Safer brake lights
Grab our Forum Feed
+ Reply to Thread
Page 5 of 6 FirstFirst 1 5 6 LastLast
Results 41 to 50 of 59
Thread: Safer brake lights
  1. #41
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,382
    Default
    Now that we have covered adding extra lights for not racing to a stoplight and jamming the brakes, what kind of signal should we add when we don't *accelerate* at a rate that the guy behind expects? This seem to be an equal safety issue, just under opposite conditions.
    Perhaps a khaki green light? So red is stop, yellow is not accelerating (slowing down), kahaki green is accelerating at less than max speed, green light for faster than turtle start but not bat out of hell, and no lights equals "bat out of hell".
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 139 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  2. #42
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,276
    Default
    Let's first make sure a car on a big hill rolling backwards makes the back up light come on.
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
  3. #43
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    2,665
    Default
    Quote Originally Posted by Cord View Post
    Don't forget the reversing beeper!
    Diamond White #B2140 ecosister plate=SLRRYDER
    Crystal Red #C8885, Red-Rider plate=NO2OPEC
    No gas purchased, fully charged off Solar, OK so I bought some gas to go to Vegas!
    DRIVING for FREE! NO OPEC FEE!
    My TED 5000 power monitoring
  4.
    Advertisement
  5. #44
    Join Date
    Jan 2012
    Location
    oklahoma
    Posts
    670
    Default
    standard shift cars don't turn on brake lights when you are down shifting... i don't understand all of the attention this topic has received from posters on this forum...... leads me to believe most on this board never owned manual transmission automobiles before. down shifting/engine braking has been a part of driving since the beginning of automobiles/motorcycles.
  6. #45
    Join Date
    Mar 2009
    Location
    Phoenix, AZ
    Posts
    376
    Default
    Quote Originally Posted by Voripteth View Post
    I'm quite surprised at the vocal opposition to the idea. This really is a safety issue
    This is no "more" of a safety issue than what you experience with manual transmissions.
    There are always those that believe if you could pass enough laws and make enough technical innovations that we will "never" have another accident.
    As far as GM going the extra mile for safety... There are $500,000 automobiles with manual transmissions that don't have this modification. Why should a $40,000 Volt be required to have it?
    The "opposition" to this is because modifications cost "money". If GM adds this feature and the price of the Volt goes up to $45,000 would that be acceptable?
    And finally..... Since no one has actually been rear ended yet in a Volt due to driving in "L" after 70 million miles..... How high should this be on GM's list of priorities????
  7. #46
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,139
    Default
    Quote Originally Posted by volt3939 View Post
    Sure, regen is a braking system, just not the Service Braking System.
    Service brakes are pedal operated normally, and regenerative brakes are considered auxiliary braking systems.
    The relevant paragraph that refers to regen brakes and the stop lights is 5.2.22.4 which lists deceleration limits for regen. Below 0.7M/s/s (Meters per second per second, or per second squared) the requirement is for no stop lights. Between 0.7M/s/s and 1.3M/s/s stop lights are optional, "The signal may be generated". Above 1.3M/s/s stop lights are required, "the signal shall be generated", i.e. stop lights should be lit.
    If you research the deceleration provided by L, you should find it is less than 1.3M/s/s for sure, else we would have brake lights already.
    (Anyone with the actual #'s?)
    Whether it exceeds 0.7M/s/s is the question, but the requirement for stop lights is only for the service brakes and/or aggressive regen above 1.3M/s/s.
    There are several online acceleration/decelleration calculators, like this one: http://www.smartconversion.com/unit_...alculator.aspx
    I did a very quick and dirty test here at the beach, where it is perfectly flat. In Low gear with my foot off all pedals, it took 12 seconds to decellerate from 50 mph to 30 mph (maximum regenerative braking). This equates to 0.7 m/s/s, right at the bottom of the range for discretionary illumination; or if you prefer, the top of the range where illumination is disallowed. That rate of decelleration may in fact not be as much coincidence as design by GM engineers. They may have anticipated this debate, and decided to play it safe, and go with relatively mild decelleration. As many here have pointed out, LOTS of vehicles decelleration at this rate, without Stop Lamp illumination.
    As a final notion, I wonder if there is a high correlation between Volt owners who prefer D over L, and Volt owners who worry about brake lights. If that correlation is high, then I agree with WOT, put your Volt in Drive, use your brake pedal as you like, and be happy!
  8. #47
    Join Date
    Aug 2011
    Location
    SJ, CA
    Posts
    314
    Default
    Quote Originally Posted by Slapshot28 View Post
    There are several online acceleration/deceleration calculators, like this one: http://www.smartconversion.com/unit_...alculator.aspx
    I did a very quick and dirty test here at the beach, where it is perfectly flat. In Low gear with my foot off all pedals, it took 12 seconds to decelerate from 50 mph to 30 mph (maximum regenerative braking). This equates to 0.7 m/s/s, right at the bottom of the range for discretionary illumination; or if you prefer, the top of the range where illumination is disallowed. That rate of deceleration may in fact not be as much coincidence as design by GM engineers. They may have anticipated this debate, and decided to play it safe, and go with relatively mild deceleration. As many here have pointed out, LOTS of vehicles deceleration at this rate, without Stop Lamp illumination.
    Thanks for the number, just what I was expecting.
    I agree, if you want stop lights, use the brake pedal.
    B3939
  9. #48
    Join Date
    Jul 2009
    Location
    S. California
    Posts
    956
    Default
    Quote Originally Posted by ShannonVolt View Post
    True. And brakes are used for what? To slow or stop a moving vehicle.
    I'm learning all the time. Since I first learned to drive on a non synchro mesh manual transmission, I've learned a lot about <del>brake lights</del> <ins>human nature</ins>!
  10. #49
    Join Date
    Oct 2011
    Location
    Lafayette, IN
    Posts
    127
    Default
    I think we should be less dependent on nanny technology and more so on common sense. Although, that could be the inherent flaw...
  11.
    Advertisement
  12. #50
    Join Date
    Jun 2012
    Location
    Illinois
    Posts
    194
    Default
    I think we are trying to make a mountain out of a molehill.....I LOVE driving in "L" .....you don't have to completely take your foot off of the "go pedal" all at once....what I do (and I am sure what many others here on the forum do who drive in "L") is that I "control" the degree of regeneration by controlling the release of my foot off of the "go pedal" when I am concerned the idiot behind me is too close and may cause a problem.........in this way....you won't feel like you are going to get hit all of the time........when no one is behind me.....I could just completely remove my foot off of the pedal for maximum regen and slowing down......in this way.....have never felt I was going to get hit...........
    On another note.......after a bit of thought.....I too am of the camp that would be against the brake lights coming on in regen.....I have had the honor of being behind people whose brake lights illuminate every 2-5 seconds for no odd rhyme or reason....and HOW ANNOYING IS THAT..... you eventually go around and are on your merrier way...but can you imagine yourself behind your VOLT every time you realease the accelerator for any reason and the brake lights are going on or off......I wouldn't mind quick flash of the brake light (by the nanny patrol) when you are in regen AFTER a few seconds or so....but not right away.....just my $0.02
Similar Threads
  1. My Brake Lights Work Just Fine
    By flmark in forum Chevy Volt News and Events
    Last Post: 03-20-2012, 03:14 PM
  2. Hooky-Bob and use (L)ow to recharge your Volt - no brake lights :)
    By scottf200 in forum Engineering and Design
    Last Post: 01-09-2012, 10:42 AM
  3. Brake lights....again!
    By Driverguy01 in forum Suggestions for GM
    Last Post: 06-22-2011, 10:51 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
