Battery Saver active I've never heard of before - it almost sounds like it's saying the car isn't using the battery because it might harm the battery to do so. PPR sets whenever the engine or battery is unavailable for whatever reason (the most common place to see it is when the battery is drained to the bottom of the CS buffer climbing a mountain at freeway speeds, you'll also see it when you run out of gas.) Engine Not Available, Service Soon mean the car has detected some sort of condition that prevents it from running the engine, I think. Service Stabilitrak is a problem with the ABS/dynamic stability system - usually a wheel speed sensor or control module.
Taken together, a bizarre set to get at the same time. I think last year someone got water into one of the wiring bundles and had a bunch of weird error messages on the forums...
