Help, Charging Issue With OEM Charger, 2011 VOLT
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 21
Thread: Help, Charging Issue With OEM Charger, 2011 VOLT
  1. #1
    Join Date
    May 2011
    Location
    Michigan
    Posts
    723
    Default Help, Charging Issue With OEM Charger, 2011 VOLT
    Need some help, I have recently developed a charging issue with my OEM L1 charger (replaced once by Chevrolet, by dealer, in the customer satisfaction on the OEM VOLT charger). Original owner of 2011 VOLT, and awesome car.
    All of a sudden the car will not charge in a continuous uninterrupted manner. What I mean is, I will plug in the car to charge with the OEM charger (charger has all green steady lights – normal) and I will get the steady green top of dash light and a single beep to complete the handshake and start charging. Then after some time (time may vary from minutes to hours) the car will stop charging but the green light on top of dash is still showing steady green and the charger lights are all green and normal. Then at some point it may continue charging again or not, not predictable. Sometimes I get more than one iteration of charge and sometimes only one. Sometimes only one mile is added and other times it could be 20 some miles over an extended period of time.
    Things I know:
    No codes/messages set on vehicle, no codes/messages on OnStar diagnosis either.
    The charger is in the typical high amp charge mode, the charger remains plugged in to the home garage wall outlet and no changes have been made to the wall outlet. Same charging scenario for several years. Plug and outlet are clean and no issues with a bad connection.
    The charger remains solid all green lights whether it is charging or not (meaning if it stops charging midstream, before completing a full charge, the charger unit status lights are all steady green).
    The car’s green charging light on top of dash remains steady green when it is plugged in while the charging stops mid-stream during one of these charging episodes.
    I have unplugged and re-plugged in the vehicle plug during a stoppage like this and I get another steady green light and single beep and charge continues, but may interrupt later.
    Plug to car is fully latched, and wiggling plug while latched will not cause the steady green dash light to change it remains steady (meaning I thought it was maybe a bad connection).
    The car charges fine without interruption at a public L2 charger. No interruptions during those charges, even during the time period that I experience the OEM charging issues.
    I always used the L1 charger to charge my VOLT from day one, never a problem.
    I unplugged and re-plugged in the OEM L1 charger and it self-booted without issues to all solid green lights. Thinking maybe there was a fault that a reboot might detect, but this was not the case.
    This happens day or night. Temps are cool and charge cord is unwrapped completely so no overheating issues as by touch of charger unit, vehicle charge cord, or 120v plug.
    My charge status is immediate, no delay charging on the vehicle. I do not have any interruption service with my electrical service provider.
    OnStar phone app shows 120v icon (as though it is plugged in) but no status as to charging when this charge interruption happens, the “charging” status word is missing totally. Then when the car is actually charging during this on/off charging episode the OnStar app shows “Charging” as a status.
    So, any ideas of what I should try next? Kind of a bummer to come out and find the car had little or only a moderate charge after a full overnight or daytime attempt to charge. As for the use on the current OEM charger (remember it was replaced once after the first year) I used it for about 26-27,000 EV miles (with about another 3,000 miles of public chargers over the years).
    Thanks for any thoughts.
    2011, My Zen-like Car, and Driving Experience #3187
  2. #2
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,115
    Default
    Great writeup, pre-empting many questions. I'm stumped. Perhaps try charging with another L1 to see if there are still issues (then it's the car), or no issues (then it's something with the EVSE).
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
  3. #3
    Join Date
    May 2011
    Location
    Michigan
    Posts
    723
    Default
    Steve,
    Thanks, I thought of trying another OEM charger but not too many VOLT owners around. Do you know if a 2014 VOLT OEM charger at a dealer will work on a 2011? May have to try to get dealer to try that, if it gets to that. I did send a message to customer service advisor on the VOLT forum so see if they have any suggestions.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5.
    Advertisement
  6. #4
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    2,811
    Default
    test at a DIFFERENT amp setting. ( I guess the 2011 charger codes do 8-12 )
    get some reading with a kill-a-watt type meter
    Voltage-amps-
    Test with a loner unit
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
  7. #5
    Join Date
    May 2011
    Location
    Delaware
    Posts
    7,873
    Default
    Quote Originally Posted by 2BeLivingGreen View Post
    Steve,
    Any J1772 EVSE should work with any J1772 car (so the older Volt shouldn't have a problem with the newer GM cable.)
