New Guy Here
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: New Guy Here
  1. #1
    Join Date
    Jun 2012
    Location
    Cedarburg, Wisconsin
    Posts
    14
    Default New Guy Here
    Hello All!
    Just joined the forum. I'm currently waiting to lease a new Volt once the lease on my current Malibu is up in December.
    I've been researching a lot of different things about the Volt the last few months and one of the things I'm curious about is it's ability to pass a slower car on a two lane road. Is there anyone out there that has experienced this and was there a method you used to do so? I've read that changing the drive mode to the sport setting improves the Volt's acceleration capabilities, is that like downshifting to increase rpms so that you have enough acceleration to get around a slower driver?
    The other thing I wondered about is the use of premium gas. I understand the only reason premium is necessary is because of the higher octane and thus the gas doesn't spoil as fast as regular unleaded. If that's true, then I would think using an additive like Stabil to unleaded gas would work too?
    I'm looking forward to learning more about the Volt from all of you on the forum.
    Thanks!
    Voltmein
  2. #2
    Join Date
    Mar 2012
    Location
    United States
    Posts
    311
    Default
    Quote Originally Posted by Voltmein View Post
    No. All "sport" does is make it so that the accelerator pedal is more sensitive; it does nothing to increase net system output. Floored pedal in regular mode is exact same as floored pedal in sport mode.
    Premium gasoline contains more energy than regular unleaded, and as a result gets you greater mileage from the generator. While it can burn fine on regular, you will likely see a minor drop in generator miles per gallon.
  3. #3
    Join Date
    Jun 2012
    Location
    Posts
    14
    Default
    Thanks for the feedback. I appreciate it very much.
  4.
    Advertisement
  5. #4
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,547
    Default
    Hello All!
    Thanks! Voltmein
    You will have zero issues/problems passing people. I don't hotrod a lot in my Volt ('11) on the highway but last weekend I was passed by a friend driving their truck. I waited for them to pass (multi-lane road) and then I passed them after putting it on the floor. I "flew" by them. They were impressed! SPORTs mode works the same as NORMAL mode when you put it to the floor. It just remaps the pedal to make it more "responsive" / linear. On the floor, it is the same.
    The Volt ICE was tuned to work with premium to get better mileage as well. See:
    why-the-volt-requires-premium-gasoline/
    http://gm-volt.com/2010/07/30/why-th...mium-gasoline/
  6. #5
    Join Date
    Mar 2012
    Location
    Oklahoma City, OK
    Posts
    6
    Default
    You will have no problem passing cars on the road. My prior car was a Pontiac G6. It was fast and I would say the Volt is just as fast. I have never put the car in sport mode just to pass someone. I do love the sport mode but, if you use it all the time, it sort of defeats the purpose of trying to get the best mileage possible. We typically get 40 miles per charge with fairly conservative driving. I also have a Chevrolet Silverado and the Volt will leave it sitting still. I have bought dozens of new cars in my 64 years and the Volt is the most enjoyable car to drive of all of them. I use premium gas in my car just because it is recommended. We drove our first 5,000 miles with only 15 gallons of gasoline. We then took a 3,000 mile trip where we were using 100% gas. Mileage was 38.5 MPG.
  7. #6
    Join Date
    Jun 2012
    Location
    Posts
    14
    Default
    Thanks Scott! I can't wait to get my Volt, December seems like an eternity right now.
  8. #7
    Join Date
    Jun 2012
    Location
    Posts
    14
    Default
    That's some very encouraging news, both on the acceleration concern as well as the mileage results you're achieving. Thanks for the input.
  9. #8
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,459
    Default
    Welcome to the forum.
    You'll be happy with your Volt when you get it. The Volt will be the most responsive car you've ever driven. No downshifting means no pauses when passing.
  10. #9
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    2,069
    Default
    Unlike most gas powered cars there is no delay when you press the accelerator. There is no downshift. No engine delay. The Volt is extremely responsive. The low end torque off the line is very impressive. Probably better than most sports cars from 0-30. The acceleration is acceptable from 30-100 but not outstanding. It's about the same as most 4 cylinder sedans. It's definitely faster than a Prius and much more fun to drive as well. It is silent, smooth and handles very well. Take one for a test drive.
    Also... In some cases it's advantageous to trade in your leased car early. In my case it was actually cheaper to turn it in early because I did not have to replace the tires before turning it in. The buyout on my lease was also slightly lower than bluebook so the car actually had some positive equity. If I had waited I would have needed to pay for new tires and the car would not have had any + equity in it. Also... My lease payments on my Volt were LESS than my previous car so why not start paying less sooner? Just a thought.
  11.
    Advertisement
  12. #10
    Join Date
    Jun 2012
    Location
    Posts
    14
    Default
    Thanks for the response Don.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
