A/C Dash Vent locations
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 22
Thread: A/C Dash Vent locations
  1. #1
    Join Date
    Apr 2012
    Location
    Aurora, IL
    Posts
    91
    Lightbulb A/C Dash Vent locations
    Now that summer heat is starting to show up I'm starting to really use A/C in comfort mode. I wish the dash vent locations were moved so the vents could easily blow on my face. Both vents on the driver side are mostly blocked by the steering wheel.
    I also wish there was some way for it to blow colder air more slowly. As it is, the fan blows so loudly it is hard to have a conversation.
    Crystal Red 2012 Volt #19636, "Evie"
  2. #2
    Join Date
    May 2012
    Location
    Grapevine, TX
    Posts
    430
    Default
    I noticed all of the above on my recent second test drive. The loud fan thing in particular - basically, I would have appreciated a couple more fan speed settings.
  3. #3
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,277
    Default
    add a filter- see other posts on this- This way you get a one notch lower air flow. AND you can always lower the speed with the buttons to over ride the auto setting.
    I guess you can always pull the steering wheel in-out and adjust the seat to get more direct air.
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
  4.
    Advertisement
  5. #4
    Join Date
    Jan 2011
    Location
    Fresno, CA
    Posts
    701
    Default
    Use Eco mode, it reduces fan speed, (about half) and you can adjust the temp to Low which will give colder air.
    Jerry, #536 2011 Volt in Fresno, CA
  6. #5
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,508
    Default
    Quote Originally Posted by Voripteth View Post
    Yes, I doc'd the same thing.
    Here is what I've done and suggested. Works great!
    Use-3-vents-too-keep-cool-(or-warm)-when-driving-by-yourself
    http://gm-volt.com/forum/showthread....ng-by-yourself
  7. #6
    Join Date
    Apr 2012
    Location
    Aurora, IL
    Posts
    91
    Default
    I ended up doing what Scott suggested and using the passenger vent to blow on my face. That works as long as there aren't any passengers.
    In the spirit of the Suggestion Forum, I request that that future versions of the Volt:
    1) Move the vents so they aren't blocked by the steering wheel
    2) Add more fan speeds
    3) Add a better way to control fan speeds. (knob or slider)
    4) Quieter fans
  8. #7
    Join Date
    Oct 2010
    Location
    Posts
    3,508
    Default
    As well when there are not rear passengers. I can point my right driver one down the center to the rear. Did that last weekend when 3 of us were in the car and my wife was warm in the back (Sun coming in window too).
    I do like this in the winter because I don't wear gloves and I can point them right at my fingers. I mainly use the seat warmers and sometimes the low heat (modest temp) for my fingers.
  9. #8
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    2,665
    Default
    Well it is 110 F here and I use ECO/AUTO 90% of the time. Really the only time I kick in comfort mode is after a direct sun soak and the interior is really toasty, but then I usually to a remote start and precool anyway.
    Diamond White #B2140 ecosister plate=SLRRYDER
    Crystal Red #C8885, Red-Rider plate=NO2OPEC
    No gas purchased, fully charged off Solar, OK so I bought some gas to go to Vegas!
    DRIVING for FREE! NO OPEC FEE!
    My TED 5000 power monitoring
  10. #9
    Join Date
    Apr 2011
    Location
    Livonia MI
    Posts
    771
    Default
    You can go to the vehicle configuration menu and bias the automatic fan control faster or slower. But you can't haved it both ways. If you bias down the automatic fan settings it won't cool as quickly or provide the comfort. I believe the auto function gives the best tradeoff and I keep it on auto fan always. If you are using the bluetooth hands free phone, the fan speed drops when it is on auto.
  11.
    Advertisement
  12. #10
    Join Date
    Feb 2008
    Posts
    132
    Default
    Correct me if I'm wrong but I believe when you push the "auto" button it defaults to the comfort mode.
    mmcc - USAF Ret
    2012 White w/all options ex. wheels
    15630
Similar Threads
  1. I just had to vent...
    By Voltster in forum Volt Ownership Forum
    Last Post: 04-02-2012, 10:00 AM
  2. Passenger Vent Stuck Closed
    By black88mx6 in forum Mechanical systems
    Last Post: 03-14-2012, 04:28 PM
  3. Charging Station Locations
    By FrankIII in forum Volt Ownership Forum
    Last Post: 02-28-2012, 11:16 PM
  4. Case Sensitivity when downloading locations
    By ClarksonCote in forum Suggestions for GM
    Last Post: 02-01-2011, 09:05 AM
  5. Why Not Seattle - Volt Introduction Locations
    By stevenslough in forum Suggestions for GM
    Last Post: 10-06-2010, 10:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
