2016 ELR to debut before 2016 Volt?!?
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: 2016 ELR to debut before 2016 Volt?!?
  1. #1
    Join Date
    May 2011
    Location
    Delaware
    Posts
    7,965
    Default 2016 ELR to debut before 2016 Volt?!?
    InsideEVs article on the Volt sales numbers for September has some interesting tidbits in it:
    http://insideevs.com/chevrolet-volt-...ber-1394-sold/
    Our earlier question of “Why the heck is Chevy building so many darn Volts this summer?” (after well more than 10,000 had been available in August) was answered as General Motor’s idled the Volt’s Hamtramck Michigan in late August…and plans to keep it that way until the middle of November.
    The reason for the shutdown? Putting to work some of that previously announced $384 million dollar investment into the facility to prepared for the next gen Volt (due out in mid-2015), two other Voltec-based plug-in models … and a great big whale of a Cadillac that we will never mention here again.
    I'm not sure if the "two other Voltec models" includes the ELR - but either way that means at least one car we haven't seen yet (the long awaited CUV/SUV?)
    Also,
    But, not to fret if you are an ELR fan, it will return at some point in 2015 as a 2016 model year car – complete with “engineering enhancements“. The new 2016 Cadillac ELR will debut at the LA Auto Show in November.
    Since the 2016 Volt is supposed to first show up at NAIAS in late January, it seems like the new ELR will show up first?
    Walter
    2016 Tesla X75D delivered 8/25/16
    Hidden Content
  2. #2
    Join Date
    Jan 2012
    Location
    Pinellas FL
    Posts
    3,398
    Default
    The 2016 ELR is just a 2014 with possible the 17.1kw battery thats in the 2015 Volt, its not a gen 2 car.
    2013 Crystal Red Volt #39239 - New off the lot 8/28/2014
    Make Your Stock charger 240V for 30 bucks! Hidden Content
  3. #3
    Join Date
    Oct 2013
    Location
    Illinois
    Posts
    7,351
    Default
    It may very well not be a "Bolt":
    "There is some curious eco-mark news to report: apparently, last month General Motors filed two notable U.S. trademark applications, one for BOLT and the other for CHEVROLET BOLT.
    They are Application Nos. 86357513 and 86357523 (BOLT Applications), respectively, and list the goods as “motor land vehicles, namely, automobiles.”
    The clean tech and electric vehicle blogosphere was buzzing with speculation as to what this new brand means. Is GM planning to offer additional EVs, perhaps a new low-cost Chevy Volt, a short-range performance vehicle, or a cool new concept car? Maybe different battery sizes?
    One clue is that the BOLT applications’ goods listing is much broader than the goods in GM’s prior CHEVROLET VOLT trademark registration, which identified “extended range electric automobiles.” So, contrasted with the VOLT, the BOLT trademark could cover any type of automobile, electric or otherwise.
    For now, though, the clean tech blogs had to conclude there is no indication that GM intends to use this new trademark. Inside EVs proposed that GM might be trying to protect itself from a Chinese ripoff called Bolt.
    Gas 2.0 carried this non-use preemptive motive further, noting that:
    Car companies are constantly taking out trademarks for names they have no intention of using; it’s just a matter of making sure nobody else uses it either.
    While car companies may try to keep potential brand names away from their competitors, there are strict legal limits on the ability to protect a trademark that is not in use.
    To fully understand this and to put the BOLT Applications in context, we need a bit more information about the U.S. trademark system.
    A U.S. trademark application must have one or more legal bases, i.e., a situation (basis) defined by the federal trademark law, to support the filing. The available filing bases are (1) actual use of the mark in interstate commerce, (2) a bona fide intent-to-use the mark in interstate commerce, (3) a foreign trademark application for the same mark and the same goods or services, (4) a foreign registration for the same mark and the same goods or services, and/or (5) extension of an international registration for the same mark and the same goods or services. By far the most common filing bases are the first two.
