Is there a way to keep my car from fully charging when plugged in?
Grab our Forum Feed
+ Reply to Thread
Results 1 to 9 of 9
Thread: Is there a way to keep my car from fully charging when plugged in?
  1. #1
    Join Date
    Apr 2012
    Location
    United States
    Posts
    6
    Default Is there a way to keep my car from fully charging when plugged in?
    I am leaving for a week and my black volt will be left sitting in the hot sun of my driveway (and it has been hot in Texas this week). From prior conversations, the consensus seemed to be that it was better to have it plugged in than to have it with a low battery. Now I wonder if there is a way to keep it at half charge and keep it plugged in so that it can use the grid to run the thermal management system but not be 100% state of charge so that the thermal management system does not have to work so hard.
    I have the car programmed to delay charge on the assumption that i will leave at 6 am everyday.
    Thanks for any thoughts
  2. #2
    Join Date
    Feb 2012
    Location
    Salt Lake City
    Posts
    239
    Default
    The thermal management system shouldn't have to work any harder for a half full battery than for a full battery. Leaving it plugged in will run the TMS and keep the battery topped off.
  3. #3
    Join Date
    Jan 2011
    Location
    SE PA
    Posts
    3,483
    Default
    I think some folks here came up with an interesting plan.
    Run the car down in Mountain Mode to low SOC in MM. This is not the lowest SOC, but what - about 35%?
    Then, compute the daily charge time to be about 15 minutes a night (setup a charging window of say 5:00am-5:15am). Then, keep it plugged in which will run the TMS even if a charge is not occuring. This could be called the "away mode". Check the "Similar Threads" below. I hope I wrote that correctly. The idea is to allow the battery to stay at a mid-level SOC while still allowing for TMS.
  4.
    Advertisement
  5. #4
    Join Date
    Oct 2009
    Location
    Connecticut
    Posts
    1,380
    Default
    It can only charge to 80% when plugged in so it shouldn't matter....
    MrEnergyCzar
    My Chevy Volt Videos: One Year Review (click here) | Sexy Volt Car Wash (click here) |
    ................................Original Test Drive (click here) | 10,000 Mile Review (click here) |
    22,000 miles on 80 gallons | 100 miles per dollar (100 MPD)
    My Social Media Sites: http://xeeme.com/MrEnergyCzar
    09/30/2011 Delivered. (8,154th Volt Produced)[/QUOTE]
  6. #5
    Join Date
    Apr 2011
    Location
    Wickenburg, AZ
    Posts
    418
    Default
    Quote Originally Posted by greenhornet View Post
    So you are worried about a week? Wow, what terrible things can happen in only a week? I think I would be more worried about having to dust the car off than any bad things that might happen to the battery.
    VIN # B0985
  7. #6
    Join Date
    Aug 2010
    Location
    Novi, MI
    Posts
    233
    Default
    I like the away mode idea, but I think that it is unnecessary in this case. A full battery is only ~80% SOC, TMS will run as needed....no problem leaving the car plugged in. This will not harm the battery....especially if it's only a week.
    2011 Volt
    #2890
  8. #7
    Join Date
    Aug 2010
    Location
    Detroit, MI
    Posts
    2,002
    Default
    @ greenhornet,
    I agree with everyone else as it would be best to leave your Volt plugged in. No harm done on the battery.
    If you have any further questions feel free to contact the Chevrolet Volt Advisor Team
    (877) 486-5846
    New Volt Advisor Hours:
    Monday - Friday 8AM to 11PM EST.
    Saturday 11AM to 8PM EST.
    Closed on Sunday.
    voltsocialmedia@gm.com
    https://twitter.com/ChevyVolt
  9. #8
    Join Date
    Jul 2010
    Location
    Bayamon, Puerto Rico
    Posts
    1,335
    Cool
    Get a good car cover and lock it on. The cover will reflect sunlight and keep the car cooler and cleaner underneath. Other than that, the Volt con be left plugged in or not, which is your decision, but it will hold up perfectly. GM has already tested that condition.
    No Volt yet
  10. #9
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,509
    Default
    Quote Originally Posted by bonaire View Post
    Here is the thread on the idea I came up with for this:
    Scheduling-method-2-keep-ur-12v-battery-charged-while-on-long-vaca
    http://gm-volt.com/forum/showthread....e-on-long-vaca
Similar Threads
  1. Replies: 18
    Last Post: 06-24-2012, 12:58 AM
  2. Replies: 4
    Last Post: 05-21-2012, 12:23 PM
  3. Replies: 9
    Last Post: 02-22-2012, 12:05 PM
  4. Not fully charging
    By gmacecsko in forum Battery issues/TMS
    Last Post: 12-15-2011, 03:09 PM
  5. Pre-heating when plugged in and time-of-use charging
    By therfman in forum Volt Ownership Forum
    Last Post: 12-04-2011, 12:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
