Chargers On Wall or On Board?
Grab our Forum Feed
View Poll Results: How do you think chargers should be implemented?
Voters
28. You may not vote on this poll
  • Built into the cars
    23 82.14%
  • Separate from the cars
    5 17.86%
+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
Thread: Chargers On Wall or On Board?
  1. #11
    Join Date
    Mar 2012
    Location
    Kansas City
    Posts
    274
    Default
    Quote Originally Posted by Henry_FL View Post
    If the smart cords were mass produced, the cost should be in the 50 dollar range, there not so we get soaked for 500-1500 dollars for a wire, plug and the electronics of and alarm clock in complexity
    That is exactly what I am starting to think. And even then, they use inferior product like the absolute minimum gauge wire. So you end up with a $25 product that should have been a $75 dollar product that they sell to you for $500 - $1000. Total rip off, and another reason why EVs have to struggle so hard to gain any traction.
  2. #12
    Join Date
    Mar 2009
    Location
    Phoenix, AZ
    Posts
    385
    Default
    So we have concluded that the charger is in the car on the Volt.
    So what is different about the Tesla model S? Is Tesla just blowing smoke in their press release?
  3. #13
    Join Date
    Jan 2012
    Location
    Lakeland Florida
    Posts
    1,348
    Default
    I know exactly the protocol of the ESEV uses, I was keeping it simple , regardless the control signal could made with 50 cents in parts, everything else is for "safety", mind you we have gone for 100 year with extension cords that don't require these nanny features
    2012 Crystal Red Volt #10921 - Plug Powered #76
  4.
    Advertisement
  5. #14
    Join Date
    Jan 2012
    Location
    Lakeland Florida
    Posts
    1,348
    Default
    The Tesla has fast charging abilities, with extra pins and a format that's not a J1722 connector, they give the customer a smart cord that can just plug into the wall, even for 240V, all the same "pod"
    Nothing prevents that same thing for any EV or EREV ( pod that works 120/240 with user changeable wall plugs )
  6. #15
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,322
    Default
    Henry_FL is right to not make this thread cover the same ground from other threads and keep it simple.
    Some of the safety in the socket/plug is just the PIN length so one opens first and the J1722 plug is designed to be run over by the car.
    Lots of information on the open charger projects groups but remember not one of those is UL or other safety testing labs approved.
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
  7. #16
    Join Date
    Feb 2011
    Posts
    317
    Default
    Quote Originally Posted by Skotty View Post
    If/when these things are cranked out in the millions, you might be right but in the meantime, just the J1772 connector with 20' of wire costs $200 (wholesale from China seems to be 60-150 depending on how many 1000s you buy) and the bare parts for the board work out to about $135. http://code.google.com/p/open-evse/
    Mike
    Volt #777
  8. #17
    Join Date
    Jun 2012
    Location
    Northern VA
    Posts
    132
    Default
    I am wondering if Skotty meant something else. I am a novice here since I just joined the EV world on Saturday. I plan on getting a 240 volt charging station installed in my house if the grant money is still available. I have chosen the Blink form Ecotality. After I get the charging station installed my guess is I will carry the 110 cord in the car for travel purposes. If I go somewhere and am able to plug in, I will to conserve use of the ICE.
    I am wondering if this is the direction the pole was supposed to take.
    Steven
    After all was said and done, more was said than done!
  9. #18
    Join Date
    Mar 2012
    Location
    Kansas City
    Posts
    274
    Default
    Quote Originally Posted by VeridianJoule View Post
    Steven
    The Tesla doesn't require charging stations. You can plug into just about any kind of power outlet so long as you have the plug adapter. I vaguely recall a picture of a Tesla plugged in and there was a box-like part to the cord. I would guess it was the equivalent of the EVSE, only far more capable than the 120v only turd you get with all other available EVs.
    At this point, the poll should really be -- is it better to have portable and/or built-in-car EVSE's that can handle most everything, or is it better to have mostly non-portable EVSE's built for installation on walls and in public charging stations? But I would have to start a new poll for the results to be worthwhile.
  10. #19
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,322
    Default
    The early EV's got an extra 50 feet of range because you could drive off with the cord still attached. Try that with a Volt charger cord.
  11.
    Advertisement
  12. #20
    Join Date
    May 2009
    Location
    Wake Forest, NC VIN:#C-8909
    Posts
    2,066
    Default
    I don't understand why there is confusion. The Tesla Model S comes with a portable EVSE (the Mobile Connector) just like all the other EV/PHEVs. It just happens to use Telsa's standard. They do include an adapter to use the J1772 plug on public EVSEs. The nice thing is that it supports up to 10kW (vs the Volt & Leaf's 3.3kW) via 120 or 240V. Tesla has to include a 240V option because the Model S is pretty useless on 120V (30+ hours to charge the smallest battery).
    The HPWC 2.0 ($1200) will be the wall mount version that will support up to 20kW using 240V.
    See the photo below for both versions:
    2012 Blue Topaz Volt - VIN:#C-8909 - Leather Seats Black with Dark Trim, Rear Camera
    9/15/11 Ordered, 11/18/11 Arrived (highly efficient signature zone) Volt Stats
+ Reply to Thread
Similar Threads
  1. kwh @ wall, vs reported
    By Kacey Green in forum Newcomers to GM-VOLT.COM (See here for FAQs)
    Last Post: 01-24-2012, 01:02 PM
  2. Arcadia (FL) Chevrolet Makes it to Wall of Shame
    By flmark in forum Buying, Leasing & Selling - Chevy Volt
    Last Post: 10-14-2011, 10:47 PM
  3. 3.3 kW on board charger
    By rphooper in forum Chevy Volt Engineering and Design
    Last Post: 10-14-2010, 07:00 AM
  4. Wall Street Journal ECOnomics Conference
    By misslexi in forum Politics, Finance, and Environment
    Last Post: 01-07-2009, 02:13 PM
  5. CA Air Resources Board Needs Input
    By KariK in forum General Motors and General Automotive Topics
    Last Post: 03-23-2008, 06:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
