51+ Miles AER at 65 mph on the freeway
Grab our Forum Feed
+ Reply to Thread
Results 1 to 4 of 4
Thread: 51+ Miles AER at 65 mph on the freeway
  1. #1
    Join Date
    Oct 2012
    Location
    United States
    Posts
    658
    Cool 51+ Miles AER at 65 mph on the freeway
    I had to go to my nephew's wedding and I found an evse 1 mile from the reception. I made it to the evse with 2 miles remaining, now if I had a faster charger I could do it all on battery. go
    Edit:
    Sorry I was on my phone last night or I would have provided more details. Temps 80's, AC on Eco set to 72~73. Terrain, semi flat with one big hill and lots of rolling.Elevation ~4400 Feet. I was worried I would not make the EVSE since there was a slight rise near the end, and I know when the Volt gets low it switches early. The EVSE was a 6.6 KW unit so If I had a bigger charger I could have avoided the .99 Gallons of gas. Still I managed 154 MPG for the day but I lost one lifetime, down from 211 to 210. I was watching the torque Pro the whole way, very interesting, I gamed it coming back using hold like Mountain mode when the battery built up more charge I cycled through normal to hold(I held @ 6 miles), to gain more battery. Not as efficient but I managed to drive the last 10 miles on battery. I used Torque Pro to make sure I had 100% battery before I left (I unplugged early).
    2013 Cyber Grey Volt, Heated Seats, & Safety 1 (Gets more Awesome every drive!)
    OPEN EVSE - Arduino and Open EVSE DIY 30A
    64.1 Miles on a single charge! Hidden Content Very Many 50+ on single charge!
    Hidden Content
    #1 GAS H8R
    6kW of solar PV on the roof, I'll be driving carbon free!
  2. #2
    Join Date
    Apr 2014
    Location
    Orange County, CA
    Posts
    339
    Default 6.6 kW OBC Gen-2
    Quote Originally Posted by markh21518 View Post
    Hence my insistence on minimum 6.6kW on-board charger for 2016 Gen-2 Volt.
  3. #3
    Join Date
    Jul 2010
    Location
    Bayamon, Puerto Rico
    Posts
    4,253
    Default
    That was great! You got about five miles per kWh, which is excellent (most Volt owners average about four miles per kWh). I expect GM to produce a better AC motor with up to seven miles per kWh , so the next BEv will carry a 30 kWH battery and reach the magical 200 mile EV range.
    BTW, even if the Volt had a 6.6 kW charger, the EVSE will still have a supply limit, and your Volt wouldn't change faster. I expect to see in the near future some OEM or aftermarket business to sell an upgraded charger (maybe a 6.6 kW unit) for the Volt.
    No Volt or Bolt EV yet!
    2009 Chevrolet Equinox 2LT
    Level 2 JuiceBox EVSE installed at 7.2 kW
    Registered EVSE at PlugShare
    Waiting for the first EV to charge!
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Mar 2008
    Location
    Arlington, Virginia
    Posts
    1,780
    Default
    Slow charging made me use the gas genset this week, as well. 25 miles in the morning, took a break at the Mosaic where we could plug in and eat a great lunch at 4 Sisters. I got 9 more miles of AER in almost an hour. Then I drove 29 more miles and the last 2 were using gas. It isn't a big deal, but I wouldn't have needed the gas if the pack charged at a 6.6 kW rate.
    I have seen electric car geeks say that upgrading from 3.3 to 6.6 kW charging would only cost GM $300-$400, but I don't know if that is true. If it is, and if the markup by GM was only $100 of profit, I would definitely like to pay for a faster charging option. If they charged $1,000, I am not sure if I would bite. It would be a nice option to be able to choose, though. And 10 kW charge rates like the RAV-4EV would be even better.
    It isn't like the Volt NEEDS faster charging, but it doesn't NEED more AER or roomier backseats, either. But having those 3 upgrades would make the Volt a much better car.
    On Edit: I guess my wish list for the Gen II Volt is, in order of importance:
    1) Lower MSRP
    2) Roomier backseats
    3) More AER [45 miles would be outstanding]
    4) Faster charge rate
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. BMW i8 official EPA rating: 0 miles AER
    By bro1999 in forum BMW
    Last Post: 08-11-2014, 08:07 PM
  2. Power went out on the freeway going 60 mph
    By SFB in forum Software & Programming/Code Discussions - Chevy Volt
    Last Post: 04-24-2014, 06:51 PM
  3. 2014 Volt Range Experiment - 74.0 Miles AER on 1 Charge!
    By doudis2 in forum Generation 1 Volt (2011-2015)
    Last Post: 10-03-2013, 10:59 AM
  4. AER at 30/35/40/45/50/55/60 mph, 70 deg, level ground, nonstop
    By Logical_Thinker in forum Generation 1 Volt (2011-2015)
    Last Post: 12-05-2012, 10:05 PM
  5. 40 or 28 miles? Which AER driving profile did GM choose?
    By Tom in forum Chevy Volt Engineering and Design
    Last Post: 03-04-2009, 12:27 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
