Originally Posted by
hull22
I disagree, it's not the exact effect and efficiency. Take for example, starting at the top of a hill, going down and coming back uphill to a stop at the approximately the same elevation that you started. By coasting in D(or even N), you're letting kinetic energy get you down and part of the way up the hill. You'll have to use a little bit of battery power to make it back up. Going down the hill in L, you're undoubtedly going to lose some of that kinetic energy and convert it into regen energy, and then you're going to need to reuse that regen energy and more battery power to make it back uphill. That regen is undoubtedly less efficient than maintaining kinetic energy. I find coasting at 30-50mph in no way treacherous. I don't find myself really having to slow down using the brake pedal when coasting. If I need to slow down more than coasting to a stop, I'll flip it into L for the stop and back to D.
I don't disagree that if you have to go downhill to a stop, L is better than D because you regen better, I just think it's more efficient to cruise/coast in D than L because regen->accelerating worse than coasting.