    I'm leaning towards a problem with either the EVSE or the house wiring - more likely the EVSE. Have you tried using that EVSE somewhere else (at the dealer maybe?) If the problem repeats, it's a failing EVSE. If not, it's something more subtle about your house or electric service.
    Walter
    2016 Tesla X75D delivered 8/25/16
    Hidden Content
  8. #6
    Join Date
    May 2011
    Location
    Michigan
    Posts
    723
    Default
    Quote Originally Posted by saghost View Post
    I'm leaning towards a problem with either the EVSE or the house wiring - more likely the EVSE. Have you tried using that EVSE somewhere else (at the dealer maybe?) If the problem repeats, it's a failing EVSE. If not, it's songwriting more subtle about your house or electric service.
    I was hoping that the self diagnostic start up within the EVSE would detect an issue within it. Maybe this is some sort of intermittent issue with the ESVE that start up may not detect and during use does not detect.
    As for the house wiring, nothing has changed and like I said the green lights stay steady on car and charger when this happens or otherwise I would suspect that either the car or charger would set some sort of error with lights etc.
  9. #7
    Join Date
    Jan 2012
    Location
    Lakeland Florida
    Posts
    3,383
    Default
    Anything else on the circuit the ESVE is plugged into? everything you describe is a low-voltage interrupt.
    1) make sure nothing else ( like a refrigerator ) on the circuit
    2) set to 8 amps
    3) get a kill-a-watt or DVM and measure the voltage at the outlet when charging
    2013 Crystal Red Volt #39239 - New off the lot 8/28/2014
    Make Your Stock charger 240V for 30 bucks! Hidden Content
  10. #8
    Join Date
    Aug 2013
    Location
    Acton, MA
    Posts
    3,408
    Default
    ..What I mean is, I will plug in the car to charge with the OEM charger (charger has all green steady lights – normal) and I will get the steady green top of dash light and a single beep to complete the handshake and start charging. Then after some time (time may vary from minutes to hours) the car will stop charging but the green light on top of dash is still showing steady green and the charger lights are all green and normal. Then at some point it may continue charging again or not, not predictable. ...
    how do you know it has stopped charging?
    here it is, my thoughts for "new to you" volt (2011 to 2015) owners, right or wrong, in one post....:
    Hidden Content
  11. #9
    Join Date
    May 2011
    Location
    Michigan
    Posts
    723
    Default
    Quote Originally Posted by Henry_FL View Post
    2) set to 8 amps
    Nothing else is on the circuit that is in use. Same routine for this circuit for four years with the VOLT.
    I did set the charger to the lower amp setting and it still hiccups. The car will give off it's signature simple beep indicating starting a charge as it is in the charge mode.
    I did reboot the charger several times more and still it happens. I do not have a kill-a-watt device but will see if someone has one or a way to read current through the power cord.
  12.
    Advertisement
  13. #10
    Join Date
    Mar 2010
    Location
    SF Bay Area, CA, USA
    Posts
    1,203
    Default
    You can get one at many hardware stores for $20-30 or at Amazon online. It's very handy for understanding your other household electricity use for finding conservation opportunities.
    It will tell you the present voltage, amps, or total kW and can also tell you the total kwh since the last time you reset it.
    http://www.amazon.com/P3-P4400-Elect...ds=kill+a+watt
    The answer is 0042.
    Hidden Content
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Bearing issue on my 2011 Volt
    By Carl S in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 07-11-2014, 02:19 PM
  2. Anyone else have a charging issue with Clipper Creek Lv2 charger?
    By marriott001 in forum Generation 1 Volt (2011-2015)
    Last Post: 02-08-2014, 01:24 AM
  3. OEM L1 EVSE Interrmittent Issue
    By David B. Kelting in forum Generation 1 Volt (2011-2015)
    Last Post: 11-05-2013, 07:15 PM
  4. Has anyone bought a 2nd OEM charger?
    By MX5 in forum Chevy Volt General Discussion, News, and Events
    Last Post: 10-19-2013, 08:42 AM
  5. 120v OEM Home Charger
    By ShannonVolt in forum Generation 1 Volt (2011-2015)
    Last Post: 06-04-2012, 10:19 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