    In the United States, trademark rights flow from, and are contingent upon, use of the mark. Although an applicant can keep a U.S. trademark application pending for about two and a half years based only on the stated intent to use the mark, the U.S. Patent and Trademark Office (USPTO) will not register a trademark in a use-based or intent-to-use application absent proof of use in interstate commerce and there is no enforceable trademark right, even at common law, without use of the mark.
    More particularly, to obtain a registration of a use-based or an intent-to-use application, the applicant must prove use of the mark for the goods and/or services listed in the application by submitting a specimen showing such use.
    If based on a foreign trademark application or registration or an international registration, however, the applicant does not need to use the mark in the United States to obtain a U.S. registration. The USPTO will register the trademark upon proof that the applicant obtained a foreign registration.
    Interestingly, the United States is one of only a handful of countries that require use to register a trademark and have an enforceable right in the mark. Most countries do not require use of the mark to obtain a registration.
    So filing a U.S. trademark application based on a foreign or international registration gets around the use requirement (in the United States and potentially anywhere in the world), at least or the purpose of obtaining a U.S. trademark registration.
    But that’s not the end of the story. The owner of a U.S. trademark registration registered solely on the basis of a foreign or international registration (i.e., without use in the United States) cannot enforce its trademark in a U.S. court. While some U.S. courts have held that such registrants have standing to sue, even in those courts, the registration would be canceled without use in interstate commerce.
    So while a foreign trademark registration can get you a U.S. registration without use in the United States, you probably can’t stop other U.S. users of the mark because your registration would be unenforceable and would not stand up in court.
    Now back to GM’s BOLT applications. This is where it gets interesting. The applications are not based on use of the marks in the United States or an intent to use in the United States. Rather, each application is based on a foreign application filing, specifically Brazilian trademark application number 907703178 for CHEVROLET BOLT and 907703070 for BOLT.
    Brazil is one of those countries that does not require use to obtain a trademark registration. So GM could get itself U.S. trademark registrations, albeit unenforceable ones, for BOLT and CHEVROLET BOLT without ever using this exciting new brand anywhere in the world.
    Even though GM’s U.S. registrations may be unenforceable “paper” registrations, Gas 2.0′s point still has some merit. Ownership of U.S. trademark registrations for the BOLT marks could still scare off potential users and keep competitors at bay for a while.
    Don’t be surprised, though, to not see a shiny new Chevy Bolt speeding by you on the highway." -Eric Lane - Green Patent Blog - September 24th, 2014
    One wiil be the Elmiraj (a great big whale of a Cadillac) I think. Another concept car pipe dream?
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5.
    Advertisement
  6. #4
    Join Date
    Aug 2012
    Location
    NOVA
    Posts
    143
    Default
    To answer the OP's question - yes.
    BoggieWoogieWoogie______It's Electric!!!Hidden Content
  7. #5
    Join Date
    May 2011
    Location
    Delaware
    Posts
    7,965
    Default
    Quote Originally Posted by Henry_FL View Post
    I must have missed something, Henry. Who told us that?
    Walter
    Hidden Content
  8. #6
    Join Date
    Jul 2009
    Location
    Listowel, Ontario, Canada
    Posts
    2,954
    Default
    Quote Originally Posted by saghost View Post
    It's just a rumor being stated as fact. Personally I believe the rumor is incorrect.
    2016 ELR will be shown at the LA autoshow coming up very fast (Nov 21). This is fact. So we will see.
    I do find it interesting that they say Volt plus two other Voltec models. One is the ELR. The other?
    DHAM will be building next year the all new Volt, ELR, all new Lacrosse and brand new CT6. I would put money on a plug-in CT6 of some type. For those that don't know the CT6 this is a large BMW 7 series sized Cadillac built off the brand new RWD Omega platform. The CT6 will show it's head not too long from now. The latest rumor I heard was at the NY auto show early next year.
