Check This out.
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: Check This out.
  1. #1
    Join Date
    Jun 2012
    Location
    Cedarburg, Wisconsin
    Posts
    14
    Default Check This out.
    I came across some really interesting information while researching solar-voltaic charging stations with capacitors to store daytime current creation. Check out this info.....it could possibly be a real game changer for EVs. http://www.ideaspike.com/ultracaps.shtml
  2. #2
    Join Date
    Jul 2011
    Location
    Memphis, TN
    Posts
    199
    Default
    Yes, they are interesting. I have seen DIY EVs that use ultra capacitors http://www.metricmind.com/ac_honda/main2.htm.
    I've long thought that using them in combination with batteries to handle intense regen and store power for rapid acceleration - a buffer for the batteries to reduce the most extreme charge/discharge scenarios.
    The real problem is weight. We can stuff all sorts of things in a car to make it more powerful, regen better, have longer range. But the trade-in weight (and then complexity) make it a bit more challenging.
  3. #3
    Join Date
    Nov 2011
    Location
    Floyd, Virginia
    Posts
    1,439
    Default
    I note that in the article it says the manufacturer is "on track to exceed battery capacities by 2007" - and here we are and yet no super cap is even close...to NiMH, much less Li ion.
    If it (marketing copy) works on the venture capitalists, then its done its job. There's more scammy blue sky in alt energy than almost anyplace else.
    Volt #5014, White. All off grid solar powered. My sci-tech boards:
    http://www.coultersmithing.com/forums/index.php
  4.
    Advertisement
  5. #4
    Default Ultracaps
    I can't believe that Eestor has resurfaced. I see the info in this article harkens back to 2007 so the poster probably doesn't know what a scam Eestor foisted on the public.
  6. #5
    Join Date
    Jan 2011
    Location
    SE PA
    Posts
    3,500
    Default
    Not really a good idea. Any solar-charging EV station (if public) should be grid-tied. What happens if such a station as described has a full capacitor? The solar energy has nowhere to go and would have to be bled off somewhere. Grid-tie it and the excess is sent to the grid and if at-night, pull energy from the grid to charge an EV plugged in.
  7. #6
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,292
    Default
    Quote Originally Posted by DCFusor View Post
    +1 I think Mickey Bly said something about there being liars, damned liars, and battery manufacturers. Which gets me thinking, where is the EESTOR product?
  8. #7
    Join Date
    Jun 2012
    Location
    Posts
    14
    Default Sorry!!!
    My apologies!
    I didn't pay close enough attention to the article's date. I realize there are a lot of pie in the sky ideas out there as well as scams. I guess I let my exuberance for new technological advances get the better of me this time. We that said, I'm betting that if the right people put the heads together, that the ultracapacitor could one day be a very viable solution. I've also seen some articles related to new battery design that's suppose to reduce weight as well as cost and reduce charging times significantly.
    I'd love to see the Volt achieve an all electric range closer to the 100 mile mark but retain the on board generator for unlimited range capabilities. I'd also love to see Chevy introduce a Volt model like the original concept design for those of us that like the sleek chopped top look.
    Thanks for all the feedback!
Similar Threads
  1. one day old and Check engine light is on
    By avraja in forum Volt Ownership Forum
    Last Post: 10-03-2012, 02:38 PM
  2. Please Check My Math / Logic: 41 MPG
    By Volt Dolt in forum Engineering and Design
    Last Post: 02-26-2012, 11:00 AM
  3. Check out this bike
    By George S. Bower in forum Chevy Volt News and Events
    Last Post: 08-30-2010, 12:37 PM
  4. Check this IMAGE out
    By JohnK in forum Off-Topic
    Last Post: 02-20-2010, 03:54 PM
  5. Check one for Volt!
    By misslexi in forum General Motors and General Automotive Topics
    Last Post: 01-06-2009, 09:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
