I purchased and had installed the Voltec 220 Volt charger today. Should the 2 green lights on the charger always stay on even when the charger is not plugged into the vehicle?
Yes. They indicate that all is well with the supply and with the charger. I just added the second sentence because "yes" seemed curt haha.
White Diamond Tricoat, Light Neutral leather
05/12/11 1100 placed at dealership
10/24/11 3800 produced
11/5/11 Delivered!!!!!
here is a link
http://gm-volt.com/forum/showthread....ts-of-pictures)
it might have an answer for you and give you a list of who had one. ( sorry I don't have one )
2012 RED Volt VIN:#C-8860 - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav
09/29/2011 Ordered -- 11/15/2011 took it home
From the Voltec "manual:"
Charge Station Status Indicators
The charge station status indicators illuminate GREEN or flashing RED to identify the charge station status. When both indicators are GREEN, the vehicle can be charged. If any indicators are flashing RED, the charge station will not permit vehicle charging.
A flashing RED AC PRESENT (A) indicates the AC voltage is out of range.
Flashing RED AC PRESENT (A) and FAULT (B) indicates the electrical outlet does not have a proper safety ground. Charging is not permitted for safety reasons. The wiring must be repaired.
A flashing RED FAULT (B) indicates a charge station fault. Reset charge station at the circuit breaker, if the fault remains, contact your Volt dedicated advisor.
It says, "When both indicators are GREEN, the vehicle can be charged." So that means they are both GREEN even before you plug in. I have two, one in continuous use since March 25, and the other about a year later at a different location. So I have seen a lot of green lights. We sort of think of them as alien eyes in the dark, but then again I'm from New Mexico (but not Roswell).
Michael in New Mexico, Volt #1761
