Wiping front to Back: Here's Why.
Grab our Forum Feed
+ Reply to Thread
Results 1 to 8 of 8
Thread: Wiping front to Back: Here's Why.
  1. #1
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,813
    Default Wiping front to Back: Here's Why.
    To keep your door valves from being damaged, wipe the door from front to back when drying with a cloth.
    The other day I noticed a small rubber flap fall to the pavement while I was dying the door after a wash. I was wiping back to front when this happened and I must have snagged it, pulling it out.
    Peering under the door, there are two rectangular rubber valves, one toward the front and the other toward the rear of the door. The piece I knocked off was a flapper "door" for one of these seals as they are called. I pushed it back in place, then went around all 4 doors finding that each door was missing one of the two flaps, some the front, some the back.
    These flaps apparently act as one-way water weep holes (when they are not missing). Perhaps they place a subtle role in acoustics are airflow as well? The pictures show these valves with the flap and sans flap. The molded arrow points to the front of the car. I ordered 4 replacement seals which arrived a few days later.
    So kids, wipe from the front to the rear (along the bottom edge of your doors),
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 32,109 miles, 143 MPG, Remaining Oil Life 98%
    Typical Commute: 57-67 miles
    30 day Stats: 1288 miles, 250+
    MPG, 87% Electric, 13% gas, Saved 52 gal., 24 kW-hr/100 miles
    VOLT TIPS & SECRETS
  2. #2
    Join Date
    May 2012
    Location
    Houston, Texas
    Posts
    300
    Default
    Thanks for the pictures!
    I found one of the rubber pieces in my driveway just 1 week that I had my new Volt at home. I figured I would find where it goes, but I did not see anything like that until today.
    From my experience, it was like less than 1 week when I found it just sitting in the driveway, so I am assuming these things fall off pretty easy.
    -KyleH
  3. #3
    Join Date
    Mar 2012
    Location
    longmont, colorado
    Posts
    237
    Default
    I didn't even know they existed, never looked at the door bottoms. Thanks for the tip.
    b2690
  4.
    Advertisement
  5. #4
    Join Date
    Mar 2012
    Location
    Illinois
    Posts
    1,804
    Default
    Interesting info, and like most every other Volt owner I was blissfully unaware these even existed.
    Thanks for the info and photos.
    Tom
    USAF Retired
    2012 Volt
    Best EV Range 50.x miles (more than once)
  6. #5
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,813
    Default
    Quote Originally Posted by KyleH View Post
    -KyleH
    The rubber flaps attach to the main rubber seal with a plug/nipple, and you can pop them back in if you find them. But they can just as easily be pulled out by wiping the door bottom the wrong way in my experience. The replacements are $3 each. Must be very special rubber, haha.
    B3320
    VOLT TIPS & SECRETS
  7. #6
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    2,069
    Default
    Great Post! Thank You!
  8. #7
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,466
    Default
    This is the type of thing I don't want to read about this but thanks for posting! Great info. LOL
  9. #8
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,322
    Default
    There seems to be a third weep hole as you move up closer to the door hinge. This third hole (no rubber cover) is where I see most of the water draining after washing or a rain. I generally have to open the door to see it in action.
    Thanks for the tip-
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
+ Reply to Thread
Similar Threads
  1. Front air dam - do you have it on?
    By AllenL in forum Chevy Volt Owners Forum
    Last Post: 2 Weeks Ago, 08:30 PM
  2. Scrapping the front?
    By Lowa in forum Chevy Volt Owners Forum
    Last Post: 06-18-2012, 12:47 PM
  3. Front air dam
    By patrick40363 in forum Chevy Volt Owners Forum
    Last Post: 06-06-2012, 11:21 AM
  4. 19/20 inch wheels at the back and 19/18 inch on the Front?
    By Brittt1 in forum Chevy Volt Accessories and Modifications
    Last Post: 11-17-2011, 01:57 PM
  5. Distance between the front seat back and the rest seat back?
    By jomo25 in forum Chevy Volt Owners Forum
    Last Post: 07-29-2011, 07:47 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
