anyone hear an annoying high pitched sound,,, any way to stop it
Grab our Forum Feed
+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 4 LastLast
Results 11 to 20 of 34
Thread: anyone hear an annoying high pitched sound,,, any way to stop it
  1. #11
    Join Date
    Apr 2008
    Location
    Effingham, IL
    Posts
    423
    Default
    I LOVE the sound! I wish it had the loud whine of a DC motor sometimes. :P
    Logged over 44,000 miles in my Volt, "B'Elanna" (Named after B'Elanna Torres of Star Trek Voyager.) Now powered in part by a 2.88kW Solar system!
    www.whatdrivesbrad.com
  2. #12
    Join Date
    Feb 2012
    Location
    San Diego
    Posts
    97
    Default
    True, it's an electric car, so it makes high pitch noises, but most of them are not too bad.
    However, my 2012, when in CS mode (e.g. the gas engine is running) and decelerating, it has a very loud high-pitch whine that really gives me a headache. I'm fortunate to have pretty good high frequency hearing, and it's really quite annoying. To me it's the biggest flaw of the Volt (second perhaps to the big blind spots).
    I've never driven another Volt, but I'm assuming that they all make the same noise?
    You can use this website to see if you can hear those sounds yourself: http://onlinetonegenerator.com/
    I'm guessing the Volt noise is somewhere between 9KHz and 12KHz? Lots of folks simply can't hear those noises.
  3. #13
    Join Date
    Mar 2012
    Location
    Illinois
    Posts
    1,649
    Default
    I can only hear it when driving close to a wall/building say going thru a drive-thru window at some fast food joint. But it's not annoying to these old ears, in fact I like the clean high tech sound that announces the future of the automobile.
    Tom
    USAF Retired
    2012 Volt
    Best EV Range 50.x miles (more than once)
  4.
    Advertisement
  5. #14
    Join Date
    May 2012
    Location
    great neck
    Posts
    2
    Default
    thanks for the help..... took car to dealer twice,,, they have no idea, they have only sold 2 volts. my rear cover fits fine, please let me know if you've heard anything else. I guess i'm one of the sensitive ones but I get a headache from it.
  6. #15
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    1,982
    Default
    What you hear is probably harmonics from the high frequency power inverter that drives the motor. The actual frequency of the power is above the range humans can hear... But the harmonics can "rattle" the windings in the motor at a frequency which is audible. The resulting sound is usually not very loud to humans. It's normal for electric vehicles to make these sounds. It's nothing to worry about. (And there is almost nothing that can be done to make it go away.)
  7. #16
    Join Date
    Nov 2011
    Location
    Fort Wayne, IN
    Posts
    125
    Default
    I worry about it annoying my dog.....
  8. #17
    Join Date
    Feb 2012
    Location
    San Diego
    Posts
    97
    Default
    In my car, the noise is only loud and annoying when the engine is running and I'm not accelerating. In that circumstance, I suspect the power flow is primarily from the gas engine to the generator to the battery. It seems to me that this should be about the same as when you are in electric-only mode and regen, but it's not, it's much much louder.
    Any gurus out there with a theory as to why the whine noise would be so much louder in the case when you are in CS mode?
    Last edited by soylentgreen; 05-06-2012 at 12:14 PM. Reason: apostrophe catastrophe
  9. #18
    Join Date
    Jun 2011
    Location
    Buckeye, AZ
    Posts
    95
    Default
    There is a noise that I hear on some Volts and not others. My first car (C3344, GM buyback) was absolutely silent when the car was booted on and remained in park. My new Volt (C14506) makes a constant high pitched whine (not ultra-high but high) when the car is turned on which cannot be heard inside with the windows up. At the dealer we listened to another car on the lot and it made the same sound. My friends Volt in LA is also silent like my first. It sounds as if it is an electrical related sound. The sound is not the same as the whine the electric motor makes a low speed when staring to drive. Any ideas?
    RIP: C3344 adopted 11/7/11. Red, Blk leather/dark, Bose, Polished wheels.
    Fresh Start: C14506 adopted 3/23/12: as above
  10. #19
    Join Date
    Apr 2012
    Location
    Aurora, IL
    Posts
    91
    Default
    VoltCrazee, we ran into the same situation and were told it was the battery cooling fans in the back. Our Volt adviser said this was "normal". We did hear the same sounds on another Volt but we swear it wasn't there when we first bought the car.
    Crystal Red 2012 Volt #19636, "Evie"
  11.
    Advertisement
  12. #20
    Join Date
    May 2012
    Location
    Erial, NJ
    Posts
    57
    Default
    I can hear the electric motor going at low speeds when first accelerating, probably because the AC frequency being sent to the 3-phase motor at those speeds is low enough so that the motor emits it audibly. Once the motor RPM gets a little higher the pitch is likely way too high for anyone to hear, if it even continues.
    I generally can only hear it clearly with the windows down in a parking garage or near a building. Never can hear it with the windows up. (2012)
Similar Threads
  1. High pitched beee sound coming from our 2012 Volt.
    By jingulbell in forum Mechanical systems
    Last Post: 04-07-2012, 01:33 PM
  2. Nothing quite as annoying as status 4B00
    By dgarnett in forum Volt Ownership Forum
    Last Post: 03-02-2012, 01:11 PM
  3. iPhone No Longer Getting Annoying Compatibility Error
    By SolarExec in forum Volt Ownership Forum
    Last Post: 10-18-2011, 06:44 PM
  4. high pitched sound when on, parked -- normal?
    By stephent in forum Volt Ownership Forum
    Last Post: 08-31-2011, 10:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
