Ac off due to high engine temperature
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: Ac off due to high engine temperature
  1. #1
    Join Date
    May 2012
    Location
    Greensburg pa
    Posts
    7
    Default Ac off due to high engine temperature
    I got this message a few minutes after the gas generator turned on. Has any body else had this message.
    The volt is in the shop. They said there replacing the thermostat heater. I never heard of that. I heard of thermostats but not thermostat heaters. Normally when the car is stopped at a red light or parking, the engine turns off. After I got this message the engine keeps running even when stopped. Also after recharging the battery, it stayed gas mode instead of switching back to electric mode.
  2. #2
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    4,081
    Default
    Quote Originally Posted by Dan97408 View Post
    One search I did stated this. Not sure if related but I thought it was interesting.
    http://forum.roadfly.com/threads/128...rmostat-heater
    there's a heater in the thermostat housing that tricks the thermostat into opening up more under heavy load conditions.
  3. #3
    Join Date
    Sep 2008
    Location
    my little grass shack
    Posts
    4,553
    Default
    Well technically you cannot replace the thermostat heater, separate from the stat and housing. It's all one part.But there should have been DTCs if it got to the point of bringing up the warning message. Did Onstar give you those? P00B7 perhaps?
    Hopefully they get you back in your Volt soon.
    WOT
    Welcome Hidden Content as our latest forum vendor!
    Follow the Chevy Volt and other GM electrified cars on Twitter! Hidden Content
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    14,982
    Default
    The more I learn about the Volt, the more I realize how far cars have advanced in general since my teen tinkering day. It seems that almost every month another mysterious Volt component comes to light.
    I found this the other day. Some sort of fuze I think.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
  7. #5
    Join Date
    May 2011
    Location
    Delaware
    Posts
    7,833
    Default
    Quote Originally Posted by Steverino View Post
    Attachment 5718
    Yup. That's the time management Fuze. If it ever starts glowing, make sure you have your towel with you, and hope it isn't a Thursday.
    Walter
    2016 Tesla X75D delivered 8/25/16
    Hidden Content
  8. #6
    Join Date
    Feb 2012
    Location
    SF Bay Area
    Posts
    316
    Default
    And DON'T PANIC!
    So much Hardware! So much Software! So many Electrons! And it's got Tires, too!
    #163718 "DasVolt2"
    2014 Volt, Crystal Red with EVERYTHING but polished wheels. Ours on October 25, 2014
    #8954 "DasVolt"
    2012 Volt, Black, with everything.. Ours on February 14, 2012 Retired on October 25 2014 at 37,395 miles of driving pleasure
  9. #7
    Join Date
    Dec 2015
    Location
    Virginia
    Posts
    1,458
    Default
    Bumping this thread because apparently this issue has reared it's head again.
    Also, damn I wish I had a picture because I have one of these plugged into my rear console power port.
    http://www.thinkgeek.com/images/prod...ar_charger.gif
    A study in opposites
    1997 Jeep Cherokee
    2013 Chevy Volt "OHM-RIDE"
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. COMFORT setting limiting "Engine Running due to low temperature" ERDTLT
    By scottf200 in forum Chevy Volt Engineering and Design
    Last Post: 03-04-2014, 11:17 AM
  2. Temperature Hack, keeps engine off.
    By F16BMATHIS in forum Chevy Volt Accessories and Modifications
    Last Post: 01-30-2013, 05:05 PM
  3. Getting stuck in "engine running due to temperature" mode
    By BxHBxH in forum Generation 1 Volt (2011-2015)
    Last Post: 02-10-2011, 09:57 AM
  4. Engine turning on for Temperature
    By mizzou in forum Generation 1 Volt (2011-2015)
    Last Post: 01-24-2011, 12:39 PM
  5. Experiencing the Chevy Volt Engine Running Due to Low Temperature
    By Lyle in forum Generation 1 Volt (2011-2015)
    Last Post: 12-12-2010, 09:37 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
