Kill-a-Watt question for power gurus
Grab our Forum Feed
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Kill-a-Watt question for power gurus
  1. #11
    Join Date
    Jul 2011
    Location
    Long Island, NY
    Posts
    480
    Default
    Quote Originally Posted by pKIO3 View Post
    Used mine for 3 months with it plugged in 24/7 and the 110V EVSE plugged into it 24/7. When I stopped using it after my 224 V system was installed I found the outlet on the Kill-a-Watt charred and partially melted. I had even installed a new outlet in the garage before I installed the Kill-a-Watt. It still works but I won't use it long term again.
    Was this the old (now recalled) 110V EVSE? I wonder if it may not have been the kill-a-watt, but the EVSE.
    2012 Volt (#3859) - Delivered 2011-10-06
    Computer programmer, science and engineering wonk, and habitual over-analyzer.
  2. #12
    Join Date
    Jan 2012
    Location
    Lakeland Florida
    Posts
    1,279
    Default
    The old ESEV ( orange color both cords ) did run very hot on the Kill-a-watt, the new one is just warm and no issues
    2012 Crystal Red Volt #10921 - Plug Powered #76
  3. #13
    Join Date
    Jun 2008
    Location
    Wisconsin USA
    Posts
    714
    Default
    Quote Originally Posted by Henry_FL View Post
    Attachment 5812Attachment 5813
    had mine connect for about 4 months now, 24/7
    Thanks for posting these photos. I just put up a dedicated outlet yesterday, but don't have the EVSE on hand yet, so they're very useful pictures.
    On a related note, here's a PDF I found that shows how to locate the mount plate for the 120V EVSE. I don't know the original source URL but I've rehosted it here: http://webpages.charter.net/flume/vo...SE-install.pdf
    Thanks everybody, for your very informative inputs. I will probably take off my Kill-a-Watt after a couple of days, once I have a good idea what's up through that socket.
  4.
    Advertisement
  5. #14
    Join Date
    Jan 2012
    Location
    Lakeland Florida
    Posts
    1,279
    Default
    If you look at my pictures closely, I mounted the base for the ESEV on 3/4" stands off's. This compensates for the Kill-a-watt bumping the plug out and keeps the cord from flexing/stressing the kill-a-watt socket. Another benefit is it helps keep the chargers base a bit cooler will air flow on the back-side
  6. #15
    Join Date
    Jun 2008
    Location
    Wisconsin USA
    Posts
    714
    Default
    Thanks for pointing that out. I surface-mounted a box, rather than flush-mounting the outlet. Here's a picture of the panel and outlet I installed. Naturally, it sticks out pretty far, so I'm likely to need standoffs as well.
    Elsewhere, I saw somebody else's install that used large bicycle hooks for easy EVSE hanging and removal, plus easy cable routing. That seemed like a good solution as well, but I'd like to use the purpose-built bracket, as I'm not planning to take my EVSE with me very often.
  7. #16
    Join Date
    Jun 2008
    Location
    Wisconsin USA
    Posts
    714
    Default
    Quote Originally Posted by Frankman View Post
    I replaced the duplex AC receptacle in the wall with one that has a receptacle on the bottom and a switch on the top (Home Depot). The switch on the top controls the receptacle on the bottom. The 110V EVSE is plugged into the bottom and when I'm not using it, I just press the rocker switch above it to turn turn it off.
    That's a nice solution. When I did my box, I was undecided about the need for switching, what vampire power usage the EVSE would draw, etc. So I used a double-wide so that I can add a switch easily later. I just need to swap out the faceplate.
  8. #17
    Join Date
    Apr 2012
    Location
    United States
    Posts
    339
    Default
    I just wanted to put in another plug for the iMeter Solo, which is basically a networked kill-a-watt (remotely read and track instant load and cumulative use). It's a nice solution for anyone into home automation stuff. It is an Insteon device. They offer a remote screen, so you don't even need a computer.
    It is also easy to put an Insteon relay/switch between the iMeter and the EVSE and, for example, add a rule that says "when load is less than 10 watts for 10 minutes, cut off all power to EVSE (if you were worried about vampire draw). You could then re-energize the EVSE on a timed basis or with a click on your iPhone (or whatever).
  9. #18
    Join Date
    May 2012
    Location
    Williston, ND.
    Posts
    162
    Default
    Nice installs. I just bought the goods to add a dedicated outlet for mine. I have two outlets in the entire garage, and both are on the same circuit. When the car is charging, I cannot do anything else.
    2012 Chevy Volt (7184 mi) - 307.9 mpg current tank 74.3 mpg lifetime
    2012 Dodge Ram QC 4x4 Big Horn edition
    2004 Saturn ION Redline (9k)
    1995 Tiffin Allegro Bay (43k)
    1968 International Scout 800 (project)
    http://mefi.us/images/fuelly/sig-us/128244.png
  10. #19
    Join Date
    Apr 2010
    Location
    Diamond Bar, CA
    Posts
    390
    Default
    One of my coworkers did fry a Kill-a-watt meter while using it on a Volt. He mentioned that it lists the max power, not the max continuous power on the Kill-A-Watt. Although he was running it longer than most since he lived in a cold area (thus the battery heater probably pulled a lot more power over that period.). I haven't had a problem with my kill-a-watt 120v EVSE.
    My Baby Jane: Volt Stats
    Leased: 2012 Viridian Joule / Black Accents + Leather + Ceramic White / Navi+Bose / Park-Assist / Polished Wheels / D8191
    Electric. Unlimited.
Similar Threads
  1. Replies: 12
    Last Post: 12-09-2012, 05:16 PM
  2. DC-DC Converter (APM/Advanced Power Module) question
    By wizkid057 in forum Engineering and Design
    Last Post: 10-31-2012, 04:13 PM
  3. Replies: 15
    Last Post: 05-04-2011, 11:18 AM
  4. VW’s Home co-generation power plant helps kill nuclear and coal use
    By Texas in forum Politics, Finance, and Environment
    Last Post: 09-25-2009, 11:18 AM
  5. ZAP has unveiled an 8,000-watt wheel motor
    By Jason M. Hendler in forum Electric Car Competitors
    Last Post: 05-20-2009, 06:18 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
