Originally Posted by
ghostgs1
I would agree with the others in the connection at the outlet being the problem. I am retired after 37 years in power plant operation and maintenance and the majority of electrical fires in breakers or switches/outlets I have seen, were caused caused by loose connections. I have seen some that were not, those being in situations where a mechanical device driven by a motor failed and would not allow the motor to turn. Once in a while a breaker will catch fire when the load is too great, but this has always been a case where load was added to a breaker system that exceed the original system design. In my home a loose connection at the dryer breaker caused the breaker to trip and partially melt the breaker. This was shortly after we moved into our home when it was less then six months old. Ray
Sage advice and I'd ask you contact the MOD's to change the title of this post. Someone GOOGLING will stumble on this and it could spin out of control again that the Volt is burning down homes.
Tom
USAF Retired
2012 Volt
Best EV Range 50.x miles (more than once)
