Remote Start- Then Disconnecting Charger
Grab our Forum Feed
+ Reply to Thread
Results 1 to 8 of 8
Thread: Remote Start- Then Disconnecting Charger
  1. #1
    Join Date
    Jun 2012
    Location
    Bucks County PA, USA
    Posts
    90
    Default Remote Start- Then Disconnecting Charger
    Perhaps this information was already covered somewhere in this forum, but I can't seem to find it. I also checked the owner's manual and it is not clear there either.
    Let's say I have the Volt hooked-up to a 220V charger, then do a remote start to cool the cabin. What steps do you take when you are ready to drive off?
    If I just disconnect the charger from the Volt's port, it freaks out and honks/flashes even if I am right next to it with the RKE in my pocket. I know the honking/flashing is designed to scare-off anyone tampering with the car and alert the owner that the charge has been interrupted, but I must be missing some step for a legit disconnect when the car is "running".
    It seems counter-intuitive to have the turn the car off, then disconnect, then turn it on again- so that cant be it, right? Is there an RKE button to push? A secret word or incantation?
    Help appreciated.
    Thanks.
    Mark
    2012 Chevy Volt #4471
    Cyber Gray Metallic
    Back-Up Camera/Proximity Sensors
    Driver has big smile on face most of the time
  2. #2
    Join Date
    Dec 2011
    Location
    Salem, OR
    Posts
    75
    Default
    Try "unlock" on the remote; that should tell the car that you are there!
  3. #3
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,659
    Default
    You either need to unlock the car, or go into the config menu and uncheck the charge cord alarm. The car locks itself when you remote start it, and when it is locked, if the config option for the charge cord alarm is set, it'll trip the alarm if the cord is removed.
    Walter
    Volt FAQ
  4.
    Advertisement
  5. #4
    Join Date
    Jun 2012
    Location
    Posts
    90
    Default
    Thanks- I think I tried that but will try again. The car is actually unlocked already when I did this (as it was safe in it's garage bay) but maybe that will do it....
    Cyber Gray Metallic
  6. #5
    Join Date
    Jun 2012
    Location
    Posts
    90
    Default
    Aha- there is the missing piece of information- I did not know that the car locked itself when remote started. Before the remote start, it was not locked as it was in a locked garage.
    Cyber Gray Metallic
  7. #6
    Join Date
    Mar 2010
    Location
    Hampton, VA
    Posts
    168
    Default
    My guess is that doing a remote start through the OnStar phone app or the MyVolt website causes the doors to become locked if they aren't already. According to the owner's manual, you have to press the door lock button on the remote before pressing and holding the remote start button for five seconds, so the doors end up locked no matter how you remote start the car.
    Volt C-6178
    2012 Silver Ice Metallic, Camera, Nav/Bose system, cloth seats
    9 Jul - Order placed (1100) / 6 Oct - Produced (3800) / 27 Oct 2011 - Picked up! (6000)
    Last fill-up: 20 Feb 2013 / Last gas used: 21 Apr 2013
  8. #7
    Join Date
    Apr 2012
    Location
    San Diego, CA
    Posts
    25
    Default
    Yes, Krellion has it right. You have to lock the doors and then press (and hold) the remote start button within a couple of seconds of locking the doors. OnStar will do both steps for you.
    Either way, you have to do an unlock first, or the alarm will sound.
    By the way, I remote start every morning while plugged in, but I habitually unlock the door after remote starting. I have been doing this since I got the Hybrid Tahoe back in '08.
  9. #8
    Join Date
    Jul 2011
    Location
    Long Island, NY
    Posts
    480
    Default
    My habit is to open the driver's door while (er, just before) unplugging - I'm going to need to open that door anyway, after all.
    2012 Volt (#3859) - Delivered 2011-10-06
    Computer programmer, science and engineering wonk, and habitual over-analyzer.
Similar Threads
  1. NO Remote Start!!!
    By Turboba6 in forum Volt Ownership Forum
    Last Post: 02-27-2012, 09:25 AM
  2. Remote Start Criteria
    By eplantz in forum Volt Ownership Forum
    Last Post: 11-10-2011, 05:16 PM
  3. Scheduled remote start
    By nhern202 in forum Suggestions for GM
    Last Post: 11-05-2011, 09:03 AM
  4. Remote Start Best Practice
    By diverdon in forum Volt Ownership Forum
    Last Post: 01-20-2011, 08:24 AM
  5. Remote Start?
    By baltimore17 in forum VOLT Consumer Advisory Board Discussion Forum
    Last Post: 11-23-2010, 03:01 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
