LED lighting (license plate & front turn signal/parking light
Grab our Forum Feed
+ Reply to Thread
Results 1 to 8 of 8
Thread: LED lighting (license plate & front turn signal/parking light
  1. #1
    Join Date
    May 2012
    Location
    Harrisonburg, Virginia
    Posts
    463
    Default LED lighting (license plate & front turn signal/parking light
    I understand why GM chose LED lighting for the DRL'S and rear lights as they are used continuously and are great at reducing battery draw. Why didnt GM finish it out with the turn signals, interior lights, rear license plate lights, etc? Anyone with photos with,aftermarket LED lights I mentioned above? Any issues with hyper flashing If I go this route? Any help appreciated.
    2012 Crystal Red Tintcoat
  2. #2
    Join Date
    Dec 2011
    Location
    Minneapolis
    Posts
    963
    Default
    Couple threads already in this subforum that cover this fairly extensively. I suggest paging through and looking for some of the longer threads if search isn't giving you what you're looking for. You'll see them.
    C3457
  3. #3
    Join Date
    Apr 2012
    Location
    Aurora, IL
    Posts
    91
    Default
    The search function on this forum is pretty frustrating. I type the keyword "LED" and it says "No matches".
    For that matter I've never been able to get search to return any results. Is it just broken or is there some ritual sacrifice that must be done first?
    Crystal Red 2012 Volt #19636, "Evie"
  4.
    Advertisement
  5. #4
    Join Date
    Dec 2011
    Location
    Minneapolis
    Posts
    963
    Default
    It just doesn't like search strings that are too small or return too many results. Throw an extra word or two in there and you'll be fine.
    C3457
  6. #5
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,982
    Default
    I replaced my dome lights and my backup lights and my license plate lights with LED's from SuperBrightLEDS.com.
    http://www.superbrightleds.com/
    It's pretty easy. Just look at the part number on your existing bulb. Cross reference it on superbright LED's and you get several choices for each one.
  7. #6
    Join Date
    Jul 2010
    Location
    Chicagoland
    Posts
    751
    Default
    TopSpeed1 has a rather thorough posting on what he did, including links to the appropriate bulbs from V-LEDs.com. I unashamingly stole every one of his ideas, including the red map lights, and am really happy with the results (other than perhaps the front dome light being a bit too harsh for my taste).
    Ron C. / Chicago-area
    2012 Crystal Red Tintcoat Volt C8794, acquired 11/08/2011
  8. #7
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    1,440
    Default
    I used license plate LED lights that were half the wattage TopSpeed used (1w instead of 2 I think?) and they are still super bright. Very easy to install.
    The parking lights are a pain, and also need a resistor in parallel to be installed.
    Volt Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Leaf Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Commercial Level 1 Charging Station - Low cost solution suitable for Hotels, Employers, Airports, etc.
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic - Love the blue!
    [SIZE="2"]Driving for FREE with Solar PV!
  9. #8
    Join Date
    Jan 2012
    Location
    53405
    Posts
    191
    Default
    a lot of the ones i see don't really work too well on the plates. it tends to wash out the numbers making the plate unreadable. to a state trooper an unredable plate is just cause for a search. not that they would find anything but a box of tools and a spare tire in mine. if you went with this i would take a long look at various angles at night to see what your plates look like.
Similar Threads
  1. Front License Plate
    By Mybatcar in forum Volt Ownership Forum
    Last Post: 11-23-2012, 05:10 PM
  2. Front license plate bracket
    By Bluejuice71 in forum Volt Ownership Forum
    Last Post: 03-05-2012, 08:31 PM
  3. Front turn signal bulb
    By Eric99 in forum Volt Ownership Forum
    Last Post: 12-27-2011, 10:55 PM
  4. Front License Plate listed as option but I don't want it
    By panzer948 in forum Volt Ownership Forum
    Last Post: 03-23-2011, 04:51 PM
  5. Front vanity license plate ideas
    By Frostberg in forum Volt Ownership Forum
    Last Post: 02-14-2011, 10:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
