Originally Posted by
I think Henry is right about the cause of the problem. The Volt seems to be a little "touchy" about charging but better safe than sorry.
You can use a standard outlet to charge the Volt but that assumes a circuit which is in good shape. While you're waiting, see if you can find a different circuit or, better still, a dedicated circuit, and see if this helps.
Same thing happened here the night I brought mine home. A shorter and higher-capacity extension cord made all the difference.
Household wiring, other loads, etc., are the wild cards.
2012 Crystal Red / Black, #10,860, delivered Dec 14, 2011.
