Curious early morning AC smell
Grab our Forum Feed
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Curious early morning AC smell
  1. #11
    Join Date
    May 2008
    Location
    Denver CO
    Posts
    888
    Default If you had the battery enhancement done recently, the grease and/or coolant can land
    on a hot part. May clear up soon, but if its' the grease, that stays quite awhile. Warning though, if you get a service engine soon light, it's tied in with that. Take it in. My whole system shorted out due to a bad battery enhancement job. 3 weeks in the shop.
  2. #12
    Join Date
    May 2008
    Location
    Denver CO
    Posts
    888
    Default
    The cooland got into the electrical system when they take apart the hoses for the battery coolant. Turned very serious, but thankfully under warranty. Yes, the smoky, not oil but a burning fluid kind of smell. That's when the nightmare began.
  3. #13
    Join Date
    May 2012
    Location
    Harrisonburg, Virginia
    Posts
    461
    Default
    Quote Originally Posted by jbfalaska View Post
    I'm leaning toward the stinky hvac system since my enhancement was performed at the factory while in production.
    2012 Crystal Red Tintcoat
  4.
    Advertisement
  5. #14
    Join Date
    Mar 2012
    Location
    Thomasville NC
    Posts
    26
    Default
    That may be a better description of the smell...burning fluid kind of smell....not quite electrical but not a paper or wood kind of smoky. And definitely not a mildew or mold smell. I have tried all the suggestions posted...fan only the last few minutes before shutdown, etc and nothing had an effect until I did not plug in last night. This morning air was fresh and clean smelling. Has to be related to the charging process...and yes the 8 day battery enhancement was completed a few weeks back.
    Brennan and Bailey's Dad
    2012 Crystal Red, Tan Leather with dark accents, Polished wheels
    everything but Nav
  6. #15
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,974
    Default
    Quote Originally Posted by hunseder View Post
    I've noticed a smell as well, but it's more like old socks. Car is 1 month old, no laundry in car! It's just the first 20-30 seconds of air that reeks, then it is fine. It's like the air trapped in the ductwork isn't allowed to free-flow once the car is off.
    Sounds like typical water condensation in your air-conditioning evaporator allowing mold to grow. All cars do it. You might want to have the dealer check that the drain hose is not plugged. If you live in a humid climate this is pretty normal for most cars.
  7. #16
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,974
    Default
    I understand you had a very serious issue... But... I think your experience is extremely rare. (Like you might be the only one who ever had this happen.) This is not a case of thousands of Volts sprouting leaks. It's just not a common problem.
  8. #17
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,974
    Default
    BBDAD if you are concerned about this issue then you might want to take it to your dealer and let them inspect it. If the check engine light comes on... Take it to a dealer right away.
  9. #18
    Join Date
    Mar 2012
    Location
    Thomasville NC
    Posts
    26
    Default
    Well it's just turned 3500 miles so I figured tire rotation and oil change (1st one is free anyway). Made service appt for Monday am. I just dread the..."we couldn't duplicate the problem" response, but at least it will go on the record in case of problems down the road. I think I will take it in almost discharged completely and ask them to plug her up and then check it.
    Quote Originally Posted by Fulgerite View Post
    everything but Nav
  10. #19
    Join Date
    Jun 2012
    Location
    Wisconsin
    Posts
    33
    Default
    My 2011 Infiniti has that smell, I cannot stand it.
Similar Threads
  1. Mildewy smell from A/C
    By David in forum Volt Ownership Forum
    Last Post: 03-27-2013, 08:01 PM
  2. Bad smell from dash vents?
    By Voltasic in forum Volt Ownership Forum
    Last Post: 04-24-2012, 11:36 AM
  3. Just curious...Are a pair of Nissan Leaf's called Leaves?
    By voltedge in forum Electric Car Competitors
    Last Post: 03-25-2012, 09:01 PM
  4. Missing the Smell of the Gas Pumps...
    By MrEnergyCzar in forum Volt Ownership Forum
    Last Post: 12-15-2011, 11:55 PM
  5. Clutch like burning smell?
    By black88mx6 in forum Volt Ownership Forum
    Last Post: 10-26-2011, 11:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