    Hidden Content 2017 Volt - Kinetic Blue - Black Cloth - HU3085
    Hidden Content
  9. #7
    Join Date
    May 2012
    Location
    Montana
    Posts
    1,208
    Default
    Henry_FL doesn't know what he's talking about, and never has. His posts are forum garbage that waste everyone's time.
    Cadillac has stated that the 2016 ELR will be released in the "first half" of 2015, which we all know probably translates to June 30, 2015! The ELR will not only have the larger battery, but will improve upon those aspects of the vehicle that were criticized the most and have resulted in such low sales. Still, don't expect a 0-60 time like the Tesla; the battery just isn't big enough to put out enough power (physics always wins).
  10. #8
    Join Date
    May 2011
    Location
    Delaware
    Posts
    7,965
    Default
    Rephrase that, please. An opinion about his knowledge in this case is fine - generalizing it into a personal attack not so much.
    Walter
    Hidden Content
  11. #9
    Join Date
    Jun 2013
    Location
    Winter Haven, Fl
    Posts
    165
    Default
    Quote Originally Posted by Blastphemy View Post
    ...The ELR will not only have the larger battery, but will improve upon those aspects of the vehicle that were criticized the most and have resulted in such low sales....
    The aspect that has been criticized the most is the price, and given Cadillac's firm statements about pricing, I don't see any way they can even budge on price. Doing so would be an admission that it was a mistake. If they dropped the price on the ELR they would be under intense pressure to reset the CTS and ATS overpricing as well.
    I don't see any way they could, in quickly implemented "engineering enhancements", add $15K, $20K, or more to the value as perceived by potential buyers.
  12.
    Advertisement
  13. #10
    Join Date
    May 2012
    Location
    Montana
    Posts
    1,208
    Default
    What I'm guessing is that, in addition to the 17.1 kWh battery, Cadillac will increase the acceleration a bit (perhaps 0-60 in 8 seconds in EV mode and 6.5 seconds in ER mode), add a Sport-Hold mode (or Sport+ mode) that gives drivers the ability to engage the range extender in Sport mode without first depleting the battery, and perhaps add in the Cadillac features found in its other cars like a Head-Up Display, ventilated/cooled front seats, etc.
    I suppose for people who continue to drive normally without utilizing the extra acceleration and cooled front seats, they'll see the range increase to 39-42 miles on average; but those who regularly stomp the pedal and turn on the cooled seats will see about the same range as the 2014 ELR. Therefore, I don't expect Cadillac to announce an increase in range for the 2016 ELR.
    While I might want to speculate that Cadillac could also fix the C.U.E. system's numerous bugs, add a Volt-like "Leaf" hard button somewhere on the dash, give drivers the ability to disable the "you left the car on and took your keyfob" triple honk, add Magnetic Ride Control Suspension, etc., I really doubt that's going to happen. Cadillac said "engineering enhancements," not "re-engineer the vehicle."
    I agree with FloridaMatt - Cadillac isn't going to reduce the price for the 2016 ELR. And if that "enhanced" model didn't sell well either, then I'd expect we'd see another fire sale and the ELR would not get a 2017 model year.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Could this be the 2016 Volt?
    By a2hanif in forum Chevy Volt General Discussion, News, and Events
    Last Post: 08-20-2014, 05:05 PM
  2. Why so little known about the 2016 Volt?
    By alfon in forum Chevy Volt General Discussion, News, and Events
    Last Post: 08-07-2014, 04:02 PM
  3. 2016 Volt
    By USe-car in forum Generation 2 Volt (2016-2020)
    Last Post: 08-07-2014, 02:40 PM
  4. 2016 Volt may make autoshow debut this year
    By MTN Ranger in forum Generation 2 Volt (2016-2020)
    Last Post: 07-31-2014, 04:38 AM
  5. Is this the new 2016 Volt?
    By cdnuser in forum Generation 2 Volt (2016-2020)
    Last Post: 04-10-2014, 12:51 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
