Regen Management - Gas vs Brake
Grab our Forum Feed
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Regen Management - Gas vs Brake
  1. #11
    Join Date
    Nov 2011
    Location
    wisconsin
    Posts
    91
    Default
    Quote Originally Posted by Mormegil View Post
    That's a good point. If you coast at high speed, you're loosing that energy only to friction for a longer time. If you regen brake, you gain back some of that energy, and coast after some threshold, you could maximize energy usage.
    I would like to see some math on this.
    Hypermilers do this but normally not for this reason, if you brake hard and early it is less likely you will have to stop and therefore have conserved momentum which is MUCH more efficient than coming to a stop by either means.
  2. #12
    Join Date
    Mar 2012
    Location
    Kansas City
    Posts
    254
    Default
    So this thread kind of wandered off from my original topic, which was to question about doing regen as part of gas and/or brake operation. Anyway, I have some new information, thanks to the just posted engaget video of driving the Tesla Model S. According to what they were talking about in the video, the Model S does indeed do all regen as part of the gas pedal operation, leaving the brakes as traditional friction brakes only. Also interesting, they said the Model S has an accelerometer and will kick on the brake lights after exceeding some deceleration threshold.
    Video here: http://www.engadget.com/2012/06/22/t...goes-electric/
  3. #13
    Join Date
    Oct 2011
    Location
    Lafayette, IN
    Posts
    127
    Default
    Correct me if I'm wrong (LOL), but if I remember correctly, I think it was WopOnTour that said in "D", 20% of the regen is in the gas pedal, and 80% in the brake pedal, and in "L" it's 80% in the gas and 20% in the brake (before the transition to the friction pads).
    It could be a total misfire on my part, but I think this was the ratio. I'm just glad GM made it so darn easy to switch between these modes on the fly!
  4.
    Advertisement
  5. #14
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,647
    Default
    Quote Originally Posted by QB 45 View Post
    I think it varies somewhat with speed, but in my experience if more like 10-15% in D and slightly over half in L. See the three rising diagonal lines in the top half of the chart? the lowest one is D regen, the middle one is L regen, and the top one (almost at the edge of the chart) is max regen using the brake pedal...
    Walter
    Volt FAQ
Similar Threads
  1. Measuring Regen
    By eplantz in forum Volt Ownership Forum
    Last Post: 05-03-2012, 02:12 PM
  2. Regen recharging
    By DJWilson2 in forum Volt Ownership Forum
    Last Post: 12-02-2011, 12:37 PM
  3. Tesla - another debated regen brake light discussion - interesting!
    By scottf200 in forum Volt Ownership Forum
    Last Post: 07-05-2011, 12:56 PM
  4. regen braking, how much?
    By excess_3 in forum Engineering and Design
    Last Post: 01-31-2011, 05:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
