PLease replace the Navigation system.
Grab our Forum Feed
+ Reply to Thread
Page 1 of 6 1 6 LastLast
Results 1 to 10 of 60
Thread: PLease replace the Navigation system.
  1. #1
    Join Date
    Apr 2012
    Location
    Illinois
    Posts
    22
    Default Nav takes me to a cornfield!
    Seriously....my wife's cellphone is better than the Nav system on this Volt. Any updates to the software to the system? It seems lost!
  2. #2
    Join Date
    Jun 2012
    Location
    Illinois
    Posts
    199
    Default
    Quote Originally Posted by farmboy View Post
    That is funny given your member name....lol....
  3. #3
    Join Date
    Jun 2012
    Location
    Santa Rosa, CA
    Posts
    97
    Default
    The Nav in mine is doing pretty well. At least as well as my Droid. Kinda depends on how it is failing. If it is truely just lost you might have a bad GPS or GPS antennae. If it know where it is, but takes you to a location other then where you think it should then maybe the maps need to be updates. BTW, the maps in the NAV unit don't cover the whole US in detail. You can go the config screen in the vehicle and see where they have detailed maps. You may not be in an are that has detailed maps.
  4.
    Advertisement
  5. #4
    Join Date
    May 2011
    Location
    Michigan
    Posts
    570
    Default
    As I understand it the Nav system software used in cars is just from a few outside sources. The rate of updates is at various levels with highways/metro areas roads at the highest level of refresh, to residential streets and maybe cornfields(?) at a low level. And the refresh is covers something like 98-99% of the new content . So what you experienced is likely the case of catching up in the future. Your wife's cell phone likely has another source for nav info so that is why there is a difference.
    You can always call OnStar and ask the advisor for the same location request and they may be able to find it through the web based system they have, it may be one way of finding it.
    2011, My Zen-like Car, and Driving Experience #3187
  6. #5
    Join Date
    May 2011
    Location
    Michigan
    Posts
    570
    Default
    Oh one more comment I forgot to add commercial businesses have a higher priority than homes too in the refresh rate.
  7. #6
    Join Date
    Apr 2012
    Location
    Illinois
    Posts
    22
    Default
    It is ironic, is it not? I grow corn, was looking for a commercial business south of Chicago, and LITERALLY ended up in a cornfield at the end of a dead end street?! Thanks for the comments everyone.
  8. #7
    Join Date
    Jun 2011
    Location
    Westborough, MA B-2689
    Posts
    774
    Default
    Quote Originally Posted by 2BeLivingGreen View Post
    The rate of updates is at various levels ...
    My understanding was that the NAV system (in the Volt and most other cars) uses the hard drive, and doesn't get updated. Are you sure that it gets updates?
    B-2689
    Personal Best Charge: 57.2 miles
    Best Day: 71.3 miles, no gas (49.9 on full charge, 21.4 on ~4 hours @120V)
    Over 4 billion pieces of data collected on the Volt OBD2 port
  9. #8
    Join Date
    Dec 2011
    Location
    Birmingham, AL
    Posts
    60
    Default
    I don't have the nav system in my Volt but use the OnStar turn by turn which is great. Very easy to set the destination with the iPhone app and works like a champ. Because the system is web based, it is likely to be updated regularly.
    I assume you can still use the OnStar nav in cases where your destination on the built in system isn't up to date. Of, course the trick is knowing when it right and wrong.
    2012 White Volt
    Check my VoltStats
  10. #9
    Join Date
    Jan 2011
    Location
    NE Iowa
    Posts
    80
    Default
    Here's the link for NAV updates. http://www.gmnavdisc.com/buy-a-disc.asp?lang=en
    Anyone taken the plunge to purchase the update(s)?
    B2486 - Picked up 2/2012
  11.
    Advertisement
  12. #10
    Join Date
    Jun 2011
    Location
    Metro Detroit
    Posts
    106
    Default
    I thought I read that we were entitled to one nav update a year. Is that true? If so, why should we need to purchase that disc?
    B3637 - Metro Detroit area
    I'm just Sip-N-Oil
Similar Threads
  1. Navigation System Silliness
    By dwvoss in forum Volt Ownership Forum
    Last Post: 04-19-2012, 02:30 PM
  2. They want to replace the entire drive system
    By Voltaviator in forum Mechanical systems
    Last Post: 12-25-2011, 11:00 AM
  3. Upgrade navigation system HDD?
    By Krellion in forum Chevy Volt Accessories, Modifications, and Hacks
    Last Post: 10-24-2011, 01:47 AM
  4. Navigation System and Pandora
    By Hardcore73 in forum Newcomers
    Last Post: 09-29-2011, 10:15 PM
  5. Navigation System Weather Warnings
    By Frankman in forum Engineering and Design
    Last Post: 01-30-2011, 08:32 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
