Battery Usage
Grab our Forum Feed
+ Reply to Thread
Results 1 to 8 of 8
Thread: Battery Usage
  1. #1
    Join Date
    Apr 2012
    Location
    South Carolina
    Posts
    12
    Default Battery Usage
    I recently purchased my Volt. The more I drive the higher my EV milage. I have been getting from 40 to 44 miles per charge. Today I drove a number of short trips. 1 to 2 miles each time. I noticed that my EV milage was not as good. Is this normal?
  2. #2
    Join Date
    Jan 2011
    Location
    Hawaii
    Posts
    265
    Default
    You're probably confusing the programming of the estimator. Don't pay attention to it, as it's just a guess and not real life. Give it about 150-200 miles before you start trusting/understanding it. The thing is, even if it gives you a pretty good guess at the beginning of the day, it has absolutely NO idea what you will do with it in the future. It is not a fortune teller... it has no way of knowing whether you will baby it and drive it down a 20 mile hill, or whether you take it to the drag strip and run the hell out of it. It's just like a weather man... he has no idea if it will rain at YOUR HOUSE, only a guess for the area. Look at www.voltstats.net to determine what others are ACTUALLY getting in your climate and terrain. If you are driving your car 30 miles at one shot and running out of battery regularly then you may have a problem, may. But my guess is that you will see about 35-45 this spring and a few miles lower in the summer heat and 10 miles lower in the deep of winter on days colder than 25.
    Aloha! codyozz 89 Chevy K1500 (want to convert to EV) driven 80miles/month.
    2008 Specialized Hard Rock Bike (lifetime mpg; 1 coffee/5 mile trip) with 6' Bamboo cargo trailer. 400# capacity. No Volt yet....
  3. #3
    Join Date
    Mar 2008
    Location
    Coral Gables, FL
    Posts
    1,173
    Default
    Yes, likely normal because short trips likely have more starts and stops per mile traveled. Additionally, it can mean mean higher accessory loads if temps aren't mild.
    Koz
    C8906
  4.
    Advertisement
  5. #4
    Join Date
    Feb 2012
    Location
    Las Vegas
    Posts
    548
    Default
    Quote Originally Posted by Dekka37 View Post
    Your milage will increase if you try and keep the happy spinning green leaf ball in the center...its a driving behavior modifier and gives you the best milage..the amount of climate control used will also affect your milage but this also is a learning curse and the more you drive and observe what the different modes can and cannot do you will become even wiser..the learning tips on the center stack can also be very useful....miles of smiles....
    US Army (Ret)
    2012 loaded Volt Viridian Joule
    2010 Prius
    7KW Grid Interactive Solar w/battery backup
    2.1KW Solar Hot Water
  6. #5
    Join Date
    Mar 2012
    Location
    Illinois
    Posts
    1,664
    Default
    Quote Originally Posted by Koz View Post
    Exactly what I'm discovering. If I need to use juice to cool the cabin, a few short errands when I have to shut off the car, it will start absorbing heat again, only to be cool off again.
    The same anomaly occurs with a ICE car, but in the Volt you are provided a real time up date as to how much juice it takes to cool or heat a vehicle.
    Tom
    USAF Retired
    2012 Volt
    Best EV Range 50.x miles (more than once)
  7. #6
    Join Date
    Mar 2012
    Location
    United States
    Posts
    296
    Default
    You didn't mention if you were running the heat. Climate control has a far greater effect than variations in driving style. Run the heat on full blast and you'll see your range dip into the high 20s.
  8. #7
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,146
    Default
    Quote Originally Posted by banadictaustin View Post
    Make sure the batteries are placed properly into the compartment, Rechargeable car batteries is entirely different the battery system is similar to traditional car batteries. If you not usage regular of your car you faced a problem with maintenance. lack of fluids in it will help the users to drive their cars for quite a long time.
    What the ... ??!?
  9. #8
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,670
    Default
    Quote Originally Posted by Slapshot28 View Post
    What the ... ??!?
    I don't know. He made a similarly bizarre post about studded tires on the when does the ICE drive the wheels thread. Both of these look like things that could come out of a heuristic spambot (selling the signature link.) His other posts are more on topic though. I dunno.
    Walter
    Volt FAQ
Similar Threads
  1. Replies: 2
    Last Post: 03-17-2012, 09:09 AM
  2. Air Conditioning and battery usage
    By agggilli in forum Newcomers
    Last Post: 01-24-2012, 12:58 AM
  3. Power usage in battery conditioning?
    By RaelGabriel in forum Newcomers
    Last Post: 09-28-2011, 12:06 PM
  4. Tracking of KWh usage
    By evportlandme in forum Volt Ownership Forum
    Last Post: 08-31-2011, 09:55 PM
  5. usage since last charge screen?
    By voltowner in forum Volt Ownership Forum
    Last Post: 03-11-2011, 01:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
