012
    Lakeland Florida
    1,276
    Quote Originally Posted by ahaer View Post
    Yah, then we would have a wiki page claiming were losing 4% of capacity in only 4K miles and want new battery's from GM
    GM put everything behind the curtain for a very good reason, look at the leaf discussions for proof.
    2012 Crystal Red Volt #10921 - Plug Powered #76
    SE PA
    3,500
    What really matters is the miles delivered to the wheels. Has that dropped at all? The kWh reading probably has some loss somewhere not calculated, like TMS or headlights or something insignificant. Maybe heat influences the metering of the kWh flow?
    May 2008
    Denver CO
    888
    I live in Colorado. The heat wave is definitely throwing a few strange numbers out there. When I parked my car, the electric range left was 6. After the heat of the day, over 100 degrees, I think the chemicals heated up and it read 8, and I did get 8 before the gas kicked in. Depending on how frugal I'mdriving, a full charge can read 44, sometimes 41. Lots of software helping you figure out range. The Leaf is far less reliable in the numbers count. Not sure about he Tesla. The Tesla I hope will join the family next to the Volt in January 2014.
    May 2008
    Denver CO
    888
    Default Battery Enhancement? Is that the Battery Recall item?
    They spewed coolant all through my electrical system on that one. This car is flawless until the mechanics get hold of it.
    Hampton, VA
    329
    The amount of kwh able to be drawn from the pack is also affected by how you are driving at the time. Whenever I am on the highway I get to about 9.7-9.9kwh before the engine kicks on. If I am driving on side roads at 25-35mph however it will give me 10.1-10.3 before the engine kicks in. It depends on a lot of factors including temperature, voltage, and current draw as to when the engine comes on. For me it seems the sweet spot is somewhere between 77-82 degrees. As lately on these 90+ degree days it is not wanting to give up more than 10kwh. I am still getting 48-50 miles per charge though, so I have no complaints.
    2012 Nissan Leaf SL #16790
    2012 Chevy Volt #2395
  1. Why does it take less total energy to fast charge?
    By MrEnergyCzar in forum Engineering and Design
    Last Post: 06-07-2012, 03:49 PM
  2. Looking at total costs...
    By shawnw2 in forum Volt Ownership Forum
    Last Post: 04-18-2012, 06:51 PM
  3. 426 miles total cost 23.56
    By nowelectric in forum Volt Ownership Forum
    Last Post: 04-02-2012, 11:57 PM
  4. Decrease Passing Time by a Factor of 2.5
    By larry4pyro in forum Volt Ownership Forum
    Last Post: 02-11-2012, 07:09 PM
  5. Total Cost of Ownership
    By IndianaDave in forum General Motors and General Automotive Topics
    Last Post: 09-24-2008, 11:44 AM
