Curious early morning AC smell
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
Thread: Curious early morning AC smell
  1. #1
    Join Date
    Mar 2012
    Location
    Thomasville NC
    Posts
    26
    Default Curious early morning AC smell
    Since it has turned warmer, I notice what I can only describe as a smoky smell, like something electrical is hot, that comes from the AC vents upon start up in the mornings. I have tried to make sure climate control is not on recirculate thinking it's just left over stale air, but that doesn't seem to have any effect. I usually leave the AC on eco, 72 auto all the time and it does it's auto recirculate thing. The car is plugged in all night in the garage. Has anyone else experienced the same smell...should I be concerned?
    Brennan and Bailey's Dad
    2012 Crystal Red, Tan Leather with dark accents, Polished wheels
    everything but Nav
  2. #2
    Join Date
    May 2012
    Location
    Harrisonburg, Virginia
    Posts
    477
    Default
    Weird, same thing happened to me yesterday morning. Doesn't smell electrical but as you described, smokey. Almost like a wood burning stove kind of smell. Went away fairly quickly after several seconds.
    2012- Crystal Red Tintcoat
    "WATT GA5"
    EVSE- Eaton L2 (16-amp)
  3. #3
    Join Date
    Mar 2012
    Location
    Thomasville NC
    Posts
    26
    Default
    It may be coincidence that the battery service was performed a few weeks ago and it has been doing it pretty much since, but nice to know I am not alone.
    Just wondered if there is a direct link with the battery cooling system and the cabin AC? Or maybe the battery cooling system's overnight "exhaust" is just picked up by the cabin AC upon start-up? Maybe I'll try leaving AC off until I pull out of the garage and then turn it on to see if that cycles in fresh air.
    everything but Nav
  4.
    Advertisement
  5. #4
    Join Date
    May 2012
    Location
    Northern AZ
    Posts
    27
    Default
    I've noticed a smell as well, but it's more like old socks. Car is 1 month old, no laundry in car! It's just the first 20-30 seconds of air that reeks, then it is fine. It's like the air trapped in the ductwork isn't allowed to free-flow once the car is off.
    _______________________________________
    2012 Viridian Joule - everything but NAV
    "SUNVOLT"
    220V Level 2 SPX, self-installed
    7.5 kW grid-tied solar | Geothermal HVAC | Oventrop Solar hot water
  6. #5
    Join Date
    Nov 2011
    Location
    Tampa Bay
    Posts
    428
    Default
    I've never smelled that, though I did install a cabin air filter, one imbedded with charcoal, which might helps with any odor.
    If you want to intall one, searched on past threads about cabin air filters.
    2013 Volt #D8115
    Formerly 2011 Volt #B1514
  7. #6
    Join Date
    Mar 2012
    Location
    Illinois
    Posts
    1,664
    Default
    Smelly AC ducts are a common complaint with the Corvette community, aside from ensuring the AC drain tube isn't clogged, GM can clean the ducts by spraying a disinfectant into them, in addition GM issued a TSB suggesting folks run the FAN with the AC off for a few minutes just prior to shut down. In fact on my 99 they actually allowed the HVAC blower/fan to run a few minutes after shut down to help DRY the system out.
    I did have these symptoms on my 99, 06 and 07 Corvette's. I suspect a TSB is eminent.
    Tom
    USAF Retired
    2012 Volt
    Best EV Range 50.x miles (more than once)
  8. #7
    Join Date
    Feb 2008
    Posts
    132
    Default
    Tom is correct. I also believe it's just residual moisture that was on the evaporator coil when the car was parked the previous day. I have always shut the A/C off and ran fan only for a minute or so on all my vehicles. This also helps to dissipate heat from the condenser prior to parking in garage for the night.
    mmcc - USAF Ret
    2012 White w/all options ex. wheels
    15630
  9. #8
    Join Date
    May 2012
    Location
    Campbell CA
    Posts
    29
    Default
    To prevent stinky air ducts, I have always switched off the ac a few blocks away from home to run warmer air through so the condensation doesn't build up when I park.
    2012 Cyber Gray Volt # H21774
    Delivered 5/23/2012
    EV range personal best = 48.2 miles
    https://www.voltstats.net/Stats/Details/1192
  10. #9
    Join Date
    Aug 2010
    Location
    Detroit, MI
    Posts
    2,013
    Default
    @BBDAD,
    I have not heard of an electrical burning smell from the A/C vents. I have however heard of a musty odor. Under certain climate and operating conditions, a musty odor develops from mold growth in the evaporator core face. This odor is generally temporary. As climate conditions change, the odor will disappear and repair automatically. If this odor you are experiencing persists though, I would make a trip to the dealer.
    If you have any further questions feel free to contact the Chevrolet Volt Advisor Team
    (877) 486-5846
    New Volt Advisor Hours:
    Monday - Friday 8AM to 11PM EST.
    Saturday 11AM to 8PM EST.
    Closed on Sunday.
    voltsocialmedia@gm.com
    https://twitter.com/ChevyVolt
  11.
    Advertisement
  12. #10
    Join Date
    May 2012
    Location
    Posts
    477
    Default
    Quote Originally Posted by BAZINGA View Post
    Thanks for the info, I will run the fan a few minutes after cutting off AC. May even try the heater as well.
    "WATT GA5"
Similar Threads
  1. Mildewy smell from A/C
    By David in forum Volt Ownership Forum
    Last Post: 03-27-2013, 08:01 PM
  2. Bad smell from dash vents?
    By Voltasic in forum Volt Ownership Forum
    Last Post: 04-24-2012, 11:36 AM
  3. Just curious...Are a pair of Nissan Leaf's called Leaves?
    By voltedge in forum Electric Car Competitors
    Last Post: 03-25-2012, 09:01 PM
  4. Missing the Smell of the Gas Pumps...
    By MrEnergyCzar in forum Volt Ownership Forum
    Last Post: 12-15-2011, 11:55 PM
  5. Clutch like burning smell?
    By black88mx6 in forum Volt Ownership Forum
    Last Post: 10-26-2011, 11:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
