Charging taking over 12+ hrs.
Grab our Forum Feed
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Charging taking over 12+ hrs.
  1. #11
    Join Date
    Jun 2008
    Location
    Wisconsin USA
    Posts
    713
    Lightbulb
    Quote Originally Posted by topher View Post
    Right. Per the above notes, mine was in 8amp mode (slow charge). I pressed the orange button on the charger and that changed it to 12amp (standard charge).
    Just a footnote to anybody trying to switch charge rate, without success, I believe you have to remove the J1772 plug from your car before you can toggle the mode.
    You should see two green rate LEDs on the EVSE when it's in 8-amp mode, and all four LEDs for 12-amp mode.
  2. #12
    Join Date
    May 2012
    Location
    Destin,FL
    Posts
    66
    Default
    is there any benefit to purposely charging in 8amp mode(besides circuit breaker load), assuming one has the time for a longer charge? Less, wasted energy from heat(probably balanced out by longer charger)? anything?
  3. #13
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,658
    Default
    Quote Originally Posted by hull22 View Post
    Actually, faster charges are more efficient (less overhead time/power,) and the Volt's TMS manages any potential heat issues. The only reason I know of to use 8 amps is a system that can't take 12. (Most other portable EVSE's don't include the 8 amp option at all.)
    Walter
    Volt FAQ
  4.
    Advertisement
  5. #14
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,143
    Default
    Should be the opposite: more charge time means more heat loss and less efficient charging.
  6. #15
    Join Date
    Sep 2011
    Location
    Dallas Texas
    Posts
    1,283
    Default
    Both of my charger cord has several plastic pages of information tye-wrapped to the handle with charging information and amperage setting. Are the dealers removing these or are people throwing them away because they looked at the side not in English?
    Anyone have a PDF of that information all I have are iPhone pictures of the pages.
    2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
    09/29/2011 Ordered -- 11/15/2011 took it home
Similar Threads
  1. Trouble Taking my Dog in my Volt
    By TommyBoy in forum Volt Ownership Forum
    Last Post: 01-18-2012, 03:11 AM
  2. Taking my dogs for a ride in the Volt
    By silvercorvette in forum Volt Ownership Forum
    Last Post: 12-20-2011, 08:55 PM
  3. Could the reason GM is taking so long be ?
    By mikeandmerle2@yahoo.com in forum Volt Nation
    Last Post: 05-14-2009, 03:02 AM
  4. GM's Taking Are Tax Money and running
    By Mikro in forum Chevy Volt News and Events
    Last Post: 01-17-2009, 03:16 PM
  5. Taking battery down to only 50% SOC?
    By Altazi in forum Engineering and Design
    Last Post: 10-03-2008, 06:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
