Disable traction control for use on a dyno...?
Grab our Forum Feed
+ Reply to Thread
Results 1 to 4 of 4
Thread: Disable traction control for use on a dyno...?
  1. #1
    Join Date
    Apr 2012
    Location
    UK
    Posts
    1
    Default Disable traction control for use on a dyno...?
    Hi
    Can anyone out there tell me how to get a Volt into a mode where we can use it on a dynamometer? We'll need to disable the traction control, which we'd normally do by removing the fuse, but the Volt we're working on won't drive without it!
    Any suggestions appreciated. I'm working with one of the very few Volts in Europe, so local advice hard to come by.
    Many thanks,
    Ruth
  2. #2
    Join Date
    Mar 2008
    Posts
    1,299
    Default
    I guess you have a 2011 model? With the 2012 model, you will see a button to disable it above your head in the dome light button area. I dont believe 2011 models could do this, but I could be wrong.
    2012 Chevy Volt
    Please visit my blog at Hidden Content
    Twitter: @voltdriver
  3. #3
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    12,148
    Default
    You're right. No way to disable traction control on the 2011 MY units, like the one I have.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Apr 2012
    Location
    Chicago area, IL
    Posts
    10
    Default
    On a less sophisticated vehicle, I'd suggest that unplugging one of the wheel sensor would disable the TC (as well as the ABS). The fault light should activate on the dash upon starting the vehicle. However, I have no idea what that would do to a Volt since wheel speed is probably used to control the drive mechanism. Maybe the vehicle would go into a "limp mode" and corrupt your dyno test?
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Rearview mirror dimming disable?
    By Rusty in forum Generation 1 Volt (2011-2015)
    Last Post: 09-28-2012, 08:27 PM
  2. I have this might as well syndrome regarding the window disable feature.
    By silvercorvette in forum Generation 1 Volt (2011-2015)
    Last Post: 04-07-2012, 01:54 PM
  3. How to disable the Bose subwoofer
    By rubley in forum Chevy Volt Accessories and Modifications
    Last Post: 12-05-2011, 03:55 AM
  4. MY 2012 Volt Traction Control (TCS) and StabiliTrak (ESP) Manual Deactivation
    By BlackVolt in forum Chevy Volt Engineering and Design
    Last Post: 10-03-2011, 03:14 PM
  5. Can the traction control system reduce regen as it can reduce aceleration?
    By marlow in forum Chevy Volt Engineering and Design
    Last Post: 07-15-2011, 09:52 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
