Lovin my Volt, but Check Engine Light at about 400 Miles
Grab our Forum Feed
+ Reply to Thread
Results 1 to 6 of 6
Thread: Lovin my Volt, but Check Engine Light at about 400 Miles
  1. #1
    Join Date
    Jun 2012
    Location
    Santa Rosa, CA
    Posts
    96
    Default Lovin my Volt, but Check Engine Light at about 400 Miles
    I'm loving my Volt. Getting 40/45 miles on a charge. When it goes to the range extender I can hardly tell and it still gets 38 MPG. Nice, but...
    On the way home from work I noticed the check engine light on. When I went to the dealer they said I had a bad cord on my 110 volt charger and gave me a new one and asked me to return the old one when it was convenient. That seemed odd to me because it seemed to work fine. I had mentioned to them that I had to try three charging units at the county charge station to find one that worked. Turns out the bad charge cords at the county charging station turned on the check engine light. Not the car at all.
    Is there a way to turn off the check engine light when you know what it is?
    Terry
  2. #2
    Join Date
    Nov 2011
    Location
    Frisco, TX
    Posts
    160
    Default
    I definitely recommend you contact your Volt Advisor. They will make sure you get the right answer, even if your dealer experience is not consistent. My personal advice is not to assume that you know what is causing the Check Engine light. Might be a different cause the next time. When it does come on, hit the OnStar button right away and ask them to give you the codes it is showing. They will direct you to the dealer if needed (likely). It shouldn't keep coming on. Your Volt Advisor will stick with you through it until it is completely right.
    I had mine come on once after about 8500 miles. Took the above action, took to dealer, they consulted with GM. Turned out to be a transient with no action necessary. The vehicle did not perform any differently while the light was on, and it's been working beautifully ever since.
    Eric Z
    C2063
    "EZ Volt" on Voltstats.net
  3. #3
    Default
    The car will automatically turn off the engine light after 3 or 4 more "test" events that are similar to what caused the failure (In this case charge cycles).
    You can also hit the onstar button and have them run a remote diagnostic on the car to find out what illuminated the light, but I don't believe they are able to reset the check engine light remotely.
  4.
    Advertisement
  5. #4
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,258
    Default
    If it was just the charger then the CEL should clear after a few charging events. If it doesn't clear you should talk to OnStar. You might have to visit your dealer.
  6. #5
    Join Date
    Jun 2012
    Location
    Santa Rosa, CA
    Posts
    96
    Default
    Thanks guys, helpful.
  7. #6
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,277
    Default
    There is alway the possibility your dealer ment you have the older version of the charger cord and were going to swap out for the new one.
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
Similar Threads
  1. one day old and Check engine light is on
    By avraja in forum Volt Ownership Forum
    Last Post: 10-03-2012, 02:38 PM
  2. Replies: 22
    Last Post: 05-04-2012, 03:20 AM
  3. Check engine light on
    By Lest in forum Error messages/ health monitoring/ DTC's
    Last Post: 03-25-2011, 01:17 PM
  4. Check engine light -- p0ac4
    By BethC in forum Error messages/ health monitoring/ DTC's
    Last Post: 03-10-2011, 05:39 PM
  5. Check Engine Light
    By honoreitiscom in forum Volt Ownership Forum
    Last Post: 01-29-2011, 10:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
