Canbus amber LEDs for front blinkers
Grab our Forum Feed
+ Reply to Thread
Results 1 to 5 of 5
Thread: Canbus amber LEDs for front blinkers
  1. #1
    Join Date
    Dec 2011
    Location
    Atlanta, GA
    Posts
    51
    Question Canbus amber LEDs for front blinkers
    Hi all,
    I really want to change my front blinker/parking light bulbs, but don't want to mess with installing in-line resistors to avoid hyper-blinking.
    Does anyone have experience with Canbus LEDs you've installed? Does anyone know anything about these two bulbs available on Amazon.com?
    http://www.amazon.com/Amber-CANBUS-B...+can+bus+amber
    http://www.amazon.com/Amber-Wedge-Li...+can+bus+amber
    Any advice is greatly appreciated. I'm kinda willing to try out the first set for $20, but not sure I wanna test both sets
    John
  2. #2
    Join Date
    Jul 2010
    Location
    Bayamon, Puerto Rico
    Posts
    4,257
    Thumbs up Use an electronic flasher for LED lamps
    I have replaced every incandescent lamp (except the headlamps) in my 1995 Buick Regal with LED lamps. The flasher would not flash for a turn signal, but the reason was that the original flasher uses a thermal element that depends on the total lamp current to heat up and open the contact, then after a half second of cooling, it would close, and start a new flash cycle. And if one bulb burn open, the flasher would not operate.
    My solution was to buy an electronic flasher that does not depend on the lamp current at all. It uses a small electronic timer "IC" (similar to the NE 555 for those who know) and a power transistor. So it would operate if all the original bulbs were incandescent, LED, or a mixture. The only weak point (which is not that bad) is if a bulb failed, the flasher will continue to operate, so the vehicle owner must test the turn signals often and verify that the lamps (incandescent or LED) are functional.
    The electronic flasher is sold at major auto supplies. Mine was bought at Western Auto, now known as Advanced Auto Parts.
    No Volt or Bolt EV yet!
    2009 Chevrolet Equinox 2LT
    Level 2 JuiceBox EVSE installed at 7.2 kW
    Registered EVSE at PlugShare
    Waiting for the first EV to charge!
  3. #3
    Join Date
    Mar 2010
    Location
    Hampton, VA
    Posts
    200
    Default
    From what I've seen, the Volt doesn't have a dedicated flasher for the turn/hazard signals. The Volt's BCM takes care of the flashing and is already electric, but is programmed to detect burned-out bulbs and do the quick-flashing indication. It's also used to flash the individual signals for use in setting the TPMS without using a special tool.
    Hidden Content
    2012 Silver Ice Metallic, Camera, Nav/Bose system, cloth seats
    9 Jul - Order placed (1100) / 6 Oct - Produced (3800) / 27 Oct 2011 - Picked up! (6000)
    Last fill-up: 4 Mar 2014 / Last gas used: 21 Sep 2014 (106.8 mi/2.05 gal = 52.1 MPG)
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Dec 2011
    Location
    Atlanta, GA
    Posts
    51
    Default
    Krellion,
    Right, I agree with you ... Which means you can't just replace a blinker module with a new one. Also means if I used NON error-free bulbs (non-Canbus bulbs), then I'd have to install an inline resistor ... PITA.
    That said, I may just try a pair (or two) of the Canbus bulbs i found and see what happens
    John
  7. #5
    Join Date
    Dec 2011
    Location
    Atlanta, GA
    Posts
    51
    Default
    Bumping up again since not a lot of activity.
    Still no luck finding 7444 error free bulbs.
    Anyone have experience with this: http://www.ebay.com/itm/Pair-7444NA-...870#vi-content
    Looks like an easier alternative than trying to fiddle with splicing resistors into the existing wiring harness ... considering the tiny, tiny, tiny amount of space you have to work in
    John
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Euro Tailights with Amber! GM, why can't we have this here?
    By nater in forum Suggestions for GM - Chevy Volt
    Last Post: 04-17-2015, 05:54 PM
  2. DRL LEDs
    By AZ-Volt in forum Chevy Volt Accessories and Modifications
    Last Post: 07-13-2013, 06:14 PM
  3. LEDs and HIDs - lots of info and links!
    By jcaponeg in forum Generation 1 Volt (2011-2015)
    Last Post: 01-12-2013, 11:50 PM
  4. Lighting! LEDs bulb #'s HID's on the way.
    By burgandy25 in forum Generation 1 Volt (2011-2015)
    Last Post: 04-06-2011, 02:06 AM
  5. Orange Button and Green LEDs on Standard 120V Voltec Charger
    By Slapshot28 in forum Chevy Volt Accessories and Modifications
    Last Post: 02-14-2011, 07:33 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
