I ran out of gas today
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 23
Thread: I ran out of gas today
  1. #1
    Join Date
    Jun 2011
    Posts
    123
    Default I ran out of gas today
    I had gone 2.5 months and 3900 miles since my last fill-up, but had to take a long trip today (140 miles). Just for grins, I ran the Volt out of gas on purpose. I put it in mountain mode, and just drove it until the engine died and the car switched back to electric with 14 miles range. I drove until I had 4 miles left and then filled up. The most interesting thing about the experience is that the trip odometer said I had used 9.6 gallons, and I put 9.753 gallons in the car. Pretty good for a 9.3 gallon tank! I'm still impressed with the highway mpg in gas mode. 40.9 MPG average at 67mph.
    DavidV
    Volt #2093 Crystal Red 30422 miles 4052 gas miles 300 lifetime MPG
  2. #2
    Join Date
    Feb 2012
    Location
    SF Bay Area
    Posts
    202
    Default
    YAY! I think it's cool we can actually play with our cars...when was the last time you did that?
    Cheers
    So much Hardware! So much Software! So many Electrons! And it's got Tires, too!
    #8954 "DasVolt"
    2012 Volt, Black, Light neutral leather interior/ Dark trim accents, Premium Trim Package, Polished Aluminum Wheels, Bose Premium Audio System, Navigation, Rear Camera/Park Assist.
    Ours on February 14, 2012
  3. #3
    Join Date
    Mar 2012
    Location
    Illinois
    Posts
    1,634
    Default
    I've read this is possible and will cause no harm to engine. That's pretty cool and thanks for showing us this is possible. I just completed a 900 mile trip and as I got down to 99 miles left on the tank I started feeling uneasy as I was on ruarl roads in Arkansas on a Sunday and hadn't seen a gas station in many miles.
    Thanks for sharing.
    Tom
    USAF Retired
    2012 Volt
    Best EV Range 50.x miles (more than once)
  4.
    Advertisement
  5. #4
    Join Date
    Oct 2010
    Location
    Graham, WA
    Posts
    218
    Default
    Ummm, when that happens to me I always wonder about the calibration of the pump. One station in Oregon I put 73 gallons into a 68 gallon tank...go figure. Complained to the manager... no effect. I called the state office of weight & measures and reported them.
    From GilChrist below MSRP
    C 2123 Veridian Joule, Black w/dark titanium accents, loaded.
    941 MPG...so far!!
  6. #5
    Join Date
    Feb 2012
    Location
    Salt Lake City
    Posts
    239
    Default
    Quote Originally Posted by MVRacing View Post
    A few weeks ago when filling up at the local Costco, I stopped filling and pulled out the filler nozzle. When I looked over at the pump to see how much gas I had put in, the numbers were still going up! They weren't moving fast - probably a cent every couple of seconds. But not even a drop of gas was coming out of the nozzle, so it was not very reassuring that I didn't get ripped off.
  7. #6
    Join Date
    Aug 2008
    Location
    Anderson S.C
    Posts
    1,088
    Default
    I did the same thing last Feb or March. I also used MM to make sure I could get to a station without gas. But some may not be aware of this, after you run out of battery power the car switches to gas (in normal mode) but when you run out of gas the car still has enough charge it holds in reserve to let you continue driving normally to a gas station. Then even after you run out of reserve battery power the car will continue in limp mode at reduced power to hopefully get you to a station.
    The people that designed this car really thought of everything.
  8. #7
    Join Date
    Apr 2011
    Location
    Livonia MI
    Posts
    771
    Default
    Quote Originally Posted by DavidV View Post
    Attachment 5611Attachment 5610
    Yeah, you are way too cool! There's already been a thread on this from a guy who got stranded by the side of the road thinking he would get 10 miles after he ran out of gas. (http://gm-volt.com/forum/showthread....d-Your-Battery)
    Yes, it won't hurt your engine, but what about your expensive in-tank fuel pump and the very expensive lithium-ion battery? The fuel pump is not designed to be run dry, and the limp-home mode is very stressful on the battery - the lower limit was set there for a reason; else GM could have advertised several more miles of range.
    As far as the 9.753 gallons (you are very precise), do you stop at the first or second click, or are you one of the people who keep clicking the nozzle until you are putting gas on the ground? The tank is designed with a space for expansion (especially with the sealed tank). You can trick the shutoff and use this space, but are likely to damage the emissions system (including the charcoal cannister) if the fuel has to expand enough to send fuel out of the tank into the other plumbing in the fuel system.
    Mountain mode will be producing high-cost electricity from gas, and unless you use all the electric range by the time you get to your destination, you are wasting money. There has been debate over whether it is more efficient to use MM on the highway and save battery miles for stop and go (normal CS mode will do this anyway), but I haven't seen anyone prove they are saving money, and I've seen people come around to the other way of thinking; to let the car decide for you.
  9. #8
    Join Date
    Feb 2012
    Location
    Las Vegas
    Posts
    548
    Default
    Thanks for sharing the experience, almost like being there...its good to know this is possible with the Volt, absolutely love this car...may miles of smiles be yours....
    US Army (Ret)
    2012 loaded Volt Viridian Joule
    2010 Prius
    7KW Grid Interactive Solar w/battery backup
    2.1KW Solar Hot Water
  10. #9
    Join Date
    Feb 2012
    Location
    Las Vegas
    Posts
    548
    Default
    Quote Originally Posted by Bob_Livonia View Post
    Just curious, which mode do you use on the highway versus city stop and go traffic?
    US Army (Ret)
    2010 Prius
  11.
    Advertisement
  12. #10
    Join Date
    Mar 2012
    Location
    CT
    Posts
    274
    Default
    [QUOTE=Bob_Livonia;144415
    [/QUOTE]
    This is true as my Volt needed to go in for service less then 5 days after i had her because of over filling at the dealership.. they needed to replace the pump and the can. It will be click and done for me.
Similar Threads
  1. Today is the Day!
    By Marc Lee in forum Volt Ownership Forum
    Last Post: 03-15-2012, 06:22 PM
  2. Hey, hey, hey got my Volt today
    By Koz in forum Buying/Leasing
    Last Post: 12-31-2011, 03:22 PM
  3. Today is the Day!
    By solar_dave in forum Volt Ownership Forum
    Last Post: 11-15-2011, 12:45 PM
  4. something new happened today
    By keegs54 in forum Volt Ownership Forum
    Last Post: 04-07-2011, 11:40 AM
  5. This from today
    By misslexi in forum Lithium and Advanced Automotive Batteries and Charging
    Last Post: 12-19-2008, 10:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
