Volt Not Charging after 1500 miles on the Odometer
Grab our Forum Feed
+ Reply to Thread
Page 8 of 8 FirstFirst 1 8
Results 71 to 77 of 77
Thread: Volt Not Charging after 1500 miles on the Odometer
  1. #71
    Join Date
    May 2012
    Location
    Malaysia
    Posts
    15
    Default
    Hi, we had some studies on the portable charger cords that we have here in Malaysia which is based on British Plugs standards of 240V 13Amp and we found that the Nissan Leaf UK specs charger cord is a 240V 10Amp, Delphi is 240V 13Amp. Chevy Volt needs 120V 15Amp and 240V 20Amp. Our charging poles use 13Amp 240V sockets. Technically Volt will not accept these Amperage but we are puzzled that it used to work before using the Delphi 240V 13Amp unit. Can you tell me how GM solved your problem? currently we can not charge our Car.
  2. #72
    Join Date
    May 2012
    Location
    Malaysia
    Posts
    15
    Default
    we had some studies on the portable chargers that we have here and we found that the Nissan Leaf UK specs charger cord is a 240V 10Amp, Delphi is 240V 13Amp. Volt needs 120V 15Amp and 240V 20Amp. Our charging poles use 13Amp 240V sockets. Technically Volt will not accept these Amperage but we are puzzled that it used to work before.
  3. #73
    Join Date
    May 2012
    Location
    Malaysia
    Posts
    15
    Default
    Quote Originally Posted by Andrew00 View Post
    Couple of questions...
    I poked around the Delphi web site but only saw a 120V portable EVSE. I did see options for various plug designs for China and Europe. What are the electrical standards for Malaysia? Did you have to modify the charger in any way to make it work in your country?
    What fuses are being blown?
    In Malaysia we use British Standard 13Amp 240V sockets "3PIN" the fuse is from the main board. However it does not happen alot, in some cases we get the Red Light blinking as check ground. the Delphi unit for us is custom made to 240V 13Amp.
  4.
    Advertisement
  5. #74
    Join Date
    Apr 2012
    Location
    Massachusetts
    Posts
    66
    Default
    Quote Originally Posted by JoE2012 View Post
    If you look on Page #6 of this thread, I posted the parts that the dealership replaced that corrected my problem. Basically it was the Charge port receptacle and the Volt's internal charger.
  6. #75
    Join Date
    Apr 2012
    Location
    Massachusetts
    Posts
    66
    Default
    I would SERIOUSLY suggest get a copy of the SAE J1772 standard, study it carefully and setup a test receptacle and evaluate that your custom charger is functioning to that standard. Validate that it's delivering the required voltages at the specified pins. You may have to put a load(like a big 4500W heating element) on it of some description in order for it to start delivering current and I would be EXTREMELY careful. At the very least demand that whoever built your custom charger perform that test for you and document the results.
  7. #76
    Join Date
    Jul 2009
    Location
    Colorado Springs, Colorado
    Posts
    2,857
    Default
    The Standard allows the car to request and then the EVSE to supply at a particular level. The Volt will happily charge at 8amp (using the supplied 120v charger.. if you push the orange button it will switch from 12amp to 8 amp mode).
    If you tripped you circuits a few times, its possible you now have a weakened circuit, maybe leaking to ground, and/or the voltage is slightly out of spec. So the EvSE could be detecting the state and only offering the VOLT something it is not willing to take. The other cars might negotiate different levels and find something they can accept.
    You might want to look into a large 240v to 120v step-down transformer (3kw at least). You might find that some computer shops have them, or UPS, designed to support larger servers. I run a whole bunch of my computers on large UPSs that take 220/240 in and provide 110v out. Then you might be able to test with the 120v that came with the Volt and try setting it at 8amps.
  8. #77
    Join Date
    Sep 2008
    Posts
    2,494
    Default
    Quote Originally Posted by tboult View Post
    The European portable EVSE (supplied with the Volt/Ampera) operates at 10A or 6A as the standard "fuse" (breaker) is typically 13A
    So I'm wondering if Proton Joe isnt just attempting to use the North American EVSE (Delphi?) with some sort of plug adapter?
    In any case he is spamming pretty much every charging related thread...
    I've PM'd him requesting he simply create a NEW thread
    WOT
    Follow the Chevy Volt on Twitter! @WopOnTour
Similar Threads
  1. Replies: 22
    Last Post: 05-04-2012, 03:20 AM
  2. Detroit Free Press: GM to temp. layoff 1500 Volt workers
    By seni0rl0c0 in forum Chevy Volt News and Events
    Last Post: 03-05-2012, 11:11 AM
  3. Suggestions after 1500 miles
    By Argojm19c in forum Suggestions for GM
    Last Post: 10-09-2011, 11:35 AM
  4. Odometer should display %EV only miles
    By Joshua Bretz in forum Suggestions for GM
    Last Post: 01-30-2009, 07:07 PM
  5. Have you played with your odometer yet?
    By DaV8or in forum General Motors and General Automotive Topics
    Last Post: 04-19-2008, 10:23 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
