Has anyone actually installed he Curt Hitch?
Grab our Forum Feed
+ Reply to Thread
Results 1 to 10 of 10
Thread: Has anyone actually installed he Curt Hitch?
  1. #1
    Join Date
    Jan 2012
    Location
    United States
    Posts
    6
    Default Has anyone actually installed he Curt Hitch?
    Hey guys- found the curt hitch for $118- reading the posts- I'm sure the tork lift is better- but mine is a company car- and I need he cheapest solution to haul a hitch bike rack since I turn it in every 18 to 24 mths .
    Has anyone used - or installed this hitch..?..
    I know it goes under the light will be horrible for ground clearance- but for one or two weekends a month I'll deal
    My main concern is- is his easy to install? If not I will have to do a tailgate strap carrier which I'm VERY worried about for an upcoming 8 hr memorial day biking trip
    Any knowledge / opinions will be great
  2. #2
    Join Date
    Jan 2012
    Location
    53405
    Posts
    235
    Default
    yes i have. one largeish hole has to be drilled. removing and cutting the under tray instructions are daft. curt should just have made a full size paper template.
    the curt reciever is 1.25" most bike racks are 2".
    i duct taped a small cardboard box where the hitch would hang down and drove it around for a week. if the box is still there and undamaged then you wont have a problem.
    my problem is that there is no wiring harness schematic avalable and the led tail lights seem to work backwards from a regular car. this should be no problem for just carrying bikes as in your case.
  3. #3
    Join Date
    Jan 2012
    Location
    United States
    Posts
    6
    Default
    Thanks emd. Much appreciated. My rack is 1.25 opening which will work perfectly. Should be interesting as it hangs out far....any small incline will probably scrape- but I don't plan on having the rack on unless the bikes are on it to.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Apr 2012
    Location
    Seattle
    Posts
    46
    Default
    Quote Originally Posted by torn66 View Post
    ... I will have to do a tailgate strap carrier which I'm VERY worried about for an upcoming 8 hr memorial day biking trip
    I'd like to know more too- I just purchased a Thule Gateway strap-type trunklid carrier for my Volt.
    I commute by car+bicycle two or three days a week so having the bike carrier stay attached to the car nearly all the time is important. But I'm leasing, so I will be dinged for any scuffs or scratches when I turn the car in. The instructions that came with the Thule note to remove it when it is not being used to carry a bike.
    I've never used a strap style trunklid bike rack. Is that why Thule says to remove it?
  7. #5
    Join Date
    Mar 2012
    Location
    CT
    Posts
    315
    Default
    because any dirt between the rack and the contact point WILL mar and scratch the finish...
    I would never use one of them... but then again i have an expensive bike.
  8. #6
    Join Date
    Jul 2009
    Location
    Colorado Springs, Colorado
    Posts
    3,141
    Default
    Quote Originally Posted by holland_patrick View Post
    I would never use one of them.. but then again I have an expensive Volt.
    I've already carried by volt inside, no need to even take the wheels off, just put the seat down (and I used a blanket). Works fine for 1 bike.. but for 2+ well a rack would be nice. Let us know how it goes.
    BoultVolt Red 2011 #3745Hidden Content More freedom than electric.
    Personal best, Hidden Content
  9. #7
    Join Date
    Mar 2012
    Location
    Sunny Florida
    Posts
    538
    Default
    FWIW, we use to use the Saris Bones bike carrier and did notice a few, very minor scratches. The trick is to put the clean feet on a clean surface and get it tight so it's not wiggling. I never really liked that system though because we worried about theft.
    We have a swing away bike carrier on the SUV, but I imagine that would be too much for the Volt either hitch - probably for the Torklift but especially the Curtis with it's floorpan mount. But either should be able to handle a regular hitch mounted carrier.
    If you're carrying a nice bike regularly I'd use a hitch mounted carrier. As soon as Torklift comes down in price that's what we'll be doing.
    Ford Fusion Energi
    Cyber Gray Metallic VOLT
    Gasoline is for suckers Hidden Content
    Dan & Nan - Lowering gas prices since March of 2012
  10. #8
    Join Date
    Mar 2012
    Location
    CT
    Posts
    315
    Default
    Quote Originally Posted by tboult View Post
    I have the knowledge to buff out the volt if i had to use one of those.. but i would not beable to weld up the frame of the bike it is ever fell off...
  11. #9
    Join Date
    Apr 2012
    Location
    Seattle
    Posts
    46
    Default
    Quote Originally Posted by Dan & Nan View Post
    Me too, I think. One concern with the TorkLift is that the license plate is up (and unreadable) when a bike carrier is installed. I wonder how bothered the LEO's will be by that...
  12. Advertisement
  13. #10
    Join Date
    Mar 2012
    Location
    Sunny Florida
    Posts
    538
    Default
    Quote Originally Posted by Jeff.Rivers View Post
    Very. Which is why I don't understand why they're including the flip down mechanism. You're going to have to remove and remount the plate somewhere when carrying a bike or basket so they should cut the mechanism and the price
    Ford Fusion Energi
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Torklift Invisi Eco Hitch has shipped
    By artsci in forum Chevy Volt Accessories and Modifications
    Last Post: 06-03-2014, 02:37 PM
  2. curt trailer hitch
    By emd in forum Chevy Volt Accessories and Modifications
    Last Post: 10-18-2013, 08:27 PM
  3. Finally got my bike rack installed on the TorkLift hitch: photos of rack and trike
    Last Post: 05-31-2012, 09:48 PM
  4. Trailer Hitch for Volt, Now less than $150.
    By davedave2008 in forum Chevy Volt Accessories and Modifications
    Last Post: 04-06-2012, 08:55 PM
  5. Hitch
    By Herto in forum Chevy Volt Engineering and Design
    Last Post: 04-16-2010, 01:21 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
