A/C system heat pump option? with element as back heat?
Grab our Forum Feed
+ Reply to Thread
Results 1 to 4 of 4
Thread: A/C system heat pump option? with element as back heat?
  1. #1
    Join Date
    Nov 2011
    Location
    Honolulu, HI
    Posts
    61
    Default A/C system heat pump option? with element as back heat?
    Just wondering if this would work out better for heating for lower demands and have the electric element as a backup if needed. This would need a reversing valve on the piping system and software to make this happen.
    Thanks for looking
  2. #2
    Join Date
    Mar 2012
    Location
    Tempe, AZ
    Posts
    183
    Default
    This has been discussed here before in other threads.
    One problem with a heat pump is that they are not very efficient at very low temperatures. They are very efficient at moderate temperatures. Perhaps some combination of heat pump and resistive or gas engine heating would be optimal.
    2012 Viridian Joule, March 29, 2012
  3. #3
    Join Date
    Aug 2008
    Location
    Carlsbad, CA
    Posts
    754
    Default
    The Volt would make a really good platform for a heat pump since it turns on the ICE if it gets really cold, at other times the heat pump could extract enough heat from the outside air to work relatively well.
  4.
    Advertisement
  5. #4
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,976
    Default
    I believe GM is working on a heat pump for the Spark. I think it would be helpful in some situations. But as others have pointed out... In extreme cold heat pumps just don't cut it. You would still need an auxiliary heat source. This subject does make an argument for a CNG version of the volt... CNG or propane could be used for a small auxiliary heater. In fact... you could use a small tank of propane that runs a very small catalytic heater to heat the car in extreme cold climates. (Just an idea.)
Similar Threads
  1. ??? Heat adding HEAT while the AC is on
    By BAZINGA in forum Mechanical systems
    Last Post: 05-07-2012, 12:07 PM
  2. Delphi Developing Heat Pump For EVs.
    By larry4pyro in forum Engineering and Design
    Last Post: 05-01-2012, 12:50 PM
  3. Heat
    By Adarondax in forum Chevy Volt News and Events
    Last Post: 12-10-2011, 06:31 PM
  4. Volt in AZ Heat?
    By ol1bit in forum Volt Ownership Forum
    Last Post: 12-29-2010, 11:19 PM
  5. heat and AC
    By mr_3456 in forum Newcomers
    Last Post: 07-12-2008, 09:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
